当前位置: 其他 > 生化检验 > 方案详情
自动化病毒检测解决方案
检测样品 其他
检测项目 生化检验
关联设备 共3种 下载方案
方案详情
Aurora Biomed用于病毒测试的自动化解决方案,可简化病毒RNA提取和实时RT-PCR体系构建。 Aurora的VERSA®1100 Gene工作站与基于磁珠/柱法的病毒RNA分离试剂盒以及疾病预防控制中心(CDC)批准的实时RT-PCR协议兼容。该工作站在降低交叉污染风险,减少由人工干预导致的错误以及减少实验室人员暴露于潜在有害试剂和病原体的时间方面具有显着优势。 所有这些都是通过增加样品通量的额外好处来完成的。 由于我们的自动化解决方案是一个开放的模块化系统,因此与各种病毒检测方法和试剂盒兼容,
More automation solutions:Aurora Biomed·www.aurorabiomed.com+1-604-215-8700·info@aurorabiomed.comGenomics- NGS library prep, PCR, DNA ExtractionMass Spectrometry-Maldi-tof, LC, GS sample prepForensics-Differential Digestion, Toxicology Coronavirus Detection Kits and Automated LiquidHandling Workstations The AB COVID-19 detection kits, when.combined with the VERSA automated liquidhanding platform provide a scalable virussample processing solution. The current outbreak of the COVID-19 Coronavirus demands shortsample processing times combined with rapid and reliable dectionkits Aurora Biomed provides viral diagnostic kits and automated liquidhandling platforms to provide automated solutions for virus detection. Aurora's VERSA series of automated liquid handling platforms arecompatible with automating most common virus detection workflows. COVID-19 virus 2-step detection kit AB COVID-19 virus detection kit has separate RNA isolation stepthat is followed by the qPCR detection step (Catalogue # AB-COVID19-2step) Detection kit information 200 copies per mL detection limit 24 tests per kit Target genes:ORF1ab and N gene Compatible with sputum, alveolar wash and pharyngeal swabsamples Positive control and an internal standard to monitor test accuracyare included with kit CFDA approved Automated by VERSA Detection kit sensitivity andcopy number range Detection limit: 200 copies per mL Plasmid test linear range: 102-10° copies per mL VERSA automated Workstation for virus detection workflows 自动化冠状病毒检测解决方案www-aurorabiomed-com-cnCOVID-19的传播给公共和私人测试实验室带来了巨大负担。 对于每个阳性测试,都要筛查数千人。 这种需要处理的样品数量的快速增加,以及周转时间短的必要性,往往超过了当前建立的设施的能力。 这凸显了迫切需要在全世界的实验室中进行广泛,可靠的检测测试。Aurora Biomed一直不懈地努力开发能力,以提供CE和CFDA认证的COVID-19检测试剂盒。 这些测试工具包已在中国(包括武汉)的40多家医疗机构中用作COVID-19的可靠测试方法,目前正在欧洲,亚洲和非洲的其他国家/地区使用。 我们的COVID-19测试试剂盒规格包括:检测限低至200拷贝每毫升24人份每个试剂盒目标基因:ORF1ab和N基因兼容痰液,肺泡冲洗液和咽拭子等样品阴、阳性对照监控测试准确性当与我们的工作站结合使用以自动执行病毒病原体检测工作流程时,我们的COVID-19检测试剂盒可快速处理潜在感染的患者样品。Aurora Biomed用于冠状病毒(COVID-19)测试的自动化解决方案,可简化COVID-19的病毒RNA提取和实时RT-PCR体系构建。 Aurora的VERSA®1100 Gene工作站与基于磁珠/柱法的病毒RNA分离试剂盒以及疾病预防控制中心(CDC)批准的实时RT-PCR协议兼容。该工作站在降低交叉污染风险,减少由人工干预导致的错误以及减少实验室人员暴露于潜在有害试剂和病原体的时间方面具有显着优势。 所有这些都是通过增加样品通量的额外好处来完成的。 由于我们的自动化解决方案是一个开放的模块化系统,因此与各种COVID-19病毒检测方法和试剂盒兼容,其中包括:FDA COVID-19诊断要求市售的COVID-19筛查试剂盒确定的病毒筛查方法CE和CFDA认证的实时RT-PCR检测试剂盒仪器特点• 具有单通道功能的4或8通道移液头可灵活处理液体• 多达8通道的ReagentDrop提供了无需一次性移液器吸头的试剂分配• 磁珠分离器用于基于磁珠的病毒RNA提取工作流程• 加热振荡器(室温至90°C)可有效分离RNA• 用于实时RT-PCR试剂和在线预混液制备的试剂冷却器模块• 紫外线HEPA过滤外壳降低样品污染的风险常见答疑VERSA自动化工作站兼容我们自己的病毒RNA提取试剂盒及实时RT-PCR试剂盒我们灵活的液体处理系统和用户友好的软件界面使用户可以轻松地创建其他工作流程,例如核酸提取,PCR设置,标准化,板重定格式和系列稀释。 不同模块之间的所有转移均由移盘夹或移液臂自动完成VERSA®自动COVID-19检测系统配备了试剂块冷却器,可以将珍贵的dNTP和温度敏感的缓冲液,酶和引物保持在4°C的试剂冷槽中。
关闭
  • 1/1
产品配置单
加拿大欧罗拉生物科技有限公司为您提供《自动化病毒检测解决方案》,该方案主要用于其他中生化检验检测,参考标准《暂无》,《自动化病毒检测解决方案》用到的仪器有核酸阵列喷印 欧罗拉微阵列点样仪 Versa10 110 1100、核酸提纯系统 欧罗拉液体处理工作站、欧罗拉VERSA 2100液体处理工作站 mRNA疫苗自动化处理。
我要纠错
推荐专场
相关方案
