北京豫维科技有限公司联系人:水先生电话:18911849923安徽医药 Anhui Medical and Pharmaceutical Journal 2013 Jun;17(6)·958· 气相色谱法同时测定黑豆馏油软膏中桉油精和冰片的含量 宋 莉,黄 艳,刘雪峰 (陕西省食品药品检验所,陕西西安 710061) 摘要:目的 建立黑豆馏油软膏中桉油精和冰片的的定量方法,更好地控制产品质量。方法 采用 Rtx-WAX毛细管柱(柱长30 m,内径0.25 mm,膜厚度为0.25 p.m),以环己酮为内标,流速:1.5 mL·min,程序升温:初始温度为60℃,持续7 min,以每分钟15℃的速率升温至140℃,保持5 min; FID 检测器。结果 气相色谱法测定,桉油精油0.3206~8.0158 pg范围内线性关系良好(r=0.9999),冰片在0.1652~4.1307 pg范围内线性关系良好(r=0.9999);桉油精平均回收率(n=6)为 98.7%,RSD=1.5%,冰片平均回收率(n=6)为98.9%,RSD=1.6%。结论 该方法能准确地进行桉油精和冰片的定量测定,且灵敏度高,重复性好,快速简便,可用于黑豆馏油软膏的质量控制。 关键词:黑豆馏油软膏;桉油精;冰片;气相色谱法 Determination of eucalyptol and borneol in HeidouLiuyou Ointment by GC SONG Li,HUANG Yan,LIU Xue-feng ( Shanxi Institute for Food and Drug Control,Xi'an 710061,China) Abstract:Objective To establish a GC method for the determination of eucalyptol and borneol in Heidou Liuyou Ointment. Methods The column was Rtx-WAX(30 m×0.25 mm×0.25 wm) ,and the gas flow rate was 1.5 mL· min-. Cyclohexanone was selected as in-ternal standard. The temperature program of column oven was set as follows: 60 ℃ for 7 min,increased to 140 ℃ at a rate of 15℃·min- and held for 5 min. The detector was FID. Results Under this condition,eucalyptol showed good linear relationship in the rangebetween 0.320 6 and 8.015 8 ug(r=0.999 9) and borneol showed good linear relationship in the range between 0. 165 2 and 4.130 7ug(r=0.999 9). The average recoveries of eucalyptol and borneol(n=6) were 98.7% and 98.9% with RSD 1.5% and 1.6%,respec-tively. ConclusionThe method is simple,rapid and can determine the content of eucalyptol and borneol accurately with higher sensitivi-ty,which can be used as the determination control method for Heidou Liuyou Ointment. Key words: Heidou Liuyou Ointment; eucalyptol; borneol; GC 黑豆馏油软膏由黑豆馏油,桉油,氧化锌和冰片四味药组成,其功能主治为消炎,收敛,止痒,使角质再生。用于神经性皮炎,亚急性、慢性皮炎及慢性湿疹等。现行质量标准收载于《卫生部药品标准》中药成方制剂第十二册,标准中只对氧化锌的含量进行了测定,对其主要成分桉油精和冰片并没有含量测定方法。为了更好的控制该制剂的质量,完善其质量标准,采用气相色谱法同时测定制剂中的桉油精和冰片的含量:方法专属性强、灵敏度高、重复性好,从而可有效地控制黑豆馏油软膏的内在质量。 仪器与试药 Aglient 6890N 型气相色谱仪, FID 检测器; SartoriusBP211D、BS224S 电子分析天平; KD500DE 型超声清洗仪。 冰片对照品、桉油精对照品均购自中国食品药品检定研究院,批号分别为:110743-200905(含量以98.0%计)、110788-201004(含量以99.6%计)。黑豆馏油软膏样品由西安康华药业有限公司生产,批号为110804、110805、110806。各原料及阴性对照样品均由西安康华药业有限公司提供。 ( 所用试剂均为分析纯,购买自天津化学试剂有限公司。 ) ( [8] 李永宏,徐 建. GC 法测定痰咳净片中龙脑的含量.安徽医 药,2009,13( 1 2): 1 498-1499. ) ( [9] 吴小英.毛细管气相色谱法测定卡泊三醇中甲酸残留量[.安 徽医药,2012,16(3):308-309. ) ( [10 ] 贾 林,刘菊平,金水铭.气相色谱法测定托吡酯中有机溶剂残 ) 2 含量测定 参照中国药典2010年版一部"及文献报道有关桉油精12-6和冰片的含量测定方法71,确定方法如下。 2.1 色谱条件 Rtx-Wax 毛细管柱(柱长30 m,内径0.25mm,膜厚度为0.25 um);流速为1.5 mL·min,柱温为程序升温:初始温度为60℃,持续7 min,以每分钟15℃的速率升温至140℃,保持5 min;检测器为 FID。理论板数按环己酮峰计算应不低于10000. 2.2 溶液的制备 2.2.1 内标溶液 取环己酮适量,精密称定,加乙酸乙酯制成每1mL含1 mg的溶液,作为内标溶液。 2.2.2 对照品溶液 取冰片对照品8mg、桉油精对照品15mg,精密称定,置10 mL量瓶中,加内标溶液适量使溶解并稀释至刻度,摇匀。 2.2.3 供试品溶液 取本品约2g,精密称定,置具塞锥形瓶中,精密加入内标溶液25 mL,超声处理20 min,摇匀,置冰箱中使基质凝固后滤过,取续滤液放置室温,作为供试品溶液。 ( 留量量.分析测试技术与仪器,2004,10(2):126-128. ) ( [11] 国家药典委员会.中国药典:二部[S].北京:中国医药科技出版 社,2010:附录61-65. ) ( (收稿日期:2012-12-03,修回日期:2013-03-20) ) 北京豫维科技有限公司联系人:水先生电话:18911849923 2.2.4 阴性对照溶液 分别取缺桉油精和缺冰片的阴性样品,按供试品溶液制备方法制成阴性对照溶液。 2.3 阴性干扰试验 取对照品溶液、供试品溶液及阴性对照溶液,按上述色谱条件测定,记录色谱图。结果表明样品色谱中,桉油精和冰片峰与相邻成分峰达到基线分离,且阴性对照无干扰。见图1。 2.4 方法学考察 2.4.1 线性关系考察 精密称取桉油精油照品80.48 mg,冰片对照品42.15 mg,置10 mL量瓶中,加内标溶液使溶解并定容至刻度,摇匀,作为对照品浓溶液。精密吸取浓溶液3mL 置10 mL量瓶中,再精密吸取浓溶液各1mL,分别置于2、5、10、25 mL量瓶中,加内标溶液定容至刻度,摇匀,作为标准曲线系列。精密吸取上述溶液各1 pL注入气相色谱仪,测定。分别以进样量为横坐标,A值(对照品峰面积与内标峰面积的比值)为纵坐标,绘制标准曲线,桉油精回归方程为:Y(A)=1.1348X(进样量) +0.0208,r=0.9999,冰片回归方程为:Y(A)=1.102 5X(进样量)+0.018 1,r=0.999 9,结果表明,桉油精在0.3206~8.0158 pg范围内线性关系良好,冰片在0.1652~4.1307 ug范围内线性关系良好。 图1 对照品(A)、黑豆馏油软膏样品(B)、桉油精阴性对照(C) 及冰片阴性对照(D)GC 图 注:1.桉油精( eucalyptol) ,2.冰片( borneol),3.环己酮( Cyclohexanone)。 2.4.2 精密度试验 按上述色谱条件,精密吸取同一份供试品溶液各1pL,连续进样6次,以A值(对照品峰面积与内标峰面积的比值)计算 RSD(n=6),桉油精为0.69%,冰片为0.50%. 2.4.3 稳定性试验 取同一批供试品溶液(批号为110806),在上述相同色谱条件下分别于0、2、5、9、12、18 h进样测定,以A值(对照品峰面积与内标峰面积的比值)计算RSD(n=6),桉油精为1.7%,冰片为1.2%,结果表明供试品溶液在18h内基本稳定。 2.4.4 重复性试验 取同一批样品(批号为110806)6份,按“2.2.3”项下方法制备供试品溶液,按上述色谱条件进行测定,结果6份样品中桉油精含量平均值(n=6)为17.1 mg *g ,RSD为1.1%;冰片含量平均值( n=6) 为9.3 mg'g:RSD 为1.1%。 2.4.5 回收率试验 取重复性项下已知含量的同一批样品(批号为110806)6份,每份约1g,精密定定,分别精密加入桉油精浓度为2.213 4g·L、冰片浓度为1.037g·L的混合对照品溶液各5 mL,按“2.2.3”项下方法制备供试品溶液;并按上述色谱条件进行测定,计算回收率,桉油精平均回收率(n=6)为98.7% ,RSD 为1.5%;冰片平均回收率(n=6)为98.9%,RSD 为1.6%。 2.5 样品测定 再取不同批号的黑豆馏油软膏(110804和110805),按“2.2.3”项下方法制备供试品溶液,按上述色谱条件进行测定,用外标法测定含量,结果桉油精含量分别为17.0 mgg和16.9 mgg,冰片含量分别为9.4 mgg-1和9.3mg'g 3 讨论 对不同提取方法进行了研究,分别考察了静置过夜,超声提取和振荡提取不同时间对含量结果的影响,结果发现超声处理20 min 得到的含量值最大,故选择此方法作为样品处理方法。 实验发现,软膏基质对色谱柱有较大的损害,如果不除去基质,长时间进样后色谱峰的分离效果会变差,理论板数也会 下降,考虑到冷冻可以除去基质,故将样品冷冻后滤过,放置到室温进行测定,结果发现冷冻后虽然含量值会有所下降,冷冻前后样品中桉油精的含量 RD 为1.7%,冰片为2.2%,但冷冻可以极大的延长色谱柱的寿命,故实验选择了超声后冷冻的方式除去基质。 另外考察了不同厂家的色谱柱(DB-WAX,柱长30 m,内径250 pm,膜厚度0.5 pm) 进行试验,结果分离度良好,样品含量值较稳定,理论板数符合要求,说明方法耐用性良好。 ( 参考文献: ) ( [1] 国家药典委员会.中国药典: :一 一部[S].北京:中国医药科技出版 社,2010:136,389. ) ( [2] 王 棋.气相色谱法测定复方艾叶油乳膏中桉油精含量[.中 国药业,2010,19(3):31 - 32. ) ( 3] 李晓波.野菊花注射液中桉油精、龙脑和樟脑含量测定研究.长春中医药大学学报,2010,26(4):277-278. ) ( [4] 赖东美,胡珊梅,李玲玲. GC法测定万金油中桉油精和丁香酚 的含量[.中国药房,2011,22(13):1211-1212. ) ( [5] 陈海滨,池文杰,黄晓姗.气相色谱法测定风油精中5种成分的含量[.海峡药学,2012,24(3):56-58. ) ( [6] 李罗清.辛苍鼻舒胶囊质量标准研究[].中国药业,2012,21 (16):45-47. ) ( [7] 杨积慧,倪继红.GC 法测定风茄平喘膏中3种成分的含量[. 安徽医药,2010,14(1):45-46. ) ( [8] 汪汝沛,戚 进,余伯阳冰片含量测定方法研究进展[.药学 进展,2010,34(8):359-364. ) ( [9] 吴 芳,樊宝娟,乔蓉霞.气相色谱法鉴别小儿化毒胶囊中冰片、乳香和没药叨.安徽医药,2011,15(11):1356-1357. ) ( [1 0 ] 汪剑飞. GC法测定喉疾灵片中冰片含量的方法研究[.安徽 医药,2011,15(11):1358-1359. ) ( [1 1 ] 谢若男,杨满琴,徐玥玮,等 . 十一味活血酊质量标准研究. 安徽医药,2012,16(6):768-769. ) ( (收稿日期:2012-12-06,修回日期:2013-01-21) ) 网址:: www.yuweichina.com 日邮箱watercom 目的建立黑豆馏油软膏中桉油精和冰片的的定量方法,更好地控制产品质量。方法采用Rtx-WAX毛细管柱(柱长30 m,内径0.25 mm,膜厚度为0.25μm),以环己酮为内标,流速:1.5 mL.min-1,程序升温:初始温度为60℃,持续7 min,以每分钟15℃的速率升温至140℃,保持5 min;FID检测器。结果气相色谱法测定,桉油精在0.320 6~8.015 8μg范围内线性关系良好(r=0.999 9),冰片在0.165 2~4.130 7μg范围内线性关系良好(r=0.999 9);桉油精平均回收率(n=6)为98.7%,RSD=1.5%,冰片平均回收率(n=6)为98.9%,RSD=1.6%。结论该方法能准确地进行桉油精和冰片的定量测定,且灵敏度高,重复性好,快速简便,可用于黑豆馏油软膏的质量控制。
关闭产品配置单
北京豫维科技有限公司为您提供《黑豆馏油软膏中桉油精和冰片的含量检测方案(毛细管柱)》,该方案主要用于中药制剂中含量测定检测,参考标准《暂无》,《黑豆馏油软膏中桉油精和冰片的含量检测方案(毛细管柱)》用到的仪器有null。
