·38·中国兽药杂志2016,50(1):1~4/严凤,等 超高效液相色谱-四级杆-静电场轨道肼高分辨质谱筛查测定饲料中19种磺胺类药物 严凤,李丹妮,吴剑平,周哲2,张鑫,潘娟,张婧 (1.上海市兽药饲料检测所,上海201103;2.赛默飞世尔科技(中国),上海201206) [收稿日期]2015-11-25 [文献标识码]A [文章编号]1002-1280(2016)1-0001-04 [中图分类号]S [摘 要] 建立了超高效液相色谱-四级杆-静电场轨道阱高分辨质谱联用( UPLC-Q -Exac-tive Orbitrap) 快速筛查和确证定量饲料中19种磺胺类药物的分析方法。饲料样品经乙腈-0.1%甲酸溶液(80:20,V/V)超声提取,Agilent SB C18色谱柱(100 mm×3.0 mm,1.8 um)分离,以0.1%(V/V)甲酸乙腈溶液和0.1%(V/V)甲酸水溶液为流动相进行梯度洗脱。静电场轨道阱全扫描得到磺胺类药物的一级精确质量数与理论精确相对分子质量对比,相对质量偏差在0.006×10-6~1.252×10-6之间,有效地去除了基质干扰,实现对饲料中磺胺类药物的快速筛查;同时建立了19种磺胺类药物的二级质谱数据库,实现对19种磺胺类药物的定性筛查及同步定量。19种磺胺类药物在0.1~200 ug/L浓度范围内线性关系良好r>0.99,方法检测限为50 ug/kg,回收率在 59.61%~106.45%之间。 [关键词] 磺胺类;饲料;超高效液相色谱;四级杆-静电场轨道阱高分辨质谱 Screening and Confirmation of 19 Sulfonamides in Feed by Ultra HighPerformance Liquid Chromatography-quadrupole - exactive OrbitrapMass Spectrometry YAN Feng', LI Dan -ni',WU Jian -pin',ZHOU Zhe’, ZHANG Xin', PAN Juan',ZHANG Jing' (1. Shanghai Municipal Superuisory Institute Veterinary Drugs and Feedstoff,Shanghai 201103 , China;2. Thermofisher Scientific( China), Shanghai 201206,China) Abstract: An ultra high performance liquid chromatography - quadrupole - exactive orbitrap mass spectrometrymethod( UPLC -Q-Exactive Orbitrap) was developed for rapid screening, confirmation and quantitative of 19sulfonamides in feed. The samples were extracted with acetonitrile -0.1% aqueous formic acid solution(80:20,V/V), and the extracts were then separated on an Agilent SB C18 (50 mm×3.0mm, 1.8 um) using a binarysolvent system composed of 0.1% formic acid acetonitrile solution and 0.1% aqueous formic acid solution bygradient elution. The relative molecular masses of the target compounds were obtained in full scan mode with arelative deviation in the range of 0.006×10-6~1.252×10-compared to the theoretical value, indicatingeffective elimination of the matrix interference.Tandem massSspectrometric database based on characteristic ( 作者简介:严凤,畜牧师,从事兽药残留分析工作。 ) fragment ions for the 19 sulfonamides was built. This method allowed qualitative screening and quantitativeanalysis at the same time. Calibration curve was linear between 0.1 and 200 ug/L, with the correlation coefficientr>0.99. The limit of detection was 50 ug/kg. The recovery in feed was from 59.61% to 106.45%. Key words: sulfonamides;feed; ultra high performance liquid chromatography (UPLC); quadrupole - exactiveorbitrap 磺胺类药物(Sulfonamides,SAs)是人工合成的具有对氨基苯磺酰胺结构的一类抗菌药物的总称,广泛应用于畜禽养殖业。饲料添加是该类药物在畜牧业中的主要用药方式,随着 SAs 的滥用,细菌耐药性问题日益突出,这不仅会影响畜禽的正常生长发育,而且还会造成畜产品中药物残留超标,危害人体健康,影响环境卫生和生态平衡。针对磺胺类药物的检测手段多样化,如采用免疫分析法2、HPLC法[3-4]以及液质联用方法[5-6]。这些方法在靶向目标定性、定量检测方面有极为广泛的应用,但是这种模式也存在无法获取样品中非靶目标结构信息的局限7,为实现高通量筛查的多组分物质,基于高分辨质谱技术的全扫描的质谱分析方法逐渐进入研究者们的视野18-9。本实验利用高效液相色谱-四极杆-静电场轨道阱高分辨质谱快速检测饲料中添加的19种磺胺类药物,采用正离子全扫描模式进行测定,通过提取的二级质谱进行定性,提取一级质谱的精确相对分子质量进行定量。该方法用实际添加实验进行验证,在较低质量浓度添加水平条件下仍可以保证良好的检测结果。 1 材料与方法 1.1 仪器与试剂 Q-Exactive 四极杆-静电场轨道阱高分辨质谱,配有H-ESI Ⅱ源(美国Ther-mo Fisher Scientific 公司);Ultimate 3000液相色谱系统(美国ThermoFisher Scientific 公司);TraceFinder 数据处理系统(美国 Thermo FisherScientific公司);AE240 电子天平(瑞士Mettler 公司); Allegra X - 22R 高速冷冻离心机(德国Beckman 公司);多管旋涡振荡器(北京Targin 公司); Milli -Q 超纯水系统(美国 Millipore 公司)。 乙腈(色谱纯,美国Merck 公司);甲酸(色谱纯,美国 Tedia 公司);实验用水为超纯水(Milli -Q自制)。 标准品:苯甲酰磺胺(纯度99.8%),磺胺醋酰(纯度99.5%),磺胺喹噁啉(纯度98.0%)磺胺氯哒嗪(纯度99.8%)磺胺嘧啶(纯度99.0%)磺胺间二甲氧嘧啶(纯度99.0%)磺胺邻二甲氧嘧啶(纯度98.0%)磺胺甲基嘧啶(纯度99.2%)磺胺对甲氧嘧啶(纯度98.0%)磺胺二甲嘧啶(纯度99.0%)磺胺甲噻二唑(纯度98.5%)磺胺甲基异恶唑(纯度99.0%)磺胺甲氧哒嗪(纯度99.2%)磺胺间甲氧嘧啶(纯度98.0%)磺胺二甲恶唑(纯度98.0%)磺胺苯吡唑(纯度99.0%)磺胺吡啶(纯度99.0%)磺胺噻唑(纯度99.5%)磺胺二甲异嘧啶(纯度98.0%),以上均购自德国 Dr. Ehrenstorfer GmbH。 标准贮备液配制:分别精密称取19种磺胺类标准品 10 mg,用甲醇溶解稀释并定容至10mL,浓度各为1 mg/mL。 混合标准工作液配制:分别取各标准贮备液500pL,于同一10 mL 容量瓶中,并定容,混合标准中间液浓度为50 ug/mL。 混合标准工作曲线配制:取适量混合标准工作液用0.1%甲酸溶液稀释为浓度0.1、1、10、100、200 ug/L的系列混合标准工作曲线。 1.2 仪器条件 1.2.1 液相色谱条件 色谱柱: Agilent SB C18 柱(3.0 mm×100 mm,1.8 pm),流动相A为0.1%甲酸水溶液,B为含0.1%甲酸的乙腈溶液;梯度洗脱程序:0~15 min,5%~95% B;15~17 min,95% B;17~17.5 min,95%~5% B;17.5~21 min,5%B;流速0.3 mL/min;柱温30℃;进样量10 pL. 1.2.2 质谱条件 可加热的电喷雾离子源(HESI-Ⅱ);离子传输管温度325℃;毛细管电压3200V (正离子模式);气化温度350℃;鞘气压(N2)40 arb;辅助气压(N2)10 arb;一级质谱驻留时间100 ms;二级质谱驻留时间50 ms;一级全扫描范围:m/z100~1200;分辨率(R):70000;扫描模式:Fullscan + ddms(一级全扫描+自动触发二级质谱扫描),碰撞裂解气为高纯氮气,碰撞能量为20、40、60。 1.2.3 样品前处理 称取饲料2.00 g,加入10mL 乙腈-0.1%甲酸溶液(80:20,V/V),混匀,超声提取10 min,8500 r/min 离心5 min,取上清液0.1 mL与0.9 mL0.1%甲酸溶液混匀,12000 r/min 高速离心5 min,取上清液待测。 2结果与分析 2.1 线性范围 本方法线性范围为0.1~200 ug/L,线性相关良好,相关系数r 均大于0.99,线性结果见表1。 表1 磺胺类药物线性方程及相关系数 药物名称 y - Intercept Slope R2 磺胺二甲异嘧啶 2.06E+06 2.29E+06 0.9928 磺胺醋酰 -7.95E+03 2.69E+05 0.9986 磺胺嘧啶 6.02E+04 1.61E+06 0.9961 磺胺噻唑 6.07E+04 1.54E +06 0.9967 磺胺吡啶 9.78E+04 2.43E+06 0.996 磺胺甲基嘧啶 7.10E+04 2.08E +06 0.9954 磺胺二甲恶唑 4.92E+04 1.82E+06 0.997 磺胺二甲嘧啶 2.15E+06 2.52E+06 0.9954 磺胺甲噻二唑 3.99E+04 1.53E +06 0.9963 磺胺对甲氧嘧啶 8.32E+04 2.54E+06 0.994 磺胺甲氧哒嗪 2.99E+04 2.24E+06 0.9991 磺胺间甲氧嘧啶 4.62E+03 2.23E+06 0.9986 磺胺氯哒嗪 1.69E +03 1.52E+06 0.9989 磺胺邻二甲氧嘧啶 7.83E+04 2.91E+06 0.9973 磺胺甲基异恶唑 2.77E+04 2.32E+06 0.9984 苯甲酰磺胺 3.22E+04 1.54E +06 0.9971 磺胺间二甲氧嘧啶 1.25E+04 3.55E+06 0.9993 磺胺喹噁啉 3.03E+04 2.44E+06 0.9991 磺胺苯吡唑 6.93E+04 3.47E+06 0.9975 2.2 回收率与精密度采用空白饲料进行添加回收率试验,添加浓度为 50、100、10000 ug/kg,每个浓度做6个平行,处理方法按1.2.3项进行,用相近浓度的空白基质添加标准单点对样品进行定量, 结果见表2。19种磺胺类药物的平均回收率为59.61%~106.45%,相对标准偏差为0.40%~35.94%,实际测得精确分子量与理论精确分子量的差值均<2 ppm。 表2 回收率、精密度与质量偏差 药物名称 添加浓度(ug/kg) 平均回收率(% RSD(% m/z(Expected) m/z (Apex) m/z (Delta(ppm)) 苯甲酰磺胺 50 76.07 3.89 277.06414 277.06424 0.35913 100 78.19 4.12 277.06414 277.06427 0.46928 10000 68.70 2.26 277.06414 277.06406 -0.30175 续表2 m/z (Delta(ppm)) 药物名称 添加浓度(pg/kg) 平均回收率(% RSD(% m/z (Expected) m/z (Apex) m/z (Delta(ppm)) 50 79.46 4.80 250.06447 250.06447 -0.00646 磺胺吡啶 100 82.84 5.24 250.06447 250.06445 -0.06748 10000 73.38 1.61 250.06447 250.0643 -0.67768 磺胺喹噁啉 50 82.82 2.99 301.07537 301.07535 -0.0734 100 83.62 5.51 301.07537 301.07547 0.33205 10000 71.20 1.52 301.07537 301.0752 -0.58021 磺胺噻唑 50 59.61 4.88 256.02089 256.02066 -0.8968 100 63.48 4.49 256.02089 256.0209 0.0568 10000 66.19 1.54 256.02089 256.02072 -0.6584 磺胺二甲恶唑 50 85.43 3.48 268.07504 268.07504 0.01016 100 106.45 4.04 268.07504 268.07513 0.35168 10000 75.46 1.68 268.07504 268.07492 -0.4452 磺胺二甲异嘧啶 50 75.84 3.58 279.09102 279.091 -0.05941 100 78.10 10.47 279.09102 279.0907 -1.15288 10000 75.19 2.61 279.09102 279.09085 -0.60615 2.3 检测限与定量限 按照检测限信噪比S/N(Peak to Peak)>3,定量限信噪比 S/N ( Peak toPeak) >10 的要求,本方法检测限为 50 ug/kg,定 量限为100ug/kg(表3)。空白图谱、检测限图谱和定量限图谱见图1、图2和图3。 表3检测限与定量限 药物名称 分子式 保留时间 (min 精确母离子 加合物 碎片1 碎片2 碎片3 检测限 定量限 (ug/kg) (ug/kg) 苯甲酰磺胺 C13H2N,0,S 8.12 277.06414 M+H 156.01138 108.04439 92.04948 50 100 磺胺醋酰 CgH10N20,S 4.55 215.04849 M+H 173.03792 156.01138 108.04439 50 100 磺胺氯哒嗪 C10H,CIN40zS 6.93 285.02075 M+H 156.01138 108.04439 92.04948 50 100 磺胺嘧啶 C10H10N402S 4.88 251.05972 M+H 156.01138 108.04439 92.04948 50 100 磺胺间二甲氧嘧啶 C12H14N404S 8.22 311.08085 M+H 156.01138 108.04439 92.04948 50 100 磺胺邻二甲氧嘧啶 C12H14N404S 7.17 311.08085 M+H 156.01138 140.04545 108.04439 50 100 磺胺甲基嘧啶 CH2N40,S 5.51 265.07537 M+H 190.02809 156.01138 108.04439 50 100 磺胺对甲氧嘧啶 CuH2N40,S 6.05 281.07029 M+H 215.09274 156.01138 126.06619 50 100 磺胺二甲嘧啶 C12H14N402S 5.95 279.09102 M+H 156.01138 124.08692 108.04439 50 100 磺胺甲噻二唑 CgH10N402S2 6.02 271.03179 M+H 156.01138 108.04439 92.04948 50 100 磺胺甲基异恶唑 C10H1N30,S 7.31 254.05939 M+H 156.01138 108.04439 92.04948 50 100 磺胺甲氧哒嗪 CH2N40,S 6.23 281.07029 M+H 215.09274 156.01138 126.06619 50 100 磺胺间甲氧嘧啶 CH12N40,S 6.61 281.07029 M+H 215.09274 156.01138 126.06619 50 100 磺胺苯吡唑 C15H14N402S 8.33 315.09102 M+H 156.01051 108.04418 92.04948 50 100 磺胺吡啶 CuHN,0,S 5.19 250.06447 M+H 184.08692 156.01138 108.04439 50 100 磺胺喹噁啉 C14H12N402S 8.16 301.07537 M+H 156.01138 108.04439 92.04948 50 100 磺胺噻唑 C,H,N,0,S2 5.06 256.02089 M+H 156.01138 108.04439 92.04948 50 100 磺胺二甲恶唑 C1H13N30,S 5.66 268.07504 M+H 156.01138 108.04439 92.04948 50 100 磺胺二甲异嘧啶 C12H14N40,S 4.19 279.09102 M+H 156.01138 124.08692 108.04439 50 100 100- 100 100- 100- 20 图1 空白饲料提取离子色谱图 图2 空白饲料添加50pg/kg检测限提取离子色谱图(A:苯甲酰磺胺B:磺胺醋酰C:磺胺氯哒嗪D:磺胺嘧啶E:磺胺间二甲氧嘧啶F:磺胺邻二甲氧嘧啶G:黄胺甲基嘧啶H:磺胺对甲氧嘧啶I:磺胺二甲嘧啶J:磺胺甲噻二唑K:磺胺甲基异恶唑工:磺胺甲氧哒嗪M:磺胺间甲氧嘧啶 N:黄胺苯吡唑O:磺胺吡啶P:磺胺喹噁啉Q:磺胺噻唑R:磺胺二甲恶唑S:磺黄二甲异嘧啶) 2.4 实际样品筛查 随机抽取11份饲料样品,用已优化的色谱-质谱条件和前处理方法进行筛查分析,采集一级质谱数据及二级碎片信息,进行谱库检索,根据保留时间、碎片离子和质量误差等信息确证并同时定量。结果表明,随机抽取的11份样品中检出1份样品含有磺胺间甲氧嘧啶,一级母离子精确质量偏差为0.028×10-6,含量为311.85 ug/kg,筛查结果见图4。 3 讨论与小结 3.1 色谱柱的选择 本实验比较了 Thermo Hypersil GOLD C18(150 mm×2.1 mm,1.9 um)与Agilent SB C18(100 mm × 2.1 mm,1. 8 pm)两款色谱柱。实验表明,虽然两款色谱柱对磺胺类药物的检测灵敏度及药物峰形均无明显差异,但在分离度方面 Agilent SB C18柱的表现更优于 ThermoHypersil GOLD C18 柱,尤其是分离同分异构体磺胺甲氧哒嗪和磺胺对甲氧嘧啶。Thermo HypersilGOLD C18 柱无法将这两个同分异构体分离,但Agilent SB C18 柱就能很好的分离开。 图3 空白饲料添加100 pg/kg定量限提取离子色谱图(A:苯甲黄磺胺B:磺胺醋酰C:黄胺氯哒嗪D:磺胺嘧啶E:磺胺间二甲氧嘧啶F:磺胺邻二甲氧嘧啶G:黄胺甲基嘧啶H:磺胺对甲氧嘧啶 Ⅰ:磺胺二甲嘧啶J:磺胺甲噻二唑K:磺胺甲基异恶唑工:磺胺甲氧哒嗪M:磺胺间甲氧嘧啶 N:磺胺苯吡唑O:磺胺吡啶P:磺胺喹噁啉Q:磺胺噻唑R:磺胺二甲恶唑S:磺黄二甲异嘧啶) 图4 饲料样品中检出磺胺间甲氧嘧啶的筛查结果图(A:母离子精确质量提取色谱图; B:母离子同位素精确质量质谱图;C:碎片离子精确质量质谱图) 2.4.2 提取溶剂比较 磺胺类药物都属于弱碱性药物,本方法选用酸性水溶液与有机溶剂不同的比例组合作为提取溶剂进行比较,6种提取溶剂分别为乙腈-0.1%甲酸溶液(80+20)、乙腈-0.2%甲酸溶液(95+5)、甲醇-0.1 mol/L盐酸溶液(50+50)、乙腈-0.1 mol/L盐酸溶液(50+50)、纯乙腈和纯甲醇。实验结果表明,大部分药物用乙腈-0.1%甲酸溶液(80+20)提取效果最好、乙腈-0.2%甲酸溶液(95+5)和纯甲醇的提取效果相对弱些,纯乙腈的提取效果最差回收率约30%,因此本方法选用乙腈-0.1%甲酸溶液(80+20)作为提取溶剂。 3.2 滤膜比较 考察了不同品牌、不同材质的滤膜对磺胺类药物的吸附影响。我们选用了进口的Millipore Millex - GN 尼龙、PALL- GHP 和国产的PTFE、尼龙、聚醚砜材质滤膜进行比较,实验表明国产的 PTFE 对大部分磺胺类药物影响较小,但对磺胺甲氧哒嗪影响较大,过滤后损失 50%。其余滤膜对不同的药物均会有一定的影响,所以本实验最终未使用滤膜过滤。 目前,高分辨质谱在饲料中药物的筛查应用主要是以液相色谱-四四杆飞行时间质谱为主10],而液相色谱-四级杆-静电场轨道肼质谱的应用则更多在蛋白质组学、代谢组学研究111和食品安全121等方面,在国内饲料领域的应用甚少。本方法用四级杆-静电场轨道肼质谱建立饲料中药物筛查方法,也是该技术在饲料领域应用的初探。 本文建立了饲料中19种磺胺类药物的超高效液相色谱-四级杆-静电场轨道肼质谱筛查与确证方法。饲料所含成分复杂,因此采用高选择性、高准确性的分析手段是检测方法建立的关键。本法通过母离子精确分子质量、二级质谱碎片的精确分子量和液相色谱保留时间信息,对化学物质达到 准确定性,可快速、准确地对饲料中磺胺类药物同时进行定性及定量检测。 ( 参考文献: ) ( [1] 吴永宁,邵 兵 ,沈建忠.兽药残留检测与监控技术[M].北 京:化学工业出版社,2007:189. ) ( 2 赵书景.贺绍君.罗国琦,等.动物性食品中磺胺类药物残留检测方法的研究进展[J].中国畜牧兽医,2009,36(8): 60-63. ) ( 3 GB/T 19542-2007.饲料中磺胺类药物的测定高高效液相色谱法[S]. ) ( 4 陈吉之.闫超.饲料中9种磺胺类药物的 HPLC 法快速分离与检测中国医药工业杂志[J].2015,46(8):892-894. ) ( 5 陈文慧.高效液相色谱-串联质谱法测定饲料中九种磺胺类 药物的残留量[J].分 析 试验室,2010,29(9):52-56. ) ( 16 5] 罗辉泰.黄晓兰.吴惠勤,等.分散固相萃取/高效液相色谱-串联质谱法快速测定饲料中87种药物残留[J] . 分析测试学 报2015,34(9):979-985. ) ( 7 1] 熊岑.李苑雯.郑彦婕,等.静电场轨道阱质谱分析技术在食品分析中的应用进展[J].食 品 科学,2015,36(13): 283 - 287. ) ( |8 姚凤花.冯永巍.高效液相色谱串联飞行时间质谱法快速检测饲料中多种β-受体激动剂[J].食与饲料工业,2013,1:62 -64. ) ( 9 贡松松.顾欣.曹慧,等.超高效液相色谱-四极杆飞行时间质谱法快速筛查生鲜牛乳中的14种磺胺类药物[J].分析 测试学报2014,33(12):1342-1348. ) ( [10]吴宁鹏.班付国.彭丽,等.超高效液相色谱-串联四极杆飞行时间质谱法筛查饲料中11种镇静剂类药物[J].质谱学报 2012,33(2):94-98,117. ) ( [11]李明.马家辰.李红梅,等.静电场轨道阱质谱的进展[J].质 谱学报,2013,34(3):185-192. ) ( [12]熊岑.李苑雯.郑彦婕,等.静电场轨道阱质谱分析技术在食品分析中的应用进展[J]. 食 品科学,2015,36(13): 283-287. ) ( (编辑:侯向辉) ) 目前,高分辨质谱在饲料中药物的筛查应用主要是以液相色谱-四极杆飞行时间质谱为主[10],而液相色谱-四级杆-静电场轨道肼质谱的应用则更多在蛋白质组学、代谢组学研究[11]和食品安全[12]等方面,在国内饲料领域的应用甚少。本方法用四级杆-静电场轨道肼质谱建立饲料中药物筛查方法,也是该技术在饲料领域应用的初探。
关闭还剩6页未读,是否继续阅读?
赛默飞色谱与质谱为您提供《饲料中磺胺二甲异嘧啶检测方案(液相色谱仪)》,该方案主要用于饲料中兽药检测,参考标准《暂无》,《饲料中磺胺二甲异嘧啶检测方案(液相色谱仪)》用到的仪器有赛默飞 Vanquish™ UHPLC超高效液相色谱系统。
