当前位置: 其他 > 方案详情
CC-505 搭配2L的Radleys反应釜中温度反应:降温,升温,可实现的最低温度检测方案(水浴、油浴)
检测样品 其他
检测项目 温度反应:降温,升温,可实现的最低温度
关联设备 共2种 下载方案
方案详情
1.可实现的最低温度为:-50℃。 2.能够通过控制器自带的编程功能进行程序控温。 3.温度精准度可达±0.01
Case Study CS 1228|205Technical details and dimensions are subject to change. No liability is accepted for errors or ommisions.www.huber-online.com React dy CC@@_505 CC-505 cycling a 2 litre Radleys jacketedreactor Requirement HH This case study demonstrates the ability of theCC-505 refrigeration bath circulator to cycle theprocess temperature in a range from +20℃to -50℃, the closeness of the temperaturecontrol and the minimum process temperatureachievable in the process mass. Method Reactor The 2 litre Radleys reactor was connected to theCC-505 using two M24x1.5 1-meter flexiblehoses. The thermofluid used in the system wasM40.165.10."Process" control was carried outvia a Pt100 sensor located in the process mass.Stirrer speed was set to 200 rpm. Setup details Temperature range: -50C...+200°C Cooling power: 1.2 kW @ +100°C 1.2kW@+20°C 1.0 kW @ 0°C 0.6 kW @ -20°C 0.15 kW @-40°C Heating power: 1.5kW Hoses: M24x1.5;2*1m HTF: M40.165.10 Reactor: Radleys 2 litre iacketed reactor Reactor content: 1.5 litre M40.165.10 Stirrer speed: 200 rpm Control: process Performance: Cooling down and heating up in a range from +20℃ to-20℃.The CC-505 needs approximately 45 minutes to cool down the reactorfrom +20℃ to -20C and 35 minutes to heat it up from -20°℃ to +20℃. Once stable at +20℃ under"Process” control, a set-point of -50C isentered. The CC-505 cools the reactor down to the minimum achievableprocess temperature of -34°C. CC®-505CC®-505 cycling a 2 litre Radleys jacketedreactorRequirementThis case study demonstrates the ability of theCC-505 refrigeration bath circulator to cycle theprocess temperature in a range from +20°Cto -50°C, the closeness of the temperaturecontrol and the minimum process temperatureachievable in the process mass.MethodThe 2 litre Radleys reactor was connected to theCC-505 using two M24x1.5 1-meter flexiblehoses. The thermofluid used in the system wasM40.165.10. “Process” control was carried outvia a Pt100 sensor located in the process mass.Stirrer speed was set to 200 rpm.Setup detailsTemperature range: -50°C...+200°CCooling power: 1.2 kW @ +100°C1.2 kW @ +20°C1.0 kW @ 0°C0.6 kW @ -20°C0.15 kW @ -40°CHeating power: 1.5 kWHoses: M24x1.5; 2* 1 mHTF: M40.165.10Reactor: Radleys 2 litrejacketed reactorReactor content: 1.5 litre M40.165.10Stirrer speed: 200 rpmControl: processresultsPerformance:Cooling down and heating up in a range from +20°C to -20°C.The CC-505 needs approximately 45 minutes to cool down the reactorfrom +20°C to -20°C and 35 minutes to heat it up from -20°C to +20°C.Lowest achievable temperature (Tmin):Once stable at +20°C under “Process“ control, a set-point of -50°C isentered. The CC-505 cools the reactor down to the minimum achievableprocess temperature of -34°C.
关闭
  • 1/1
产品配置单
富博(广州)仪器设备有限公司(huber中国)为您提供《CC-505 搭配2L的Radleys反应釜中温度反应:降温,升温,可实现的最低温度检测方案(水浴、油浴)》,该方案主要用于其他中温度反应:降温,升温,可实现的最低温度检测,参考标准《暂无》,《CC-505 搭配2L的Radleys反应釜中温度反应:降温,升温,可实现的最低温度检测方案(水浴、油浴)》用到的仪器有Huber 加热制冷型浴槽循环器 CC-505、Huber 低温循环制冷器 Unichiller 060T。
我要纠错
推荐专场
相关方案
