<< Titration result >> Sample No. 09-03 Date 2017/09/13 18:33:01 Sample No. 09-03 Date 2017/09/13 18:33:01 Model MKC-710(MCU-710) Time 00:06:08 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 74 mg Catholyte Reagent Name Catholyte Catholyte Life Value 74 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Cell type 2-Comp. Option Off Oven temp. --- Deg.C Pre-Treat Back purge s Cell purge Sample purge -s Calc.No. Sample name H2O Sample ID Size(Size) 0.0100g Size(Wt1) 0.0100 Size(Wt2) 0.0000 g Blank (Blank) 0.0000 Revision Coef. (FA ) 1.00000 Dissolve Samp. ( Wt0) g Conc.of Solvent ( A ) -.---- ppm Dissolve Solvent(B) g Samp.Volume(V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) L Samp.Gas Temp. (Temp.) Deg.C Recalculation comment [Result1 Conc. 10053.6000u Moisture 10053.6 Drift 0.25 ug/s Evaluation OK Standard Value±Acceptance: 10000.0000±200.0000 Detection temp. ---Deg.C Detection temp. ---Deg.C [Titration Curvel << Titration result >> Sample No. 09-04 Date 2017/09/13 18:40:21 Model MKC-710(MCU-710) Time 00:06:28 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 4 mg Catholyte Reagent Name Catholyte Catholyte Life Value 84 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Cell type 2-Comp. Option Off Oven temp. --- Deg.C Pre-Treat Back purge Cell purge Sample purge -s Calc.No. Sample name H2O Sample ID Size(Size) 0.0100g Size(Wtl) 0.0100g Size(Wt2) 0.0000 g Blank (Blank) 0.0000ug Revision Coef. (FA ) 1.00000 Dissolve Samp. ( Wt0) g Conc.of Solvent ( A ) -------ppm Dissolve Solvent(B) g Samp.Volume(V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) L Samp.Gas Temp. (Temp.) Deg.C Recalculation comment [Result] Conc. 10088.1000u Moisture 10088.1 Drift 0.26 ug/s Evaluation OK Standard Value±Acceptance: 10000.0000±200.0000 Detection temp. ---Deg.C Detection temp. ---Deg.C [Titration Curvel 都电子工业株式会社-可睦电子(上海)商贸有限公司电话: 电邮: kemu-kem@com上海市徐汇区宜山路网址: http://www.kem-china.com 卡尔费休库仑滴定仪测定10μL的纯水 使用京都电子(KEM)-卡尔费休库仑滴定仪(MKC-710S),依据GB/T 11133标准方法,测定10μL纯水的应用资料。 GB/T 11133-2015 石油产品、润滑油和添加剂中水含量的测定 卡尔费休库仑滴定法 9 校准与标准化从理论上来说,此方法是不需要进行标准化的,因为根据计量学和卡尔费休反应原理,滴定出的水的量与消耗的库仑电量成直接比例关系。然而,实际操作中随着测试次数的增加,试剂的性能会有所降低。通过注入已知量(测试样品水含量范围的典型值)的纯水,如10000μg或10μL,可定期监测试剂的性能。监测间隔可在初次测定采用新试剂时,及以后每十次测定后进行。 10.3 当发生以下的情况时,更换电解液并按第8章的步骤重新准备仪器。10.3.6 注入10μL纯水样品的测量结果超出10000μg士200μg的范围。
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《纯水中校准与标准化检测方案(卡氏水分测定)》,该方案主要用于其他中校准与标准化检测,参考标准《暂无》,《纯水中校准与标准化检测方案(卡氏水分测定)》用到的仪器有MKC-710S豪华型库仑法卡尔费休水分仪、库仑法卡尔费休试剂。
