挥发性脂肪酸在BP-FFAP上的分离与检测 min GC: Agilent 5890 w/ FID Column: NanoChrom BP-FFAP Dimension: 30mx0.25mmx0.25um Cat no: G2125-3002 Oven: 80℃ 1min 20℃/min to 120℃ 6℃/min 205℃ 2min Carrier: Hydrogen, 8psi Inlet: Split, 240 ℃, split flow 50ml/min Detector: FID 260℃ Samples: Free Fatty Acids Test Standard (Cat.#:35272) Inject volume: 1ul Peak# compound Retention Time 1 Acetic acid 4.35 2 Propionic acid 5.064 3 Isobutyric acid 5.299 4 Butyric acid 5.938 5 Isovaleric acid 6.373 6 Valeric acid 7.199 GC: Agilent 5890 w/ FID Column: NanoChrom BP-FFAPDimension: 30m×0.25mm×0.25umCat no: G2125-3002Oven: 80℃ 1min 20℃/min to 120℃ 6℃/min 205℃ 2min Carrier: Hydrogen, 8psiInlet: Split, 240 ℃, split flow 50ml/minDetector: FID 260 ℃Samples: Free Fatty Acids Test Standard(Cat.#:35272)Inject volume: 1ul
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《挥发性脂肪酸中分离检测方案 》,该方案主要用于其他中理化分析检测,参考标准《暂无》,《挥发性脂肪酸中分离检测方案 》用到的仪器有纳谱分析 NanoChrom BP-FFAP 强极性毛细管柱。
