当前位置: 合成纤维 > 理化分析 > 方案详情
尼龙66中水检测方案(卡氏水分测定)
检测样品 合成纤维
检测项目 理化分析
关联设备 共4种 下载方案
方案详情
卡尔-费休库仑法测定尼龙66中水分含量 使用日本京都电子公司(KEM)-库仑法卡氏水份测定仪(MKC-520),外接自动卡氏加热炉(ADP-511S),测定聚合物(尼龙66)中水分含量的应用资料。
Kyoto Electronics Manufacturing Co., Ltd.Data No.LA47-07251 No.EKCR-07273 KEM Application Note No.EKCR-07273 Coulometric Karl-Fischer Titration Moisture of N-66 polymer -Summary- Checked the possibility of measuring moisture of N-66 polymer in combination of MKC-520with ADP-511S, and good repeatability was obtained. -Measuring instrument- Main unit:MKC-520 Coulometric KF moisture titrator Option: ADP-511SEvaporator Electrode: M-713 Twin platinum electrode #433-0006Inner burette ·Reagent- Anolyte: Coulomat AG Catholyte: Coulomat CG Carrier gas: Nitrogen -Measurement method- Preparation: (1) Fill the titration cell with the anolyte and inner burette with the catholyte. (2) Pretitrate for dehydration. (3) Connect MKC-520 with ADP-511S and set the nitrogen flow at 200mL/min and theevaporation temperature at 200°℃. Measurement: (1) Place 1g sample in the sample boat and measure for its moisture. -Equation- Moisture (ppm): ((Data-Driftxt-Blank)/(Wt1-Wt2))xF Data: Measured water content (ug) Drift : Drift before measurement (ug/s) t: Measuring time(s)Blank : Blank value (ug) Wt1 : Tare including sample weight (g) Wt2 : Tare including residual weight (g) F:Factor(1.00) -Standard method- Karl Fischer method .Ambient conditions- 京都电子工业株式会社-可睦电子(上海)商贸有限公司上海市漕溪路222号航天大厦北楼902室电话:021-54488867 电邮: kemu-kem@163. com网址: http://www.kyoto-kem.net.cn -Measurement parameter- -Printout data- [Titration1 Method 4 Titr. Cell No. 1 t(stir) 300s t(wait) 15 s t(max) 1800 s Drift Stop:: Rel 0.01 ug/s Cont. Gain 5.0 Stable 0.1 ug/min Start :Manual Oven : ADP- Oven Temp :200°℃ Pre Treat 2 Back Purge180 s Cell Purge 120 s [Calculation] Clac. No. 2 Unit :ppm Weight :Variable Drift Comp. :Auto DataList] Samp. Interval 60s Display : Form2 Print Meas. Data: On Print Graphic : Form2 ug 3000 00:30:00 ***Result*** Sample No. 03-01 Date 07/08/31 10:38 Titr. Cell No. 1Wt1 1.0105gWt2 0 g Net 1.0105 g Drift 0.11 ug/s Result 2925.0 Hg2894.6ppm Titr. Time : 00:30: 15 -Measurement results- Run Sample size(g) Moisture(ug) Concentration(ppm) Statistics 123 1.0105 1.0123 0.9847 2925.02912.8 2790.2 2894.6 2878.02833.6 MeanSD RSD 2868.7 ppm31.538 ppm1.0994% -Comments- Compared with Karl Fisher Coulometry without a diaphragm. See the No.KCR-07272. 京都电子工业株式会社-可睦电子(上海)商贸有限公司电话:021-54488867 电邮: kemu-kem@163.com 上海市漕溪路222号航天大厦北楼902室网址: http://www.kyoto-kem.net.cn
关闭
  • 1/2
  • 2/2
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《尼龙66中水检测方案(卡氏水分测定)》,该方案主要用于合成纤维中理化分析检测,参考标准《暂无》,《尼龙66中水检测方案(卡氏水分测定)》用到的仪器有MKH-710M容量法库仑法混合型卡尔费休水分仪、MKC-710S豪华型库仑法卡尔费休水分仪、MKC-710M四通道旗舰型库仑法卡尔费休水分仪、橡胶塑料水分测定仪。
我要纠错
推荐专场
