第36卷 第5期Vol.36 No.52006年10月Oct. 2006山 东 大 学 学 报 (工 学 版)JOURNAL OF SHANDONG UNIVERSITY (ENGNEERING SCIENCE) 第5期121丁原菊,等:毛细管电泳法对柴胡中柴胡皂甙a与d对映体的分离和测定 文章编号:1672-3961(2006)05-0120-05 毛细管电泳法对柴胡中柴胡皂甙a与d对映体的分离和测定 丁原菊,陆玮洁,主沉浮,高建军,贾(山东大学 化学与化工学院,山东 济南 250100) 摘要:利用环糊精衍生物2-O丙酮基-2-0羟丙基-环糊精(2-AHP-β-CD)作为手性选择剂,提出了一种毛细管电泳快速分离、测定柴胡中柴胡皂甙a,d对映体的方法.考察了手性选择剂浓度、缓冲液浓度及其pH值对分离效果的影响,确定了最佳分离条件.结果表明,在214nm检测波长处,在硼砂缓冲溶液中,2-AHP-B-CD能使柴胡皂甙a ,d异构体在7 min 内得到分离.利用该法测定了柴胡中柴胡皂甙a,d的含量,并进一步研究了方法的线性范围、检测限及精密度. 关键词:柴胡;柴胡皂甙;环糊精衍生物;毛细管电泳 中图分类号:O657.8 文献标识码:A Separation and determination of saikosaponin isomer a and d inBupleurum by capillary zone electrophoresis DING Yuanju, LU Wei-jie, ZHU Chenfu,GAO Jian-jun, JIA Jiong (School of Chemistry and Chemical Engineering, Shandong University, Jinan 250100,China) Abstract: A fast capillary zone electrophoresis (CZE) method was developed for the separation and determina-tion of saikosaponin a and d isomer in the Chinese herbal extract in Bupleurum. A highly water soluble cyclo-dextrin (CD) derivative 2-0-Acetonyl-2-O-hydroxypropyl-B-CD (2-AHP-B-CD) was tested as an effectivechiral selector for the capillary zone electrophoretic resolution of saikosaponin a and disomer. Detection at 214nm with a system containing sodium borate buffer and 2-AHP-B-CD is found to be the most suitable approachfor this analysis. The chiral resolution is strongly influenced by the concentration of the 2-AHP-B-CD, the concentration of buffer and buffer pH. The compounds studied can be enantiomerically resolved in less than 7 minutes with no capillary treatment. Furthermore , the linearity range, quantitation limit for the crude drug extractin Bupleurum and the precision of the measurements were determined. Key words: saikosaponins; Bupleurum;B-Cyclodextrin derivative ; capillary zone electrophoresis 0 引言 柴胡为著名传统中药,具有表和里、疏肝解郁等功效,在我国已有二千多年的应用历史.柴胡的主要成分为柴胡皂甙,其中柴胡皂甙a,d对映体具有抗 炎、保肝、降低血中胆固醇等药理活性.关于柴胡皂甙a,d的分离测定,文献报道的方法有比色法液滴逆流层析法薄层扫描法“等.这些方法操作比较繁琐,准确度和精密度也不够高.高效液相色谱法分离测定柴胡皂甙的报道亦有出现,但这类方法所用试剂价格较高或使用有机溶剂较多,对环境影 ( 收稿日期:2005-12-02 ) ( 作者简介:丁原菊(1952-),女,山东临沂人,大学毕业,高级工程师,主要研究方向为高分子化学. ) 响较大15.6】;而且分离时间较长(大约30 min).有的应用示差折光检测,方法仍不够简便.高效毛细管电泳(high performance capillary electrophoresis,HPCE)是近十几年迅速发展起来的一种新型分离分析技术,具有分离效率高、分析速度快分离模式多、所需样品少、应用范围广、自动化程度高的特点18~111.在生命科学、生物技术、医学药物和环境科学等领域显示了极其重要的应用前景,目前正广泛应用于天然药物的研究之中.笔者以环糊精及其衍生物作为手性选择剂12~151,利用毛细管电泳法对柴胡中的皂甙a,d进行了分离测定,结果表明该法具有快速、简便,且消耗试剂少,不污染环境的特点,具有一定的优越性. 1 试验 1.1 仪器 RE-100型旋转薄膜蒸发仪(上海亚荣生化仪器厂) ,ACS 2000 高效毛细管电泳仪(北京彩陆科学仪器有限公司),pHS-25型酸度计(上海雷磁仪器厂),石英毛细管60 cm X50 um(i.d.),有效长度为50 cm(河北永年光导纤维厂),0.45 um纤维素脂膜(上海市新亚净化器件厂). 1.2 试剂与药品 柴胡皂甙a,d(批号:SKH050317)从成都思科华生物技术有限公司购买,均为含量测定对照品,其结构式如图1所示. 柴胡皂甙a:R—Gc-Fuc →; R22·——CHOH; R3 -B-OH.柴胡皂甙d:R,——GcFuc→:R2——CHOH;R :—6-OH. 图1 柴胡皂甙a、d结构式 Fig.1 Molecular structure of saikosaponins 环糊精衍生物:2-丙酮基-2-羟基基环糊精衍生物(2-AHP-B-CD)由实验室自己合成.结构式如图2所示. 图 2 2-O丙酮基-2-O羟丙基环糊精衍生物结构式 Fig.2 Molecular structure of 2-AHP-B-CD 式中,7-n与m分别为相应的丙酮基与羟丙基的平均取代度.n和m值由反应物比例控制并通过HNMR测定(产物为n=4.8,m=1). 硼砂 (Na4B207)、硼酸(HBO4)、氢氧化钠(NaOH)、无水乙醇均为分析纯试剂;pH缓冲溶液由0.1mol/L 硼酸或0.1 mol/L 氢氧化钠溶液调节;水为二次蒸馏水. 1.3 标准溶液的配制 将柴胡皂甙a,d标准品分别用乙醇配成质量浓度1mg/mL的标准溶液,使用过程中用二次蒸馏水稀释为所需浓度. 精密称定柴胡生药粉末(过60目筛)1.0000 g(产地:山东;购自山东中医药大学药材仓库),放入50mL三角烧瓶中,加入20mL乙醇(内含0.5%吡啶,防止柴胡皂甙a,d在提取过程中发生酸性水解),至超声波振荡器中萃取1h.重复萃取3次,合并萃取液,并用旋转薄膜蒸发仪浓缩至3mL左右,至5mL容量瓶中定容.在进样前用0.45 um纤维素脂膜过滤. 1.5 实验方法 毛细管在使用之前用1ml/L的 NaOH溶液充 满放置1h,然后用二次蒸馏水洗5 min. 2 次运行之间依次用0.5mol/L的 NaOH溶液洗 2 min,二次蒸馏水水洗2 min,背景电解质洗2min.所用溶液均经0.45 um纤维素脂膜过滤,采用电动进样,在20kV进样5s,分离电压为20kV,检测波长214 nm. 2 结果与讨论 2.1 手性选择剂2-AHP-B-CD浓度对分离度的影响 从图1中可以看到,柴胡皂甙a,d为一对对映体,用本实验室合成的2-AHP-B-CD 作为手性选择剂,考察了其浓度对柴胡皂甙a和d分离度的影响,结果见图3. 图3 2-AHP-B-CD浓度对分离度的影响 Fig.3 Effects of 2-AHP-B-CD concentration on the resolution 电泳条件:硼砂浓度:40 mmol/L;缓冲液pH值:8.0;分离电压:20kV;电动进样:5s;温度:22℃;紫外波长:214 nm. 由图3可以看到,当2-AHP-B-CD的浓度小于5 mmol/L时,柴胡皂甙类化合物的分离度随着2-AHP-B-CD的浓度增加而增大;当2-AHP-B-CD的浓度大于5mmol/L时,柴胡皂甙类化合物的分离度随着2-AHP-B-CD 的浓度增加而降低,由此可知,2-AHP-B-CD的浓度为5 mmol/L时最为合适. 2.2 缓冲液 pH值的影响 缓冲液pH值影响待分离物质的电荷及电渗流,是影响手性分离的重要参数之一.由于柴胡皂甙在酸性条件下水解,因此考察了pH值在8.0~10.0时的影响.实验结果如图4. 电泳条件:硼砂浓度:40 mmol/L;2-AHP-B-CD的浓度为5 mmol/L;分离电压:20kV;电动进样:5s;温度:22℃;紫外波长:214 nm. 实验结果表明,随pH值的增大,皂甙类化合物的分离度降低,所以pH值=8.0时为最佳选择. 图4 pH值对分离度的影响 Fig. 4 Effects of pH on the resolution 2.3 硼砂浓度对分离度的影响 固定pH值为8.0和浓度为 5 mmol/L手性选择剂浓度不变,改变硼砂浓度考察其对分离度的影响.实验结果如图5. 图5 硼砂的浓度对分离度的影响 Fig.5 Effects of borate concentration on the resolution 电泳条件:缓冲液pH 值:8.0;2-AHP-B-CD 浓度:5 mmol/L;分离电压:20kV,电动进样:20 kV/5s;温度:22℃;检测波长:214nm 实验证明,柴胡皂甙类化合物的分离度随硼砂浓度的增大而增大,峰型变得较为对称,拖尾减少.考虑到在较大缓冲液浓度时,电流值较大,选用硼砂浓度 40 mmol/L 作为分离条件. 2.4 分离电压 加大毛细管柱两端的电泳电压能够缩短分析时间,但当电压增加到一定程度时,焦耳热不易散发,使缓冲溶液粘度降低,迁移率增加,柴胡皂甙类化合物的分离度下降.另外电泳电压加大后,还会使仪器的噪音明显增大.综合考虑,本实验选用20 kV的电泳电压,既能使柴胡皂甙类化合物有较好的分离度和较快的迁移时间,又保持了仪器的低噪音. 2.5 标准品与样品的分离图谱 在前面讨论的最佳电泳条件下,柴胡皂甙a,d的分离谱图如图6所示.图6分别为标准品的分离 图谱和样品的分离图谱(标准溶液样品质量浓度为1mg/ml). 0.15 0.10 0.05 www4 0.00 3.0 8.0 0.15- 0.10 0.05 0.00 3.0 4.0 5.0 6.0 7.0 8.0 t/min (b) 样品(Sample) 图6 标准品和样品的电泳图谱 Fig.6 The electropherograms of the standards mixture solutionand the real samples 电泳条件:缓冲液pH值8.0;2-AHP-B-CD浓度:5 mmol/L;硼砂浓度:40 mmol/L;分离电压:20kV;电动进样:20 kV/5 s;温度:22℃;检测波长:214 nm 2.6 线性实验 分别精密量取柴胡皂甙a,d标准溶液各1mL,逐级稀释,制成一系列浓度的溶液,在最佳分离条件下,测定其出峰面积.并以峰面积为纵坐标,浓度为横坐标,进行线性回归,结果如表1所示. 表1 线性回归实验结果 Tab. 1 The results of regression analysis on calibration curvesand the detection and the detection limits 回归方程 相关 样品 y=a+bx 系数 柴胡皂甙d y=4.973+8.010x 0.9994 线性范围 检测限 /(ugml )/(ug ml 50~1000 25 柴胡皂甙a y=6.004+5.215x0.9996 50~1000 25 2.7 重现性和精密度实验 重复进样6次,迁移时间和峰面积的标准偏差分别在1.1%~2.1%和2.6%~4.5%范围内.采用标准加入法测定,柴胡皂甙a和d的回收率范围为97.1%~100.9%. 用高效毛细管电泳(HPCE)和高效液相色谱法(HPLC)在最佳实验条件下,对市售柴胡样品中柴胡皂甙的含量进行了测定,其分离谱图如图6(b)所示.测定结果如表2.由表2可以看出,用两种方法测定的结果基本一致. 表2 柴胡皂甙含量测定结果 Tab. 2 Contents of two flavonoids in the herbal plant ofBupleurum(n=6) 方法 样品 含量/% RSD/% HPLC 柴胡皂甙d 0.50 2.7 柴胡皂甙a 0.78 4.2 HPCE 柴胡皂甙d 0.56 3.9 柴胡皂甙a 0.71 3.4 3 结论 用 2-AHP-B-CD 作为手性选择剂,利用毛细管电泳法对柴胡中的柴胡皂甙a,d对映体进行了分离和测定.实验结果表明,在最佳实验条件下,二者得到了基线分离.该方法具有快速、简便等特点,亦可用于其它天然药物的研究. ( 参考文献: ) ( [1]张本.柴胡属植物药理作用研究概况[J].吉林中医药, 1983,(1) : 39-41. ZHANG Ben. Bup l eurum plant pharmacological act i on research survey[J ]. J Traditional Chinese M edicine and C h inese MateriaMedica o f Jilin, 1983, (1) : 39-41 . ) ( [2]赤昭,香川清水.柴胡工牛入中 工saikosaponin 定量(第 1 报) Saikosaponin0比色定量法[J].生药学杂志(日), 1974 ,28(2) : 116-121. ) ( [3] H IDEOKI OTSUKA , SHIGEO KOBOYSHI, S HOJI SHIBATA.Separation and determination of saikosaponin of Bupleurum ra dix by drupler counter current chromatography (DCC) [ J ]. Plant Medica , 1978 , 33(2):152-159. ) ( [4]罗燕,林明美.柴胡皂甙薄层扫描定量法[J].药物分析 杂志,1987,7(2):104-105.LUO Yan, L IN Ming mei. The determination of saikosaponin inBupleurum by thin layer scanning m e thod[J]. C hi n ese Journalof Pharmaceutical A nalysis, 1987 , 7(2) :104-105. ) ( [5]董友毅,潘胜利.柴胡主要皂甙成分的高效液相色谱测 定[J].中国中药杂志,1989,14(11): 39-41.DONG You yi, P A N She n g-li. The det e rmination of the mainsaikosaponin ingredient in Bupleurum b y high effective l iquid chromatography method[J ]. C hina J ournal of Chinese Materia Medica, 1 989, 14(11):39-41. ) ( [6]马林,何丽一,宋万志,等.柴胡皂甙的高效液相色谱分 离与测定[J].药 物 分析杂志,1994,14(2):6-8. ) ( MA Lin, H E Liryi, SONG W a r zhi, et al. H PLC determinar tion of saikosaponin [J ]. C hinese Journal o f PharmaceuticalAnalysis, 1994, 14(2):6-8. ) ( [7 ] KOJI SHIMIZU, SAKAE AMAGAYA, YUKIO OGIBARA.Separation a nd quantitative a nalysis of saikosaponin by hi g lr performance liquid chromatography [J]. J Chromatogr A, 1983, 2 68(1):85-91. ) ( [8 ] G G U BITZ, M G SCH M ID. Chiral sep a ration by chromatographic and electro migration techniques: A review[ J ] . Biopharm Drug Dispos, 2 001,2 2 (7-8):291-336. ) ( [9]I RAQUEL R ODR GUEZ DE P ABLOS, CARMEN GARCA- RUIZ, ANTONIO L CR E GO, et a l . Sep a ration of etodolac enantiomers by capillary e lectrophoresis. Validation a nd applircation of the chiral method t o t he analysis o f commercial for mulations[J]. E l ectrophoresis , 2005 , 26:11061113. ) ( [10] CHANKVETADZE B, BLA S CHKE G. En a ntioseparations incapillary electro migration techniques: r ecent developinents and future trends [ J ] . J Chromatogr A, 2 001, 906(1- 2 ): 309-363. ) ( [11] RAN KAFRI, DORON LANCET. Probability rule for ch i ral recognition[J]. Chirality , 2004, 16:369-378. ) (上接第119 页) 的非线性动力学方程,利用Poincar e映射图和全局分岔图分析了系系统的混沌行为,利用不动点定理分析了混沌控制后的距离空间结构与控制前的距离空间结构之间的关系,从理论角度分析了混沌控制的机理. (2)针对 Jeffcott 碰摩转子系统中混沌行为,构造几种特殊的压缩映射,利用数值分析方法实现了对该系统的有效控制. ( 参考文献: ) ( [1]褚福磊,张正松,冯冠平.碰摩转子系统的混沌特性 [].清华大学学报(自然科学版),1996,36(7):52-57. CHU F u rlei, ZHANG Zheng song, F E NG Guarrping. Chaotic behavior of a rub r otor model[J ]. J ournal of Tinghua University (Sci & Tech), 1996, 36(7):52-57. ) ( [2]褚福磊,汤晓瑛,唐云.碰摩转子系统的稳定性[J].清 华大学学报(自然科学版),2000,40(4):119-123.CHU F u rlei, T ANG Xiao ying, TANG Yu n . St a bility of a rub ) ( [ 1 2 ] LIN Xiurl i , ZHU Cherfu , HAO Ai-you. E v aluation of newlysynthesized derivative of cyclodextrin f o r the c a pillary electror phoretic separation[J ] . J Chromatogr A, 2004,1 0 59,181189. ) ( [13]魏云鹤,林秀丽,马小隆,等.洛贝林对映体的毛细管区 带电泳法拆分[J].山东大学学报(工学版),2004,34 (1) : 104-106. WEI Y u nrhe,L I N Xiurli , MA Xiao-long, et al. Th e enantio meric s eparation o f Lobeline b y capillary zone el e ctrophoresis[J]. Journal of Shandong University ( E ngineering S cience), 2004,34(1):104-106. ) ( [ 1 4] Z HU C h enfu, LI N Xiuli, WEI Yunrhe. Chiral separation of pemoline enantiomers by cyclodextrin modified mi c ellar ca p il- lary chromatography[J]. J ournal o f Pharm B i o A n al, 20 0 2 , 30:293-298. ) ( [ 1 5] L IN Xiurli, ZH U Cherrfu, H A O Ai-you. En a ntiomeric se p a-rations of some acidic compounds with c ationic cyclodextrin bycapillary electrophoresis[J ] . Ana l Chim Acta, 2004,517(1-2) : 95-101. ) ( (编辑:许力琴) ) ( impact r otor system[J ] . Journal of Tinghua U niversity (Sci & Tech) , 2000, 40(4):119-1 2 3. ) ( [3] R UDIGER SEYDEL. Pract i cal bifurcation and stability analysis[M]. G e rmany: Springer verlag , 1994.256-260. ) ( [4]许天周.应用泛函分析[M].北京:科学出版社,2001. 74-78.XU Tian zhou. A pplied functional analysis[M]. Beijing: Scientifi c Publishing Company,2001.7478. ) ( [5]吕金虎,张锁春. Lyapunov 指数的数值计算方法[J].非 线性动力学报,2001,8(1):84-92. LU Jin hu, ZHANG Suo-chun. T The numerical c alculating method of Lyapunov exponent [J ]. J ournal N o nlinear D y namics in Sciences and Technology, 2001,8(1) :84-92. ) ( [6]张思进,陆启韶,王士敏.碰摩转子映射系统的延迟反 馈混沌控制[J].固体力学学报,2001,3(1):89-94. ZHANG Si jin, LU Qi-shao , WANG Shi min. Delayed feedback control of chaos in rub impact rotor mapping systems[J]. Acta Mechanica S olida Sinica, 2001,3(1): 8 9-94. ) ( (编辑:许力琴) ) OChina Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net
关闭还剩3页未读,是否继续阅读?
北京华阳利民仪器有限公司为您提供《柴胡中柴胡皂甙a 与d 对映体的分离检测方案(毛细管电泳仪)》,该方案主要用于中药材和饮片中限度检查检测,参考标准《暂无》,《柴胡中柴胡皂甙a 与d 对映体的分离检测方案(毛细管电泳仪)》用到的仪器有高效毛细管电泳仪(紫外检测)CL1030。
