ThermoFisherS CIENTIFIC 韩春霞 赛默飞世尔科技(中国)有限公司 关键词:离子色谱;脉冲安培检测; lonPac AS11; 磺丁基醚-β-环糊精;β-环糊精 流速: 1.00mL/min; 定量环:10pL Key words: IC; PAD;IonPac AS11; Betadex Sulfobutyl Ether Sodium; BetaCyclodextrin 检测方式: Au电极, AgCI参比模式,脉冲安培检测,糖四电位波形,见表1。 引言 结论 磺丁基醚-β-环糊精(SBE-β-CD)是阴离子型高水溶性环糊精衍生物,能很好地与药物分子包合形成非共价复合物,从而提高药物的稳定性、水溶性和安全性,同时具有降低肾毒性、缓和药物溶血性、控制药物释放速率及掩盖不良气味等特性,其在欧美已被批准用作注射剂齐辅料。β-环糊精(β-CD)是SBE-β-CD的合成原料之一,控制其含量对于提高SBE-B-CD的质量有重要意义。 SBE-B-CD样品基体相对简单,干扰较少,易于分离。安培检测器可进一步提高方法的选择性。方法前处理简单,样品水稀释后即可直接进样分析,样品谱图见图1。方法线性良好,灵敏度高,重现性好。 测试条件 仪器: ICS5000系统; 淋洗液:氢氧化钠(NaOH)梯度淋洗,0-4min,25mmol/L NaOH; 5-10min,200mmol/LNaOH; 10.1-15min,25mmol/L NaOH 图1 SBE-B-CD样品分离谱图 表1糖测定的四电位波形 时间(s) 电位(V) 积分 0.000 0.100 0.200 0.100 On 0.400 0.100 Off 0.410 -2.000 0.420 -2.000 0.430 0.600 0.440 -0.100 0.500 -0.100 www.thermoScientific.com C2013 Thermo Fisher Scientific Inc. All rights reserved. ISO is a trademark of the International StandardsOrganization. All other trademarks are the property of Thermo Fisher Scientific Inc. and its subsidiaries. Thisinformation is presented as an example of the capabilities of Thermo Fisher Scientific Inc. products. It is notintended to encourage use of these products in any manners that might infringe the intellectual property rightsof others. Specifications,terms and pricing are subject to change. Not all products are available in all countries.Please consult your local sales representative for details. CE ( Thermo Fisher S cientific, Austin , TX USA i s ISO 9 001:2008 Certified. )
关闭产品配置单
赛默飞色谱与质谱为您提供《磺丁基醚-β-环糊精中β-环糊精检测方案(离子色谱仪)》,该方案主要用于其他中含量测定检测,参考标准《暂无》,《磺丁基醚-β-环糊精中β-环糊精检测方案(离子色谱仪)》用到的仪器有赛默飞戴安ICS-5000+高压离子色谱系统。
