The CMA provides enhanced productivity whereby all elements can be analyzed in one run, fulfilling all environmental detection limit requirements of the US-EPA. The CMA can be fitted to any model in the Jobin Yvon ICP product range very easily, allowing rapid and efficient analysis of hydride forming elements down to ultra trace levels. The CMA is very simple to set up and can be used as the standard sample introduction system. If a run does not require the use of hydride generation to reach ultra-trace levels, simply turn off the pump that transports the hydride generation reagents to the chamber.
关闭产品配置单
HORIBA(中国)为您提供《溶液中氢化物检测方案(ICP-AES)》,该方案主要用于环境水(除海水)中无机阴离子检测,参考标准《暂无》,《溶液中氢化物检测方案(ICP-AES)》用到的仪器有HORIBA Ultima Expert高性能ICP光谱仪。
