检测样品 果蔬汁类及其饮料
检测项目 理化分析
重Analytical Equipment一寸丁<、www.lumexinstruments.ccm DETERMINATION OF ANIONS IN BEVERAGESLumex Method M 04-79-2013 INTRODUCTION The method is used for the determination of the mass concentration of chloride, sulfate, and nitrate inbeverages by capillary electrophoresis. The method can be applied for all types of non-alcoholic andalcoholic beverages including sport and energetic drinks, juices, beer and beer products, wines,brandy and spirits, liquors, and vodka. MEASUREMENT METHOD The measurement method is based on capillary zone electrophoresis with indirect UV detection at thewavelength of 254 nm. MEASUREMENT RANGE The measurement ranges for the components are presented in the table below. Anions Measurement range, mg/L Chlorides 0.5-20000 Sulfates 0.5-5000 Nitrates 0.5-500 Other inorganic anions (nitrite, bromide, sulfite,fluoride, phosphate, and carbonate) and organic acids (acetic,tartaric, oxalic, malic, citric and others) in concentrations, typical for the mentioned beverages do notdeteriorate target anions determination. EQUIPMENT AND REAGENTS The CAPEL capillary electrophoresis system is used in measurements. Data acquisition, collection,processing and output are performed using a personal computer running under WINDOWS@ XP/7/8/10operating system with installed dedicated software package ELFORUN. Lumex Instruments set, order No 0300001842. EXAMPLES OF REAL ANALYSES BGE: chromate, with DEA and CTA-OH Capillary: -ef/Ltot =50/60 cm, ID 75 pm The contents on this paper are subject to change without notice.To get more specific information, please contact the representative by sales@lumexinstruments.com LUMEX成功的将毛细管电泳发展成为实验室的常规分析手段,并一直占据该领域的市场领导地位。成熟的仪器、优化的配置、大量的应用方法包集于一体,被用户称为目前性价比最优的分析仪器。采用毛细管电泳法测定饮料中氯化物、硫酸盐和硝酸盐的质量浓度。该方法可适用于所有类型的非酒精和酒精饮料,包括运动和烈性饮料,果汁,啤酒和啤酒产品,葡萄酒,白兰地和烈酒,酒,伏特加等。毛细管电泳法的分析优势特点有:1.高效分离效率(百万级理论塔板数);2.样品试剂和样品量消耗低;3.极低的分析成本,毛细管柱一般无需更换;4.操作简单便捷,实现快速分析 (5-10分钟)。
关闭产品配置单
LUMEX INSTRUMENTS (鲁美科思分析仪器)为您提供《饮料、果汁、啤酒、葡萄酒等样品中阴离子(氯化物、硫酸盐和硝酸盐)检测方案(毛细管电泳仪)》,该方案主要用于果蔬汁类及其饮料中理化分析检测,参考标准《暂无》,《饮料、果汁、啤酒、葡萄酒等样品中阴离子(氯化物、硫酸盐和硝酸盐)检测方案(毛细管电泳仪)》用到的仪器有LUMEX高效毛细管电泳仪Capel 205、LUMEX石墨炉原子吸收MGA-1000、LUMEX傅立叶近红外光谱仪 FT-12、LUMEX实时荧光定量PCR AriaDNA-4。
