· Agilent Technologies Differential Analysis in Screening Assays for Extractable and Leachable Compounds 摘要: The analysis of extractable and leachable (E&L) compounds presents challenges for datainterpretation and compound identification. The interpretation of data for controls and samples istraditionally performed manually, and can be very time-consuming. Software-based datainterpretation greatly alleviates this challenge. Mass Profiler Professional (MPP), a chemometricsoftware application, performs differential analysis, and provides a means to readily visualize thedistribution of compounds across samples. The identification of compounds encountered during E&L analysis using GC/MS with electronionization (El) requires a degree of specialized knowledge. The use of El often results in a massspectrum that does not contain a distinct molecular ion, and identification is dependent on matchingcharacteristic fragmentation patterns. In E&L studies, fragmentation matching scores can be relativelypoor, where compounds are present in minor concentrations or interfered by strong chemicalbackground noise. Therefore, not all compounds may be identified unequivocally based on theirfragmentation pattern alone. In this study, an Ophthalmic Drug Product (ODP) and its containerclosure system were analyzed using an accurate mass high resolution Agilent 7200 GC/Q-TOF systemin both El and chemical ionization (CI) modes. The analysis of extractable and leachable (E&L) compounds presents challenges for data interpretation and compound identification. The interpretation of data for controls and samples is traditionally performed manually, and can be very time-consuming. Software-based data interpretation greatly alleviates this challenge. Mass Profiler Professional (MPP), a chemometric software application, performs differential analysis, and provides a means to readily visualize thedistribution of compounds across samples.The identification of compounds encountered during E&L analysis using GC/MS with electron ionization (EI) requires a degree of specialized knowledge. The use of EI often results in a mass spectrum that does not contain a distinct molecular ion, and identification is dependent on matching characteristic fragmentation patterns. In E&L studies, fragmentation matching scores can be relatively poor, where compounds are present in minor concentrations or interfered by strong chemical background noise. Therefore, not all compounds may be identified unequivocally based on their fragmentation pattern alone. In this study, an Ophthalmic Drug Product (ODP) and its container closure system were analyzed using an accurate mass high resolution Agilent 7200 GC/Q-TOF system in both EI and chemical ionization (CI) modes.
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《药包材中萃取物与浸出物检测方案(气质联用仪)》,该方案主要用于其他中溶出物检测,参考标准《暂无》,《药包材中萃取物与浸出物检测方案(气质联用仪)》用到的仪器有null。
