Routine soil analysis using an Agilent8800 ICP-QQQ Introduction: Quadrupole ICP-MS (ICP-QMS) is one of the most widely used analytical techniques in inorganic testing laboratories,due to its performance characteristics of high sensitivity, low detection limits, wide dynamic range, and high speedmulti-element analysis. Recent advances have seen a dramatic improvement in matrix tolerance: Agilent’s High Matrix Introduction (HMI)technology uses aerosol dilution to reduce the sample matrix load on the plasma, ensuring that much higher matrixlevels-up to % levels of total dissolved solids (TDS)-can be analyzed routinely. Control of interferences has also been improved significantly, with Agilent's octopole-based collision/reaction cell(CRC) operating in helium (He) collision mode to eliminate a wide range of matrix based polyatomic interferencesusing one set of cell conditions [1]. Reliable and accurate quantitation of all required elements at the regulatedlevels in a wide variety of sample matrices is now possible using ICP-QMS. However, some applications requiregreater sensitivity for some specific elements, while some complex sample matrices may cause spectralinterferences that remain a challenge. Agilent Technologies Quadrupole ICP-MS (ICP-QMS) is one of the most widely used analytical techniques in inorganic testing laboratories, due to its performance characteristics of high sensitivity, low detection limits, wide dynamic range, and high speed multi-element analysis.Recent advances have seen a dramatic improvement in matrix tolerance: Agilent’s High Matrix Introduction (HMI) technology uses aerosol dilution to reduce the sample matrix load on the plasma, ensuring that much higher matrix levels—up to % levels of total dissolved solids (TDS)—can be analyzed routinely.Control of interferences has also been improved significantly, with Agilent’s octopole-based collision/reaction cell (CRC) operating in helium (He) collision mode to eliminate a wide range of matrix based polyatomic interferences using one set of cell conditions [1]. Reliable and accurate quantitation of all required elements at the regulated levels in a wide variety of sample matrices is now possible using ICP-QMS. However, some applications require greater sensitivity for some specific elements, while some complex sample matrices may cause spectral interferences that remain a challenge.
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《土壤中Ca元素检测方案(等离子体质谱)》,该方案主要用于土壤中(类)金属及其化合物检测,参考标准《暂无》,《土壤中Ca元素检测方案(等离子体质谱)》用到的仪器有null。
