APPLICATION NOTEF&F-0-002-2014/A1 OXIDATION STABILITYOF LEATHER Oxidation Stability of Leather Reference:EURACHEM GUIDELINES Tested with VELP Scientifica OXITEST Oxidation Stability Reactor (Code F30900248) Introduction “Lord God made leather clothing from animal skins for Adam and his wife" Genesis 3:21 The production of leather goes back to prehistoric times, when primitive men soon realized that they could use the skinof animals hunted for food, in order to protect themselves from the weather. They used different treating methods thathave remained largely unchanged for centuries, exposing it to the smoke or putting it in contact with water or leaves.Nowadays, the leather manufacture is usually divided into three processes: preparatory stages, tanning and crusting.During the process of tanning, fat is dissolved from the animal skin. These small quantities of oil, known as fat liquors,make a significant difference to the handle, i.e. the fullness, softness and flexibility, among other factors. Oxidation Stability in Leather This work is aimed to evaluate the effect of adding an antioxidant treatment on leather, comparing the oxidation stabilityof leather with and without the addition of antioxidant agent. OXITEST is able to determine the oxidation stability ofvarious sample types,directly on the whole sample, without any fat separation. OXITEST Principle OXITEST speeds up the oxidation process because of the two accelerating factors, temperature and oxygen pressure,according to the most common applications. The instrument measures the absolute pressure change inside the two chambers, monitoring the oxygen uptake byreactive components in the sample and automatically generates an IP value. IP Definition: IP stands for Induction Period and it is the time required to reach the starting point of oxidation, corresponding to either alevel of detectable rancidity or a sudden change in the rate of oxidation. The longer the Induction Period, the higher the stabilityagainst oxidation over time. Sample Leather sample 1: without antioxidant treatment Leather sample 2: with antioxidant treatment Equipment and Chemicals · Analytical balance, 3 decimals e Oxygen, purity grade 5.0 ●SSilicone grease Sample Preparation Store the samples at room temperature. In order to homogenize the sample, cut leather tissues in small pieces (5x5 mm) and put 10 grams of sample directly onthe surface of the titanium sample holder, by using a spatula. In each reaction chamber (A and B), place one spacer and 2 sample holders containing the sample for a total of 20 g,leather pieces in each oxidation chamber. Analysis Procedure Grease the O-rings with silicon grease and set them in their position. Close the chambers with the titanium covers andturn the discharge valves in open position. Set the following conditions on the OXISoft TM software: Temperature: 80°C Oxygen Pressure: 6 bars When the temperature set is reached inside the chambers, close the discharge valves and start loading oxygen.Data acquisition is automatically started by the software. Typical Results on Leather Each sample has been monitored two times. At the end of the oxidation tests, the IP of every run is calculated by thesoftware OXISoftTM. It is possible to elaborate the oxidation curves obtained for each kind of leather. Sample Weight (g) Set Point (bars) Set Point (°C) IP (hh:mm) Line Leather 1 20.012 6.00 80.0 00:49 Leather 1 20.005 6.00 80.0 00:49 Leather 2 20.010 6.00 80.0 24:28 Leather 2 20.004 6.00 80.0 24:33 Repeatability Test With OXISoftM, it is possible to create a repeatability test for each analysis, in order to obtain the average, standarddeviation and relative standard deviation of the results. For repeatability test, it is necessary to analyze the same quantity of the sample in duplicate or more, at the same valuesof temperature and pressure. In the table below the results are summarized: Sample IP average (hh:mm) SD (hh:mm) RSD % Leather 1 00:49 0:00 0.0 Leather 2 24:30 0:03 0.2 RSD value must be<5% in order to obtain good results. Formula Comparison With OXISoftTM, it is also possible to easily compare the obtained IP values, of different formulations but tested at thesame condition, and identify the most stable one. Leather 1 Leather 2 Conclusion The results obtained by OXISoftTM and the formula comparison function clearly discriminate the leather tissuesresistance to oxidation: Leather 1 (without antioxidant treatment) has a shorter IP value, hence a lower oxidationstability. In conclusion, the use of antioxidant agent increases the oxidation stability of leather tissue. Benefits of OXITEST are: Test is made directly on the whole sample No need for preliminary fat separation of the sample Resistant titanium chamber ● Time saving analysis, if compared to the traditional methods Especially designed for R&D, Product Development and Quality Control labs Many investigations available through the software OXISoftTM: 1. Repeatability test: a series of tests run on the same sample or standard to verify its IP period, to calculateaccuracy and repeatability of the data 2. Freshness test: to verify the quality of different lots, for example of the same raw material, and comparethem, for the evaluation of raw materials and suppliers. 3. Formula comparison: to identify the most stable formula of a finished product, under the same conditions; andfor the evaluation of the effectiveness of antioxidant treatments. 4. Packaging comparison: for testing which packaging maintains the product in the freshest condition, and forthe evaluation of the adequacy of storage conditions. 5. IP during ageing: to obtain a graph of the decrease of the product IP during the shelf-life period 6. Estimated shelf life: to have a prediction of oxidation stability during the shelf life. Copyright C VELP Scientifica. All rights reserved.No part of this publication may be reproduced or transmitted in any form or for any purpose without the express permission of VELP.VELP Scientifica, Italy Tel: + Fax: + www.velp.com 可以对皮革直接进行氧化稳定性分析
关闭还剩2页未读,是否继续阅读?
意大利VELP公司为您提供《皮革中氧化稳定性检测方案(氧化分析仪)》,该方案主要用于皮革/毛皮/箱/包中氧化稳定性检测,参考标准《暂无》,《皮革中氧化稳定性检测方案(氧化分析仪)》用到的仪器有VELP Oxitest 油脂氧化分析仪。
