电源技术 研究究与设计 研究与设计 电源技术 普鲁士蓝薄膜电极的制作及充放电研究 徐国荣', 任凤莲, 司士辉 (1. 湖南科技大学化学化工学院,湖南湘潭411201;2.中南大学化学化工学院,湖南长沙410083) 摘要:以多孔阳极氧化铝作电极活性物质的支撑体,制备了一种新型的普鲁士蓝薄膜电极。制备过程包括纯铝片在草酸溶液中阳极氧化成多孔阳极氧化铝,电化学法去多孔阳极氧化铝的阻挡层,磷酸中扩孔,无电沉积一层钯,再在孔中组装普鲁士蓝。用扫描电镜对支撑体和电极表面形貌进行了表征,用循环伏安法对电极进行了电化学研究。结果表明,这种支撑体孔隙率大于65%,组装的普鲁士蓝(PB)薄膜电极在-02~0.6V和0.6~1.2V两个电位窗口内呈现两对稳定的可逆峰,由这种薄膜电极组成的微型 PB 薄膜蓄电池,容量达到 65 m C /cm 2,表现出良好的充放电性能。 关键词:多孔阳极氧化铝;普鲁士蓝;薄膜电极;蓄电池 中图分类号:TM 9122文献标识码:A 文章编号:1002-087 X (2006)07-0570-04 Preparation and charge-discharge characteristics ofa Prussian blue thin film electrode XU Guo-rong, REN Feng-lian, SI Shi-hui² (1.College of Chemistry and Chemical Engineering,Hunan University of Science and Technology,Xiangtan Hunan 411201,China;2.College of Chemistry and Chemical Engineering, Central South University, Changsha Hunan 410083,China) Abstract:A new type ofPrussan bue thin fim electrode was fabricated. The preparation ofPB thin film electrode in-clded anodic oxilation ofalm num sheet, rem ovalof barierby electolyzng,eenlargem entofpore diam eter nphosphatic acil and electroless deposition ofm etallic paladim and Piussan bhe The m orphobgy ofcamierand PBthin fih electrode were characterized by SEM . Electrochem icalbehavors ofPB thin fin electrode w ere nvestigatedby voltam m etric m ethod and charging-discharging cuive. The results show the porosity ofthe camrier for electro ac-tive m aterials reached 65%, and cyclic voltam m ogram s ofthe PB thin fim electrode exhibied wo reversble redoxpeaks resulting fom FeFe and Fe (CN)。]3-/Fe (CN)。]4-transitons,which were very stable n potentialcyclingranges between -02V and 0.6 VPWPB transition) and betw een 0.6 V and 12V PB/PY transitions). The PBthin fim secondary cells fabricated in this kind ofelctrode exhbita good charging/dischargng perom ance, andhave a capacity of65 m C /cm². Key words:porous anodic alum na;Prussin bhe;thn fim electrode;secondary cell 普鲁士蓝(Prussian blue,PB)又名铁氰化铁,是一种沸石型化合物,自1978年Neff首次报道PB膜修饰电极以来,国内外学者对其进行了广泛的研究,已将其广泛用于电催化2、电显色、传感器、离子选择性电极。由于PB具有电化学可逆性好,良好的离子嵌/脱能力,两对可逆的氧化还原电对,高度的稳定性以及容易制备,成本低廉,成为一种很有吸引力的蓄电池材料16~9]。与普通电极相比,薄膜电极具有更大的电极接触面积,更好地利用活性物质和更短的离子扩散路径,因此可以有效地减少电池体积,适合于高端电子器件使用。薄膜电极支撑体(承载电活性物质)一般是金属或者导电塑料,电活性物质直接沉积或附着在金属、塑料表面,但电活性物质和支 ( 收稿日期:2006 -0 2-22 ) ( 基 金 项目:国家自然科学基金项目( 20475065) ) ( 作者简介:徐国荣( 1 9 70一 ),男,湖南省人,讲师,博士生 , 主要研究方向为电化学催化材料。 ) ( B igrap h y:XU G u o - i on g (1 9 7 0一), m a l e ,le c to r , can d ila t e fo r Ph D . ) 撑体之间的粘着力比较差,电活性物易脱落。也有用通孔的微孔塑料作支撑体0,在微孔塑料的一面沉积一层金属作导电层,然后在孔中沉积电活性物质,这种支撑体电活性物质不易脱落,但制作工艺较复杂。多孔阳极氧化铝( PAA)制备工艺成熟,孔径、孔深均可调,是一种合成纳米材料的重要模板。本文首次用 PAA 经过去阻挡层,扩孔处理和沉积一层钯后作薄膜电极的支撑体,在纳米孔中组装了普鲁士蓝,制成了薄膜电极。并对这种薄膜电极和组成的蓄电池性能进行了测试。 1实验方法 1.1试验仪器 MCP-1型恒电位仪;CA 1713 A双路直流稳压电源;LK98BⅡ微机电化学分析系统; Sirion 2000 扫描电镜。 12电极的制作及电化学测试 电极的制作包括铝的阳极氧化、去阻挡层、扩孔处理,无电沉积Pd和PB。铝的阳极氧化过程为铝箔(30mm×10 mm×0.15 mm,纯度99.9%)经退火、丙酮浸泡除油、1 mol/LNaOH中超声清洗5 min 去氧化铝层、体积比为1:3的高氯酸乙醇溶液中电化学抛光1 min 后,在0.3 mol/L 草酸中以不锈钢板为阴极进行阳极氧化"。去阻挡层采用电化学方法,在10℃的水浴中,0.5 mol/L KCl溶液作电解液,多孔阳极氧化铝为工作电极(阴极),石墨作辅助电极,Ag/AgCl作参比电极,恒电位-1.8V)电解10 min。然后在30℃5%(质量百分数) 的磷酸中浸泡30 min 进行扩孔处理。无电积钯在50mmol/L 的氯化钯的氨溶液中(氨浓度为25%)进行,利用基体铝置换钯,,时间为1~8 min,镀钯后用蒸馏水反复清洗去氨。无电沉积PB在2mmol/L硝酸铁、2 mmol/L铁氰化钾和0.5 mol/L 硝酸钾的混合溶液中进行,时间为2~10 min。电极性能测试采用三电极系统,PB薄膜电极为工作电极,大面积铂片作辅助电极, Ag/AgCl电极作参比电极。电池测试在自制电解槽中进行,正极和负极都是PB 薄膜电极,0.5 mol/L 硝酸钾作电解质( pH=3,用硝酸调节)。 2结果与讨论2 电极形貌表征 在酸性溶液中铝经过阳极氧化后, i可在铝表面形成结构独特的多孔膜。这种膜的结构包括三个部分:外层是多孔氧化铝层,其深度可通过氧化时间调控,一般在几十微米至几毫米之间;底层是没有氧化的铝基体;在多孔氧化铝层和铝基体之间是致密的阻挡层,厚度与氧化电压存在线性关系, 一般在10~100 nm之间。由于存在阻挡层, PAA不能直接作薄膜电极的支撑体,必须去掉阻挡层。去阻挡层的基本原理:在中性电解液中 PAA 作阴极电解氯化钾溶液,水在阴极界面((阻挡层)处还原产生碱OH),利用碱溶解氧化铝阻挡层达到去阻挡层的目的。草酸溶液中制得的PAA 的孔径为70~80nm,孔隙率为45%~50%,经过电解去阻挡层后,并不能扩大孔径,为了提高孔隙率增加活性物质的装载量,需要对PAA进行扩孔处理。扩孔是利用酸均匀溶解孔壁,以扩大孔径。去阻挡层、扩孔后后 PAA 表面形貌如图1(a)所示。从图可以看出,扩孔后孔径达到90~100 nm,出现了部分连孔,孔隙率达到65%以上。镀满了PB的PAA 表面只看到细小的裂纹,见图1(b),表面很均匀、平整。图1(c)是 PB 薄膜电极用饱和氯化汞溶液溶解基体铝,再用5%的磷酸(30℃)溶解底部部分氧化铝后的PB形貌图。图中可以看出PB成棒状,由于没有氧化铝的支撑,棒与棒相互连接成蜂窝状。整个薄膜电极的结构如图2所示。 22PB薄膜电极电化学特性 图3为PB薄膜电极在0.5 mol/L的硝酸钾溶液中典型的循环伏安图。图3(a)的电位扫描范围-0.2~1.2Ⅴ。在此电位范围内出现两对氧化还原峰,第一对峰是PB得到电子还原成普鲁士白(PW),并伴随着钾离子进入 PB膜晶格。第二对峰是PB失去电子氧化成普鲁士黄(PY),并伴随着钾离子迁出PB膜晶格。图3(a)的另一个特点是氧化峰电流与还原峰电流不相等,而两个PB峰近似相等;PY与 PW峰也近似相等,且比两个 PB峰明显要高。图3(b)的电位扫描范围有两个:- 图1(()PAA 模板顶部扫描电镜图 Fg.1a) SEM i agne ofthe top plne ofPAA图1(b)PB薄膜电极表面形貌图 Fg.1 (b) Top phne ofPB thin fin elctrode 图1(c)溶解利和部分氧化铝后的PB薄膜电极底部扫描电镜图 Fg.1 (C) Bottom phne ofPB thin filn elctrode aferalm numand partalalim na dissoled 图2PB薄膜电极结构图 Fg2S tructure m odelofthe PB thin fin electrode 0.2~0.6V和0.6~1.2V,即对两对峰单独扫描。图3(b)不同于图3(a)图,它的氧化峰和还原峰的峰高分别对应相等。当PB 薄膜电极在-0.2~1.2V电位窗口范围内连续进行循环伏安扫描时,两对峰的峰高逐渐降低,其中第一个峰降低更快,说明PB薄膜电极在-0.2~1.2V范围内伏安扫描时不稳定。然而当电极在-0.2~0.6V或0.6~1.2V之间连续循环伏安扫描时,内两对峰的峰高并没有随着扫描次数的增加而降低,说明 PB薄膜电极在-0.2~0.6V及在0.6~1.2V范围内是稳定的。这可能与 PB、PW、PY三者的结构不同有关,当PB在PW/ PB/ PY之间来回变化时,PB的结构容易受到破坏。因此当 PB 薄膜电池充放电时,电池的正负极要固定,一旦电池的正负极反向,将缩短电池使用寿命。 2.3制备工艺条件对PB 电极性能的影响 2.3.1钯沉积时间 PAA去阻挡层后,铝基体便可以与电位较它正的金属离子或金属络离子发生置换反应。在铁-铁氰化钾溶液中,铁氰化铁氧化性很强,可以氧化基体铝,在孔道中生成普鲁士蓝。但这样沉积的普鲁士蓝薄膜电极并没有电化学信号,可能是 (a) PW/PB/PY系统; (b)PB/PW和 PY/PB 系统 图3PB薄膜电极典型循环伏安图 Fg.3 Typicalcyclc vo ltam m ogram s ofthe PB thi fin electrode 普鲁士蓝和铝基体之间产生的界面电阻太大。在沉积PB之前先无电沉积一层金属钯2,PB 薄膜电极才产生电化学信号,钯促进了界面中电子的传递。实验表明,沉积时间5 min,即可使PB薄膜电极产生可逆的电化学信号。沉积时间大于5 min对沉积PB膜没有太大的影响,但钯属于贵金属,使制作成本增加。 232PB沉积液酸度 PB膜沉积液酸度对电极性能影响很大。实验表明当pH<1时,膜电极电化学信号降低。这是因为在较强的酸度下,氧化铝会溶解,在PB与铝电极之间形成的界面电化学稳定性差。当pH>4,PB电极电化学信号可逆性差。这是因为酸度太低,铁离子发生水解。因此PB膜沉积液酸度应控制在弱酸性(pH=2~3)为宜,用硝酸调节。 233PB沉积时间 PB 沉时时间影响PB信号强度,图4为PB沉积时间与电化学信号(PB/PW峰电流)的关系。从图中可以看出, PB沉积时间与峰电流信号并不成线性关系,而是随着时间的增加,峰电流信号增加的幅度慢慢降低。这是因为,随着浸镀时间的增加,膜不断增厚,PB膜的生成速率降低。当PAA孔中镀满PB后,有一部分PB会从电极上脱落。因此,当PAA孔中镀满 PB后,继续增加浸镀时间,对PB峰电流信号不会有很大的增加。 24PB 薄膜电池充放电特性 PB蓄电池在充电过程中,其中一个PB电极发生还原反 图4PB浸镀时间对峰电流的依赖关系 Fg4 Dependence ofpeak currents on the phtng tin e ofPB 应,还原成PW,见(1)式;另一个PB电极发生氧化反应,氧化成 PY 见(2)式,整个电池反应见(3)式。在放电过程发生极性反转,反应朝相反方向进行。PY/PB 电对的热力学平衡电位1.17V(氢标电位, SHE),PB/PW电对的热力学平衡电位0.02V( SHE),因此PB电池热力学平衡电压是1.15Ⅴ。图5(a)是 PB蓄电池在充放电过程中电极电位变化的理论曲线。 图5(()PB/PB薄膜蓄电池充放电过程中阴极阳极电位变化理论曲线 Fig.5 (a) Theoreticalcurves ilustrating the concurrentchanges n potental ofthe anode and cathode durngcharging /discharging ofthe PB secondary cell 图5 (b) PB/PB薄膜蓄电池稳态充放电曲线 Fg.5 (b) S table charge discharge pro files of thePB secondary cellobtaned at50u A /cm² 在开路状态下,电池电压为0V,在充电初期,充电电压由0V慢慢上升到半充电状的1.15V并维持稳定,在充电末期,电压达到最大值。在放电状态下,电压变化相反。图5(b)是 PB薄膜蓄电池稳态下的充放电曲线。电池充放电采用恒电流方式,由于电池的活性物质的质量不能准确知道,根据初步试验,采用 50 mA/cm²充放电。结果表明电池的充电电压稳定在1.4~1.5V之间,充电末期电压上升,放电电压在0.9~0.8V之间,充放电曲线都很平坦,放电容量达到65 mC/cm²。 3 结论 由 PAA 作电极支撑体,制成了性能良好的PB 薄膜电极。由于有多孔氧化铝层的保护作用,沉积在电极上的电活性物质不易脱落;在活性物质与基体电极之间有钯作过度层,大大降低了接触电阻,提高了放电倍率。在50mA/cm²电流密度下,PB薄膜电池的容量达到65 mC/cm²,是一种有开发潜力的微型薄膜蓄电池。 ( 参考文献: ) ( [1] NEFF V D .Electrochemical oxidation an d re d uction of thin films o f Prussian blue [J]. J Electrochem Soc,1978 , 125:886—887. ) ( [2] URSULA S,ERICH W G.Electrocatalytic oxidation of hydrazine at a Prussian b lue m odified g l assy c a rbon el e ctrode [J ] .Electrochimica Acta ,1996,41(2):23 3 —239. ) ( [3] ELLIS D ,ECKHOFF M,NEFF V D . Electrochemism in the mixed va-lence hexacyanides.1.Voltammetric and sp e ctral studies of the oxi- dation a nd reduction o f thin f i lm o f Prussian blue [J].J Phys Chem, 1981,85;1 2251228. ) ( [4] RUEDAS R AMA M J, R UIZ MEDINA A , MOLINA D IAZ A. APrussian blue-based f low-through r enewable surface opt sensor for analysis of ascorbic acid [J]. Microchemical J o urnal, 2 004,78: 157—162. ) ( [5] HERMES M, SCHOLZ F. The e lectrochemical determination of am-monium ba s ed on the sel e ctive in h ibition of the lo w -spin iron(II)/(III) system of Prussian blue[J]. J Solid State Electrochem,1997,1: 215220. ) ( [6] N EFF V D. S ome perf o rmance chara c teristics of a Prussian blue bat-tery [J]. J Electrochem Soc,1985,132: 1 382一1 38 4. ) ( [7] JAYALAKSHM M, SCHO L Z F.Ch a r g e-discharge characteristics ofa s olid-stat e Prussia n blue secondary cell [J]. Journa l of Power Sources, 2000,87:212一217. ) ( [8] ALI E.F abrication o f all-solid-state-thin-film secondary c ells u sing hexacyanometallate-based e lectrode materials [J] . Journa l of Power Sources, 2004,132:29 1 — 2 95. ) ( [9] ALI E .Potassium secondary ce l l based on Pr u ssian bl u e ca t hode [J] . Journal of Power Sources , 2004,126:221—228. ) ( [10] B ARBIC P A, B I NDER L, VO S S S, et a l. T h in-film zinc man-ganese d ioxide electrodes based o n m i croporous polymer foil s [J] . Journal o f Power Sources, 1999,79:271—276. ) ( [11 ] THOMPSON G E. P o ro u s anod i c alumina fabr i cation, ch a racteri- zation and applications [J]. Thin Sol i d Films,1997,297:192一 2 01. ) ( [12] POURNAGHI-AZAR M H , D A STANGOO H. P al l adized a luminum as a n o vel s u bstrate for the n on-electrolytic preparation ofa Prussian blue f i lm modified el e ctrode [J]. Jo u rnal of Elec t roanalyti-cal Chemistry, 2004,573:355—364. ) 传真:0575-3068228 联系人:黄 勇 olNo.◎China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net
关闭还剩2页未读,是否继续阅读?
天津市兰力科化学电子高技术有限公司为您提供《普鲁士蓝薄膜电极中制作及充放电研究检测方案(电化学工作站)》,该方案主要用于其他中电化学性能检测,参考标准《暂无》,《普鲁士蓝薄膜电极中制作及充放电研究检测方案(电化学工作站)》用到的仪器有天津兰力科电化学工作站LK98BII。
我要纠错
