食品科技一研究与探讨 食品科技研究与探讨Vol.36,No.07,2015 电子鼻测定榴莲果肉臭味气体的模型建立及应用 马 勇,刘水琳,汤轶伟,励建荣 (渤海大学化学化工与食品安全学院,辽宁锦州121013) 摘 要:利用 PEN3 便携式电子鼻检测榴莲果肉的臭味响应值,并运用密封、打孔的方法使信号曲线能较快的达到平稳状态。通过 PCA 分析确定榴莲果肉臭味的第一主成分和第二主成分的总贡献率达到99.49%,而且0孔、8孔、16孔三种不同孔数处理的榴莲果肉臭味有明显差异,所以,电子鼻识别榴莲果肉臭味可行;通过 Loadings 分析认为硫化物是榴莲果肉臭味气体的主要成分;根据检测到的数据,利用 PLS 法建立了榴莲果肉臭味气体相对含量的模型,运用统计软件建立了 PLS 线性拟合曲线,得到0孔、8孔、16孔的相对含量拟合的线性相关系数为0.997,说明榴莲果肉臭味气体相对含量与电子鼻输出信号之间有较好的线性性系;测得0孔、8孔、16孔的相对含量的平均相对误差均小于10%。因此,本文所建模型可准确地测定榴莲果肉臭味气体的相对含量,从而提供一种评定榴莲臭味的实用方法。 关键词:电子鼻,榴莲臭味,PLS模型 Establishment and application of the model fordetecting the odor of durian pulp MA Yong,LIU Shui-lin,TANG Yi-wei,LI Jian-rong (College of Chemistry, Chemical Engineering and Food Safety, Bohai University,Jinzhou 121013,China) Abstract: The response values of the odor of durian pulp were detected by PEN3 portable E-nose.The method ofsealing and punching was applied to make the signal curve reach steady much faster. The total contribution of thefirst and the second principal component of the durian pulp was 99.49% by PCA, and the odors of the threesamples were obviously different.It was feasible to identify the differences between the odors with different levels ofdurian pulp by E-nose. The result of loadings was that sulfide was the main component.According to the datadetected,a model of measuring the relative content of the odor was established by the method of PLS and a linearfitting curve of which the correlation coefficient was 0.997 was drawn up by statistical software. This showed thatthere was a good linear relationship between the relative content of the odor and the output signal of E-nose.Theaverage relative errors of the samples with 0 hole,8 holes and 16 holes were6.3%,6.5% and 6.7%.Therefore, in thispaper, the model can accurately determine the relative content of the odor of durian pulp so as to provide apractical method to evaluate durian odor. Key words:E-nose;durian odor;PLS model 榴莲,又称韶子,台湾称“金枕头”1-2。产自东南亚和南亚热带国家,是热带国家名贵的水果。有“南国水果之王”的美誉。近几年,我国广东、海南和台湾等地有小量引种栽培-4。榴莲果肉营养丰富,蛋白质含量为2.7%,碳水化合物为9.7%,脂肪含量为4.1%;榴莲果肉中维生素(VC、Va、Vb,)、氨基酸(谷氨酸等)和人体必需的矿质质素(K、Ca等)含量 丰富5-6。榴莲果肉滑似奶膏、甜润可口、齿颊留香,但它奇特的臭味,不堪入鼻17-8。一些国家禁止在公共场所携带、食用榴莲19-10。为了使榴莲这种名贵且高营养的水果登上大雅之堂,马勇等采用臭氧法消除榴莲果肉臭味,并用气质联用仪测定了榴莲果肉臭味气体成分的变化,感官评定了榴莲果肉在不同密封时间后臭味气体富集的效果。此外,相关榴 ( 收稿日期 : 20 14- 0 5- 1 5 ) ( 作者简介: 马 勇(1 960 - ) ,男,博 士 ,教授,研究方向:食品资源开发与利用。 ) ( * 通讯作者:励建荣( 196 4-),男,博士,教授,研究方向:食品、农产品加工与安全。 ) ( 基金项目: 国 家自然科学基金项目(3120 1370) ;辽宁省食品安全重点实验室开放课题(LNSAK F2011027) 资助。 ) 表2:电子鼻实验参数 Table 2 Test parameters of E-nose 项目 采样时间间隔 清洗时间 零点调节时间 连接样品时间 测量时间 进样流量 参数 1.0s 100.0s 5.0s 5.0s 480.0s 300mL/min 莲臭味消除、评定的研究少见。 电子鼻是由具有部分选择性的气敏传感器阵列和适当的模式识别系统组成的人工智能系统。通过挥发性化合物与传感器活性材料表面接触时,发生一系列物理、化学变化产生电信号,接口电路将模拟信号转化为数字信号,经过一系列数据处理和模式识别判断,对被测样品进行鉴别旧。本文旨在探索电子鼻对榴莲果肉中的臭味气体进行定量分析的可行性,建立电子鼻测定榴莲果肉臭味气体的模型,提供一种感官之外的定量评定榴莲臭味的实用方法。 1材料与方法 1.1 材料与仪器 金枕榴莲果肉 购于辽宁省锦州市新玛特超市,八成熟。 FA224型电子天平 上海舜宇恒平科学仪器有限公司;PEN3 型便携隽电子鼻德国 Airsense 公司,其传感器阵列由10个不同的金属氧化物传感器组成,敏感性和选择性达10°~10°级,传感器对某一大类芳香物质响应显著,具体见表1;根据气味标识并利用化学计量统计学软件对不同气味进行快速鉴别,对每一样品进行数据计算和识别,可得到样品的气味指纹图和气味记记 表1电子鼻传感器所对应的香气类型 Table 1 AArrooima types corresponding to sensors of E-nose 阵列序号 传感器名称 性能描述 W1C 芳香成分苯类 2 W5S 氮氧化合物 3 W3C 氨类,芳香成分 4 W6S 氢气 5 W5C 烷烃类芳香成分 6 W1S 甲烷 7 W1W 硫化物 8 W2S 醇类 9 W2W 芳香成分,有机硫化物 10 W3S 烷烃 1.2 实验方法 1.2.1 样品处理 称取0.25g榴莲果肉于小瓶盖(内径12mm,高11mm)中,用粘纸封口(见图1),封口面积为113mm²,在粘纸上打孔(0孔、8孔、16孔),孔径均为0.9mm,从而减小榴莲果肉臭味气体的散发速率,保证电子鼻对臭味气体的检测在短时间内达到平稳状态。然后,将小瓶盖置于50mL广口瓶中,用粘纸将广口瓶密封30min 以富集臭味气体。0孔、8孔、16孔每个水平23个平行样,取每个水平中20个平行样用于 PLS分析建模,3个平行样用于PLS模型验证。 1.2.2 电子鼻检测数据采集 在室温(20℃)下,采 图1小瓶盖及粘纸封口示意图 Fig.1 Diagram of the cap sealed with sticker 用顶空抽样的方法用电子鼻检测,电子鼻实验参数见表2。 从图2可知,样品在478~480s 之间信号曲线较为平稳,本实验用稳定状态下 478~480s 之间的平均信号作为分析的时间点。 图20孔处理传感器响应图 Fig.2Sensor response of the 0 hole 1.2.3 数据分析方法 采用电子鼻自带的 Winmuster软件进行主成分分析(PCA)、负荷加载分析(Loadings)偏最小二乘法分析(PLS)。 通过0孔、8孔、16孔的分组方式,输入经不同孔数处理的样品的相对含量(0、0.8、1.6)。由于榴莲是一种含有多挥发性成分的物质,很难制备出臭味气体浓度一定的标准样品,所以此处输入的相对含量是根据0孔、8孔、16孔三种孔数所成规律而设定的臭味气体含量,即0、0.8、1.6为榴莲果肉经0孔、8孔、16孔处理后释放出臭味气体的相对含量,用 PLS进行回归分析,建立各孔数 PLS 相对含量模型。 2结果与分析2传感器对榴莲果肉挥发性成分的响应 图2~图4分别为榴莲果肉密封后经0孔、8孔、16孔处理,所富集的臭味气体在传感器上相对电导率(G/G0)随检测时间的变化情况。由图2~图4可以看出,在测定初始阶段相对电导率快速变化,192s后逐渐平缓。通过电子鼻传感器对榴莲果肉挥发性物质的响应实验可知,电子鼻对榴莲果肉的挥发性成分有明显响应,并且每一个传感器对其响应值各 不同,见图2~图4中的W1W、W2W、W5S所在位置各不相同。所以,利用 PEN3 电子鼻系统识别榴莲臭味气体可行。 40.01 图3 8孔处理传感器响应图 Fig.3 Sensor response of the 8 holes 图4 16孔处理传感器响应图 Fig.4 Sensor response of the 16 holes 2.2 榴莲果肉臭味气体的 PCA 主成分分析 本文中处理后的榴莲果肉臭味气体用电子鼻检测(1~10传感器),运用PCA分析发现(见图5),不同孔数间相距较远,数据采集点表现出明显的聚集特性,PCA分析法能较好区分三种孔数的样品。般情况下,两个主成分总贡献率之和超过70%~85%,说明其代表的信息全全面。由图5所示,通过 PCA分析得出,第一主成分和第二主成分的总贡献率达到99.49%,所以这两个主成分已基本代表了样品的主要信息。第三、四主成分在区分中不起作用,甚至可能有抵消作用,因此不予考虑。从图5看出,各孔数的组内聚集性较好,在横坐标上的组内距离都很小,部分孔数在纵坐标上组内距离较大,但纵坐标第二主成分的贡献率较小,只有0.78%,所以尽管纵坐标上的距离较大,但实际差别并不大。 当仅仅选择7号传感器对处理后的榴莲果肉臭味气体进行电子鼻检测时,两个主成分总贡献率之和仍超过70%~85%,甚至达到100%。所以,这两个主成分已经代表了样品的主要信息,见图6。 2.3 贡献率分析(Loadings) 观察传感器在 Loadings 分析图中坐标接近零,在实际分析中可以不计该传感器的作用。如果某个传感器的负载参数离零点越远,说明该传感器对样品主成分的贡献率越大. 如图7所示,传感器7(W1W)对第一主成分的贡献最大。据此可知传感器7发挥了较大的作用,而传感器1(W1C)、2(W5S)、3(W3C)、4(W6S)、5 图5 0、8、16孔榴莲挥发性成分的1-10传感器 PCA 主成分分析图 Fig.5 Principal component analysis of durian volatilesubstances detected by 1-10 sensors of PCA of the three processings 图6 0、8、16孔榴莲挥发性成分的7号传感器 PCA 主成分分析图 Fig.6 Principal component analysis of durian volatile substances detected by seventh sensor of the three processings(W5C)、6(W1S)8(W2S)9(W2W)、10(W3S) 发挥的作用较小。传感器7对硫化物最敏感。因此,硫化物是榴莲果肉臭味气体的主要成分6. 图7 1~10 传感器 Loadings 贡献率分析图 Fig.7 Contribution analysis of 1~10 sensors 为了印证7号传感器贡献率,本文只选择7号传感器进行实验,结果见图8,即7号传感器在第一主成分上的比重仍较大。从而进一步说明硫化物是榴莲果肉臭味气体的主要成分。 2.4 榴莲果肉臭味气体的 PLS 预测模型分析 本文运用 Excel 2003 软件及 PLS 构建不同孔数榴莲果肉臭味气体浓度变化的预测模型。由图9所示,以测得的榴莲果肉臭味气体的相对含量(实际值)为纵坐标、电子鼻预测值为横坐标,建立 PLS线性拟合曲线,0孔、8孔、16孔的相对含量拟合的线性 图8 7 号传感器 Loadings 贡献率分析图 Fig.8 Contribution analysis of seventh sensor 相关系数为0.997,可以认为建立的0孔、8孔、16孔的相对含量与电子鼻输出信号之间的 PLS 曲线有较好的线性关系。用模型预测9个未知样品的相对含量,结果见表3,预测0孔、8孔、16孔三种孔数处理后测得的臭味气体相对含量的平均相对误差分别为6.3%、6.5%、6.7%,均小于10%;说明模型较好地预测了0孔、8孔、16孔三种处理后的臭味气体相对含量。 图9 PLS线性拟合曲线 Fig.9 PLS linear fitting curve 表3 PLS模型预测榴莲果肉臭味气体相对含量 Table 3The relative content of theodor of PLS model estimation 样品类别 预测值 实际值 相对误差 (%) 平均相对误差 (%) 0.0375 0.0352 0孔 0.0071 0.0077 6.3 0.0249 0.0238 0.8023 0.8572 8孔 0.7955 0.7421 6.5 0.8722 0.8236 16孔 1.6260 1.5224 1.6177 1.5218 6.7 1.5474 1.6638 3 结论与讨论 3.1 采用电子鼻分析了榴莲果肉挥发性成分,结果表明PEN3 电子鼻系统识别榴莲果肉气味可行。 3.2 采用 PCA对原始数据进行分析,第一主成分和第二主成分的总贡献率达到99.49%,说明 PCA均能准确区分出不同孔数处理过的榴莲果肉样品气味相对含量。 3.3 通过 Loadings 分析证明,硫化物是榴莲臭味气体的主要成分。 3.4 在对榴莲果肉密封后,打0孔、8孔、16孔所测得的臭味气体相对含量的平均相对误差均小于10%,PLS线性拟合曲线的相关系数为0.997,表明PLS 建立的模型可以准确测定榴莲果肉臭味气体相对含量。 ( 参 考文献 ) ( [] 潘 永 贵 . 榴莲 果 实采后生理 品 质变 化 和贮藏技 术.中国 南 方 果 树,2 0 08,37(4 ) :45- 4 7. ) ( [ 2 ] T imkhum m P , T e rdwongworakul A . N on - d e s t ructivec l ass i fication of durian maturity of ‘ Monthon g ’ cu l tivar by meansof visibl e spectrosco p y o f t h e spi n e [] . J Food Eng, 2012, 112 (4) : 2 63-267. ) ( [ ] 阳君. 南 国 水 果 之王 [ ] .中 国果 菜,200 0(1): 2 5. ) ( [4 ] Foo K Y , Hameed B H . Te x tural p o rosity, s urf a ce che m istryand adsorptive p ropertie s o f durian s hell d e r ived act i va t ed ca r bonprepared b y m icrowave a ssiste d N aOH ac t ivat i on [ ] . C hem E ng J,2012,187:53- 6 2. ) ( [5 ]刘冬英,谢剑 锋 ,方少瑛,等 . 榴 莲 的 营 养成 分 分 析[ ] . 广东 微 量元素科学, 2 004 ,11(10 ) :5 7 -5 9 . ) ( [ 6] Bai- Ng ew S , Therdthai N , Dhamvithee P. C ha r acteri z at i on o f mic r owave vacuum-dried d urian chips [ ].J Food Eng,2011,104 ( 1 ): 1 14-1 22. ) ( [ ]李 冬 梅, 尹凯 丹 . 榴 莲的 保健 价值和 加工利 用[] .中国食 物与 营养 , 20 09(3): 3 2-3 3 . ) ( [ 8] Olivieri J, Quiliquini-Chambard A M, Hauser C. A l l e rgy t odurian []. A ll e rgy,2002,57( 3 ) :26 3-263. ) ( [9 ] 王鹭 .臭不 可 闻 的水果 之王 [ . 国际 市场 ,2 002(8):4 5. ) ( [1 0 ] 环 球时 报.泰 国 人对榴莲又爱 又 怕 [ .旅游纵览(行业 版), 2011( 4 ) : 7. ) ( [1 1] 马勇 ,刘 水 琳, 张 晓莉,等.臭 氧消除 莲莲果 肉 臭味 的研 究. 中 国食品学 报,2 01 3,13(10) : 121-125 . ) ( [1 2]费雅君,白雪, 康 小 红.LDA优 化 电 子鼻传感 器 阵列的 研 究 [ ]. 食品与 机械, 2 01 2,28(1): 9 7-100. ) ( [1 3] 赵 国群,姚瑶,关军 锋 . 鸭 、 雪梨 果醋香 气成分的 电子 鼻分 析 []. 食 品工 业科 技,201 3,34(22 ) :62-65. ) ( [1 4 ] 田怀香,孙宗宇 . 电子鼻在 金华 火腿香精识 别中 的应用 [ ].中 国调 味 品 ,2 0 08(11): 6 1-64. ) ( [1 5 ] 胡 桂 仙, 王 俊, 海 铮,等.不同 储藏时 间 柑 橘 电子 鼻 检 测 研究[ .浙 江农业学报, 2 00 6,18(6):4 5 8-461. ) ( [1 6]张博, 李 书倩,辛广,等 . 金枕榴 莲 果实各部位挥 发性 物 质成 分GC/MS分 析 [J ] . 食品研究与开发,201 2,33(1) : 130-134. ) 第 电子鼻测定榴莲果肉臭味气体的模型建立及应用《食品工业科技》 马勇,刘水琳,汤轶伟,励建荣(渤海大学化学化工与食品安全学院,辽宁锦州121013) 摘要:利用PEN3便携式电子鼻检测榴莲果肉的臭味响应值,并运用密封、打孔的方法使信号曲线能较快的达到平稳状态。通过PCA分析确定榴莲果肉臭味的第一主成分和第二主成分的总贡献率达到99.49%,而且0孔、8孔、16孔三种不同孔数处理的榴莲果肉臭味有明显差异,所以,电子鼻识别榴莲果肉臭味可行;通过Loadings分析认为硫化物是榴莲果肉臭味气体的主要成分;根据检测到的数据,利用PLS法建立了榴莲果肉臭味气体相对含量的模型,运用统计软件建立了PLS线性拟合曲线,得到0孔、8孔、16孔的相对含量拟合的线性相关系数为0.997,说明榴莲果肉臭味气体相对含量与电子鼻输出信号之间有较好的线性关系;测得0孔、8孔、16孔的相对含量的平均相对误差均小于10%。因此,本文所建模型可准确地测定榴莲果肉臭味气体的相对含量,从而提供一种评定榴莲臭味的实用方法。关键词:电子鼻、榴莲臭味、PLS模型
关闭还剩2页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《榴莲果肉中气味分析检测方案(感官智能分析)》,该方案主要用于其他水果制品中营养成分检测,参考标准《暂无》,《榴莲果肉中气味分析检测方案(感官智能分析)》用到的仪器有德国AIRSENSE品牌PEN3电子鼻。
