北京豫维科技有限公司联系人:水先生电话:]18911849923分析测试学报FENXI CESHI XUEBAO(Journal of Instrumental Analysis)第29卷第3期2010年3月Vol. 29 No.3220~225 221第3期 大鼠尿液中异丙嗪及其主要代谢物的GC-MS分析 黄克建,朱定姬,李宏森',林翠梧,李 璐,刘晓锋1,2 (1.广西壮族自治区公安厅物证鉴定中心,广西南宁530012; 2.广西大学化学化工学院,广西 南宁530004) 摘 要:采用气相色谱-质谱(GC-MS)分析了大鼠尿液中的异丙嗪及其代谢产物。尿液经β-葡萄糖醛酸酶酶解, Oasis@ HLB 3 mL 固相萃取柱提取后。以 Restek Rtx-5MS(30 mx0.25 mm×0.25 um)石英毛细管色谱柱为分析柱,经GC-MS分离检测。根据质谱图对代谢物的结构进行鉴定。结果表明:在大鼠尿液中检出了吩噻嗪、去甲基异丙嗪、异丙嗪亚砜、2-羟基去甲基甲丙嗪、二羟基异丙嗪、顺-N-(1-丙烯基)吩噻嗪、反-N-(1-丙烯基)吩噻嗪、顺-N-(1-丙烯基)吩噻嗪砂、反-N-(1-丙烯基)吩噻嗪砜、顺-N-(1-丙烯基)吩噻嗪亚砜及反-N-(1-丙烯基)吩噻嗪亚砜11种代谢物。对异丙嗪在大鼠体内的氧化、还原等主要代谢途径进行了讨论。 关键词:异丙嗪;尿液;代谢物;气相色谱-质谱 中图分类号:0657.71; R917 文献标识码:A 文章编号:1004-4957(2010)03-0220-06 doi: 10.3969/j. issn. 1004-4957.2010.03.002 Analysis of Promethazine and Its Metabolites in Rats Urine by GasChromatography -Mass Spectrometry HUANG Ke-jian', ZHU Ding-ji , LI Hong-sen’, LIN Cui-wu, LI Lu’, LIU Xiao-feng (1. Institute of Forensic Science, Public Security Department of Guangxi Zhuang Autonomous Region, Nanning5530012.China; 2. School of Chemistry and Chemical Engineering, Guangxi University, Nanning 530004, China) Abstract: A gas chromatography and mass spectrometrie(GC-MS) method was developed for the a-nalysis of promethazine(PMZ) and its metabolites in wistar rat with the electron ionization(EI) andthe positive chemical ionization(PCI) mode. The sample was hydrolyzed with B-glucuronidase, andextracted by a Oasis@ HLB 3 mL solid phase extraction(SPE). The separation of target compoundswas performed on a Restek Rtx -5 MS(30 m×0.25 mm×0.25um) capillary column. The molecu-lar structures of the metabolites were identified based on their MS spectra. The result indicated thatPMZ and its eleven metabolites, including phenothiazine, desmethylpromethazine, promethazinesulphoxide, 2-hydroxy-desmethylpromethazine, dihydroxypromethazine, cis-N-(1-propenyl)phe-nothiazine, trans-N-(1-propenyl) phenothiazine, cis-N-(1-propenyl) phenothiazine-5-oxide, trans-N-(1-propenyl) phenothiazine-5-oxide, cis-N-(1-propenyl) phenothiazine-5,5-dioxide, trans-N-(1-propenyl) phenothiazine-5, 5-dioxide were found in rat urine. The main metabolic process of PMZ inrat bio-body was also discussed. Key words: promethazine; urine; metabolites; GC-MS 异丙嗪(Promethazine, PMZ),又名非那根、抗胺荨、普鲁米近等,常用于治疗过敏、止吐、镇静、镇痛及哮喘等。1951年被美国食品药品管理局(FDA)批准使用,有糖浆溶液及片状两种,以糖浆溶液较常见。其药性与可待因相似,1952年被 FDA 批准可与可待因联合使用(2)。2003年以来,我国的云南、广东、广西、湖南等地出现了俗称“1+1” “丁丙套装”、“套餐”、、“三合一”、.“丁丁”混合毒品注射滥用的情况,主要是将丁丙嗒啡溶于安定注射液、东莨菪碱注射液或水中,与盐酸异丙 ( 收稿日期:2009-12-04;修回日期:2010-01-20 ) ( 基金项目:公安部应用创新计划资助项目(2007YYCXGXST081);广西壮族自治区公安厅科学研究与技术开发计划资助项目(桂公(科 技)[2005]4号) ) ( 第一作者:黄克建(I969-),男,广西崇左人,高 级 工程师, Tel: 0771-2892352, E -mail: huangke ian911@163. com ) 黄克建等:大鼠尿液中异丙嗪及其主要代谢物的 GC-MS分析 嗪等药物混合注射[3-69。异丙嗪在生物体内易代谢,口服或静脉注射,仅有少于1%的异丙嗪原体通过 尿液排出17-8]。因此,研究异丙嗪在生物体内的代谢,对打击吸食毒品的违法犯罪活动具有重要意义。国内外关于异丙嗪在体内代谢的研究报道较少,大多是异丙嗪及其代谢物检测方法的研究,且报道的代谢物存在差异。文献[9-10]利用高效液相色谱法(HPLC)检测血液、尿液中 PMZ 及异丙嗪亚砜( Promethazine sulphoxide, PMZSO)、去甲基异丙嗪亚砜(Desmethylpromethazine sulphoxide, DMPMZ-SO)、去甲基异丙嗪(Desmethylpromethazine, DMPMZ);文献[11]利用 HPLC 法检测生物检材中的PMZSO、DMPMZ 及去二甲基异丙嗪(Desdimethylpromethazine, DDMPMZ);文献[12-13]利用紫外导数光谱法及超高效液相色谱-质谱检测尿液及动物源食品中 PMZ 及 PMZSO 代谢物;文献[14]用GC-MS 法检测人尿中2-羟基去甲基异丙嗪(2-Hydroxy-desmethylpromethazine,2-HDMPMZ)代谢物。 本文利用 GC -MS 法对大鼠尿液中异丙嗪及其代谢产物进行检测,推测了异丙嗪在大鼠体内的主要代谢产物及代谢途径。 实验部分 1. 1 仪器与试剂 QP 2010气相色谱-质谱联用仪(日本岛津公司),配电子电离轰击源(EI),正化学电离源(PCI);3-18R 高速冷冻离心机(美国 Tomos公司);固相萃取仪(美国 Supelco 公司); Oasis" HLB 3 mL 固相萃取柱(美国 Waters 公司); TTL-DC 型氮吹仪(北京同泰联科技发展有限公司)。 盐酸异丙嗪(公安部物证鉴定中心);异丙嗪亚砜(纯度98%,加拿大 TRC 公司);β-葡萄糖醛酸酶(美国 Sigma 公司, 22 mg, 1 134 600 u/g), 临用时用 pH 4.8的醋酸钠缓冲溶液配制成5000 u/mL;甲醇、异丙醇(美国 Fisher 公司);乙醚、氯仿等其他试剂均为国产分析纯。 1.22 GC-MS测定条件 GC条件:色谱柱: Restek Rtx -5 MS 石英毛细柱(30 m×0.25 mm×0.25 p.m);柱温:初始温度80℃ 保持1 min, 以5℃/min 程序升温至220℃,保持1 min, 再以3℃/min 程序升温至290℃,保持15 min; 进样口温度:280℃;载气(He)流速:1.42mL/min;进样方式:不分流进样;进样量:1 pL。 MS条件:EI源和正化学电离源(PCI);电子能量:70eV;倍增器电压:1.0kV;传输线温度:250℃;离子源温度:200℃;扫描方式:全扫描(SCAN);扫描范围:55~350 u; CI反应气: CH4。 1. 3 样品采集 大鼠空白尿液:取5只Wistar 大鼠,各灌胃7 mL 蒸馏水,收集24h内的尿液,总体积为30 mL。大鼠阳性尿液:取5只Wistar 大鼠,各灌胃7 mL的 0.36 g/L 盐酸异丙嗪水溶液,收集灌胃后24 h 内的尿液,总体积为25 mL。 1.4 样品预处理 取20 mL 阳性大鼠尿液于锥形瓶中,用0.1 mol/L盐酸调至pH6.0, 加入 pH 4.8醋酸钠缓冲溶液5 mL、β-葡萄糖醛酸酶溶液0.5 mL, 摇匀,57℃酶解30 min, 用1 mol/L NaOH 调至 pH9.0, 离心10min(7 000 r/min), 上清液过 Oasis HLB 3 mL 固相萃取小柱(预先用3mL甲醇、3mL超纯水、3 mLpH 9.2的 Tris-HCl缓冲液活化),用3mL 5% 甲醇水溶液淋洗杂质,弃去淋洗液,离心5 min(7 000r/min), 分别用3mL乙醚、3 mL氯仿-异丙醇(体积比9:1)洗脱待测物,合并洗脱液,70℃氮气吹干,残渣用100 u.L甲醇溶解, 供 GC-MS(EI、PCI)检测。同时平行作空白鼠尿。 2 结果与讨论 2. 1(GC-MS分析结果 按“1.2”分析条件对大鼠尿液样本提取物进行 GC-MS(EI、PCI)分析。图1为阳性大鼠尿液的 GC - MS(EI)总离子流图,与空白样本相比,阳性大鼠尿液样本中新增12个色谱峰,分别为 M1~M12,保留时间分别为27.92、28.7529.43、31.77、32.64、35.63、36.34、 图1 阳性大鼠尿液的 GC -MS(EI)总离子流图 Fig. 1 GC-MS(EI) total ion currentchromatogram of positive rat urine 36.53、37.92、38.07、39.12、39.84 min,质谱图见图2。在PCI分析模式下给出M1~M 12的相对分子质量分别为199、239、239、270、284、255、271、255、271、286、300、316。 取0.5 mL 0.36 g/L 盐酸异丙夜水溶液,按照“1.4”方法进行提取, GC -MS检测,从提取物中检出异丙嗪,未检出异丙嗪代谢物。 图2 异丙嗪及其代谢物的 GC-MS(EI)质谱图 Fig.22GGC -MS(EI) spectra of promethazine(PMZ) and its metabolites 2.2 大鼠尿液中异丙嗪及其代谢物的鉴定 通过 NIST 质谱库检索,确定M5为原形药物异丙嗪(相似度为97%),其结构式和质谱碎裂方式见图3。异丙嗪的分子离子峰为 m/z 284,失去中性碎片N, N-二甲基-乙烯胺后形成碎片离子 m/z 213,再失去甲基形成碎片离子 m/z 198,接着失去中性碎片S后,形成m/z 166;碎片离子m/z 213 失去 H后,形成碎片离子 m/z 212;碎片离子 m/z212进一步失去S,形成碎片离子 m/z 180; m/z 72为N, N-二甲基-乙胺基碎片离子。 M4的保留时间为31.77 min, m/z 270 为分子离子峰,与异丙嗪原形药的分子离子峰 m/z 284 相差14u;与异丙嗪相比,少了 m/z 72碎片峰,增加了N-甲基乙胺 m/z58碎片离子,其余主要碎片离子与异丙嗪相同,推测M4为去甲基异丙嗪。其结构式和质谱碎裂方式见图4。 图3 异丙嗪的质谱碎裂方式 Fig. 3FFragmentation patterns of PMZ 图4 M4的结构式与质谱碎裂方式 Fig.4 Structure and fragmentation patterns of M 4 M 11 的保留时间为 39.12 min, m/z 300 为分子离子峰,与异丙嗪分子离子峰 m/z 284 相差16u,多1个氧原子,推测为异丙嗪的氧化代谢产物,与异丙嗪亚砜对照,其保留时间和EI质谱图与异丙嗪亚砜基本吻合,因此推测 M 11 为异丙嗪亚砜。其结构式和质谱碎裂方式见图5。 图5 M 11 的结构式与质谱碎裂方式 Fig. 5 Structure and fragmentation patterns of M 11 M 10的保留时间为38.07 min, 通过谱库检索确定为2-羟基去甲基异丙嗪,其结构式和质谱碎裂方式见图6。 M 12的保留时间为 39.84 min, m/z 316 为分子离子峰,与异丙嗪分子离子峰 m/z 284 相差 32 u,多2个氧原子,且El 质谱图中存在 m/z 72碎片离子,不存在[M-16]和[M-32]碎片离子,推测为异 丙嗪的二羟基代谢物。 逐6 M 10的结构式与质谱碎裂方式 Fig.6 Structure and fragmentation patterns of M 10 M1的保留时间为27.92 min, 通过谱库检索确定为吩噻嗪。 M2及M3的保留时间分别为28.75、29.43 min,分子离子峰均为 m/z239,比吩噻嗪分子离子峰m/z 199 多 40 u, EI质谱图中均存在与吩噻嗪相同的 m/z 127、154、166(167)、198(199)碎片离子,还存在m/z239、223、180碎片离子,推断M2和M3为一对N-(1-丙烯基)吩噻嗪顺反异构体。其结构式和质谱碎裂方式见图7。 图7 M2与M3的结构式及质谱碎裂方式 Fig. 7Structure and fragmentation patterns of M 2 and M 3 M6和M8的保留时间分别为35.63、36.53 min, 分子离子峰均为 m/z 255, 比M2、M3的分子离子峰 m/z 239 多16 u, 即多1个氧原子,且存在[M-16]碎片离子,其余碎片离子与M2、M3相同,推断M6及M8为一对N-(1-丙烯基)吩噻嗪亚砜顺反异构体。 M7及M9的保留时间分别为36.34、37.92 min,分子离子峰均为 m/z 271,比 M6和M8的分子离子峰 m/z 255 多16u,推断M7和M9为一对N-(1-丙烯基)吩噻嗪砜顺反异构体。 2.3讨 论 异丙嗪在大鼠体内易代谢,尿液中主要以代谢物形式存在,除检出己有文献报道的异丙嗪亚砜19-13、去甲基异丙嗪19-11.和2-羟基去甲基异丙嗪114)3个主要代谢产物外,还检出N-(1-丙烯基)吩噻嗪顺反异构体、N-(1-丙烯基)吩噻嗪亚砜顺反异构体、N-(1-丙烯基)吩噻嗪砜顺反异体和异丙嗪二羟基代谢物,未检出文献[11]报道的去甲基异丙嗪亚砜19-101和去二甲基异丙嗪代谢物。根据实验结果,推测异丙嗪在大鼠体内的主要代谢途径见图8。 黄克建等:大鼠尿液中中丙嗪及其主要代谢物的 GC-MS分析 图8 异丙嗪在大鼠体内的主要代谢途径示意图 Fig.8 Main metabolic passway of PMZ in rat ( 参考文献: ) ( [1] WEIL A J. Exfoliative dermatitis after medication w ith methylpheni-date H C1(ritalin)[J]. An n Allergy, 1968, 26(8) : 402-404. ) ( [2] STARKE P R, WE A VER J, CHOWD H URY B A. Boxed warning added to promethazine labeling for pediatric use[J ] .N Engl J Med, 2005, 352(25):2653. ) ( [3] 周旭辉,黄劲松,张登科,等.静脉注射丁丙诺啡舌下片合并东莨菪碱、异丙嗪注射液成瘾一例[J].中国药物依赖性杂志,2007,16(5): 400. ) ( [4] 周旭辉,张登科,邓慧琼,等.丁丙诺啡舌下片合并东莨菪碱、异丙嗪静脉注射对认知功能的影响[J].中国药物依赖性杂志,2006, 15(2):35-39. ) ( [5] 张登科,周旭辉,张雪辉,等.长沙市丁丙诺啡、东莨菪碱、异丙嗪等混合滥用情况调查[J].中国药物依赖性 杂志,2006, 1 5(1):53-56. ) ( [6] 白丽琴,王继望,傅文,等.云南省丁丙诺啡片与安定、盐酸异丙嗪等多种药物混合滥用的潜力分析[J].中国 药物依赖性杂志,2009,18(3):215-219. ) ( [7] DIGREGORIO GJ, RUCH E. Human w h ole blood and parotid saliva concentrations of oral and intramuscular prometha-zine[J]. J Pharm Sci , 1980 , 69(12):1457-1459. ) ( 81 TAYLOR G, HO U STON JB, SHAFFE R J, et al. P h armac o kinetics of promethazine and its sulphoxide metabolite a f terintravenous and oral administration to man[J]. Br J Clin Pharmacol, 1983, 15(3):287-293. ) ( 97 S ONG Q, PU T CHA L. Quantitation of promethazine and m e tab o lites in urine samples usin g on-line solid-phase extractionand column-switching[J] . J Chromatogr: B, 2001, 763(1/2):9-20. ) ( 10] VANAPALLI SR, K AMBHAMPATI S P, PUTCHA L, et al. A liquid c hromatographic method for the simultaneous de- termination of promethazine a nd t hree o f i ts metabolites in plasma using electrochemical and UV detectors[ J ]. J C h roma- togr Sci, 2001, 39(2) : 70-72. ) ( [11] ALLENDER WJ, ARCHE R A W. Li q uid c hr omatographic analysis of promethazine and its ma j or metabolites in humanpostmortem materia l [J]. J Forensic Sci,198 4 ,29(2): 5 15-52 6 . ) ( [121 吴玉红,开丽梅,许英键.尿中异丙嗪及其代谢物含量硅藻土萃取紫外导数光谱测定法[J].中国法医学杂志, 2008,23(2):89-91. ) ( [13] 齐士林,吴敏,严丽娟,等.超高效液相色谱-质谱对动物源食品中氯丙嗪、异丙嗪及其代谢物的测定[J].分 析测试学报,2009,28(6):677-681. ) ( [14] 宋鸣,黄志刚,刘新江.尿中异丙嗪代谢产物的测定及质谱解析[J].中国卫生检验杂志,2006,16(1): 69, 93. ) 网www. yuweichina. com.邮箱watercom
关闭还剩4页未读,是否继续阅读?
北京豫维科技有限公司为您提供《大鼠尿液中异丙嗪及其主要代谢物检测方案(毛细管柱)》,该方案主要用于尿液中异丙嗪及其主要代谢物检测,参考标准《暂无》,《大鼠尿液中异丙嗪及其主要代谢物检测方案(毛细管柱)》用到的仪器有null。
