Hydraulic fracturing (fracking) extracts oil and gas by forcingfluids into oil and gas rich shale deposits. The fracking fluidscontain a mixture of proppants (sand), surfactants, biocides,inorganic salts, and other compounds intended to facilitatethe release of the trapped gas. More than 7,000 wells havebeen drilled in Colorado alone, and reports of groundwatercontamination have occurred most notably in Wyoming, NewYork, and Pennsylvania [1]. The first water that returns from the fracking process (flowback) has the potential to contaminate nearby aquifers or surface water. Care is taken to recycle the flowback water, or to dispose of it properly, although theSafe Drinking Water Act does not apply to hydraulic fracturing solutions [2]. Thus, there is a demand for tracer compounds that are indicative of the presence of contamination by hydraulic fracturing and do not occur in the subsurface [2].In this application note, a combination of ultra high performance liquid chromatography (UHPLC) followed by quadrupole time-of-flight tandem mass spectrometry (Q-TOF-MS/MS) was used to detect a bimodal distribution of polyethylene glycols that may be used as indicator compounds for groundwater or surface water impacted by flowback waters. The Kendrick Mass Defect [2,3] was applied in a novel application to differentiate the various adducts of a suite of glycols, in particular, the proton, ammonium, and sodium adducts of each of the chains of glycols. The database of the accurate masses along with their retention times byUHPLC is needed to provide a rapid and accurate analysis of either groundwater or surface water samples using Agilent MassHunter Software.ConclusionsThe Agilent 1290 Infinity LC System and Agilent 6540 LC/Q-TOF-MS enabled the UHPLC/MS/MS characterization of two sets of representative polyethylene compounds from hydraulic fracturing flowback samples. Applying the Kendrickmass scale to the accurate masses of these PEGs and other ethoxylated surfactants [2] facilitates their identification using Agilent MassHunter Software, and the construction of a database of such compounds present in flowback samples. This database can, in turn, enable the use of these compounds as unique tracers of hydraulic fracturing.
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《废水中聚乙二醇检测方案(液相色谱仪)》,该方案主要用于废水中有机污染物检测,参考标准《暂无》,《废水中聚乙二醇检测方案(液相色谱仪)》用到的仪器有Agilent 1290 Infinity II 四元液相色谱系统、Agilent 6545XT Q-TOF 液质联用系统、Agilent 7693A 自动液体进样器。
