MEGA SYSTEMSAMPLINGSOLUTIONS& METROLOGY Via Don Fracassi, 41/43-20010 Bareggio (MI)ITALY-Tel. +39.02.90361622- commerciale@megasystemsrl.com- www.megasystemsrl.com CALIBRATION STACK EMISSIONSSAMPLING OFHEAVY METALS The European regulation UNI EN 14385:2004 is the referencenorm for the Heavy Metals gravimetric sampling from thestack emissions: As, Cd, Cr, Co, Cu, Mn, Ni, Pb, Sb, Tl and V. This sampling is done in isokinetic conditions and typicallythis kind of pollutants are catched by using glass impingersfilled with a specifical chemical solution where the flue gas issucked through a pump and a heated probe. Our solution consists in a sampling train composed by aheated probe X1-Probe with a titanium sampling line and aglass filter holder in order to have inert materials in directcontact with the flue gas without influencingthe analysis results. The isokinetic sampling is driven by the isokinetic controllerlIsocheck SRB together with a Lifetek Pump series, alightweight, versatile and user friendly solution. Thanks to E1-Analyzer it is possible to measure the dry gasdensity and use the real value for the isokinetic calculations. < ISOCCHHECK CARE FOR THEENVIRONMENT METALS UNIEN 14385:2004 The reference standard for sampling of metals in stacks isUNI EN 14385:2004. “Stationary source emissions. Determination ofthe totalemission of As, Cd, Cr, Co, Cu, Mn, Ni, Pb, Sb, Tl and V".The system allows to sample heavy metals in flues of any sizeand type (vertical/horizontal). 5 LEGEND 1.X1-Probe 2. Greenburg Smith impingers 3. Impingers holder 4.E1-Analyzer 5. Silica gel tower 6. Isokinetic controller Isocheck SRB and Lifetek 55 pump CARE FOR THE ENVIRONMENT The European regulation UNI EN 14385:2004 is the reference norm for the Heavy Metals gravimetric sampling from the stack emissions:As, Cd, Cr, Co, Cu, Mn, Ni, Pb, Sb, TI and V
关闭产品配置单
北京威斯孚科技有限公司为您提供《废气,固定污染源中As, Cd, Cr, 等检测方案(CO、CO2)》,该方案主要用于废气中(类)金属及其化合物检测,参考标准《暂无》,《废气,固定污染源中As, Cd, Cr, 等检测方案(CO、CO2)》用到的仪器有顺磁氧红外二氧化碳分析仪E1-Aanalyzer、分级颗粒物采样石英/玻纤 滤膜。
