当前位置: > 理化分析 > 方案详情
乙醇,水,熔融石英等样品中和频光谱,吸附过程检测方案(激光产品)
检测样品
检测项目 理化分析
关联设备 共2种
方案详情
采用立陶宛Ekspla公司由PL2241型皮秒激光器构成的合频光谱测量系统SFG。对乙醇,水,熔融石英,压敏粘结剂,蓝宝石,丙烯酸,L-组氨酸晶体等物质的表面吸附特性及其和体物质结构行为的关联性进行了研究。
Thorough understanding of interfaces requires an assessment of both the surface and bulkproperties through the use of multiple techniques. In this thesis, infrared absorption,Raman scattering and sum frequency generation were used as vibrational probes of different features of interfacial systems including the ability to measure surface and bulk effects. Two-dimension correlation analysis was used to study the relationship between the spectral response of the different techniques. Attenuated total reflection absorption,bulk Raman scattering and sum frequency generation were used to study the adsorption ofethanol–water mixture on fused silica. With the use of two-dimension correlation analysis,interesting results were observed concerning the behavior of the surface in respect to thebulk. Surface concentration of ethanol were concluded to be higher than in the bulkindicative of competitive adsorption. Furthermore, at low concentration ethanol was shownto adsorb to the surface in dimers, to then form a bilayer of strongly oriented ethanol molecules at higher concentration. At highest concentration, this bilayer is disturbed,leaving only one layer at the surface of oriented ethanol molecules. The same spectroscopic techniques were applied to pressure sensitive adhesives of different composition while drying on a sapphire surface. The presence or absence of acrylic acid in the material was shown to alter the reorientation at the surface while drying. In the case where no acrylic acid is present, the orientation of the polymer at the surface was driven by the packing of the molecules at the surface. When acrylic acid was present in the pressure sensitive adhesive, reorientation occurred much faster and was caused by strong hydrogen bonding with the surface of the sapphire. An increase in acrylic acid composition, increased the rate of reorientation. An experimental set up was constructed to specifically study interfaces with a nonuniform distribution within the plane of the surface. This allows for concomitant measurement of polarized total internal reflection Raman scattering and sum frequency generation spectroscopy along with bright field imaging and cross polarized imaging.This set up was used to study the L-histidine crystal in situ adsorbed on fused silica.The polarized experiments along with calculations allowed for a more in-depth analysis of the crystal orientation effect on the birefringence, the Raman and the sum frequencygeneration.
关闭
北京欧兰科技发展有限公司为您提供《乙醇,水,熔融石英等样品中和频光谱,吸附过程检测方案(激光产品)》,该方案主要用于醇中理化分析检测,参考标准《暂无》,《乙醇,水,熔融石英等样品中和频光谱,吸附过程检测方案(激光产品)》用到的仪器有PL2241 系列高能量皮秒锁模 Nd:YAG 激光器、Ekspla SFG 表面和频光谱分析系统。
我要纠错
推荐专场
相关方案
