OXFORDIN STRUMENT SThe Business ofScience机械及电学性能@ Oxford Instruments 2019 真正意义上检测某种材料就是要在其使用过程中观察其表现 For many materials, the truly important is how they performand behave under the conditions that they are likely to beexposed to during their use-lifetime. This may be theapplication of stresses and strains in construction materials,the dielectric properties of ceramics or the corrosionresistance of materials as they are exposed to a variety of atmospheric conditions. Using our Cypher and MFP-3D atomic force microscopes () it ispossible to measure a huge range of mechanical properties of materials at the nanoscale,from elastic and adhesive forces to materials hardness. The way a changes structurally underthe application of force is vitallyimportant for construction materials.Our Symmetry electron backscatter(EBSD) has market-leading speedand sensitivity allowing the crystalline For many materials, the truly important is how they perform and behave under the conditions that they are likely to be exposed to during their use-lifetime. This may be the application of stresses and strains in construction materials, the dielectric properties of ceramics or the corrosion resistance of materials as they are exposed to a variety of atmospheric conditions. Using our Cypher and MFP-3D atomic force microscopes () it is possible to measure a huge range of mechanical properties of materials at the nanoscale, from elastic and adhesive forces to materials hardness.
关闭产品配置单
牛津仪器科技(上海)有限公司为您提供《材料、塑料、胶黏剂中机械及电学性能检测方案(扫描探针)》,该方案主要用于粗钢中机械性能检测,参考标准《暂无》,《材料、塑料、胶黏剂中机械及电学性能检测方案(扫描探针)》用到的仪器有牛津仪器Asylum Research大样品原子力显微镜JupiterXR、EBSD探测器Symmetry S3 牛津仪器、牛津仪器X-MaxTEM大面积硅漂移探测器、牛津仪器Azteclive能谱实时元素成像系统、电镜专用自动清洁度分析系统---牛津仪器AZtecFeature。
