邻苯类物质在NanoChrom BP-5MS上的分离与检测 Column: NanoChrom BP-5MS Dimension: 30mx0.25mmx0.25um Carrier: Hydrogen, flow 1.5ml/min Inlet: Split, 275℃, split flow 60ml/min Oven: 80°C (hold 0.5 min) to 160 °℃ at 30 °C/min, to 240 ℃(hold 2min) at 15 ℃ /min to 320C(hold 1min) at 8 °C/min. Inject volume:EPA 8061 standard 1ul Detector: FID 325℃ Peak Compound Chinese Name Elution Time Resolution 1 Dimethylphthalate 邻苯二甲酸二甲酯 5.799 2 Diethylphthalate 邻苯二甲酸二乙酯 6.807 3 Phthalic acid diisobutyl ester 邻苯二甲酸二异丁酯 8.791 4 Di-n-butylphthalate 邻苯二甲酸二丁酯 9.462 5 Bis(2-methoxyethyl)phthalate 邻苯二甲酸二甲氧乙酯 9.753 6 Bis(4-methyl-2-pentyl) phthalate 邻苯二甲酸二甲氧乙酯异构体 10.403 ISomer 7 Bis(4-methyl-2-pentyl)phthalate 邻苯二甲酸双-4-甲基-2-戊酯 10.435 1.35 8 Bis(2-ethoxyethyl)phthalate 邻苯二甲酸二乙氧乙酯 10.711 9 Diamyl phthalate 邻苯二甲酸二戊酯 11.078 10 Di-n-hexyl phthalate 邻苯二甲酸二己酯 13.046 11 Benzyl butyl phthalate 邻苯二甲酸丁苄酯 13.241 12 Bis(2-n-butoxyethyl)phthalate 邻苯二甲酸二丁氧乙酯 14.400 13 Phthalic acid dicyclohexyl ester 邻苯二甲酸二环己酯 15.088 14 Bis(2-ethylhexyl)phthalate 邻苯二甲酸二辛酯 15.155 2.07 15 Dipentylphthalate 邻苯二甲酸二戊酯 15.445 16 Di-n-octyl phthalate 邻苯二甲酸二辛酯 17.005 17 Di-nonyl phthalate 邻苯二甲酸二壬酯 18.863 Peak CompoundChinese NameElution TimeResolution1Dimethylphthalate 邻苯二甲酸二甲酯5.7992Diethylphthalate 邻苯二甲酸二乙酯6.8073Phthalic acid diisobutyl ester 邻苯二甲酸二异丁酯8.7914Di-n-butylphthalate 邻苯二甲酸二丁酯9.4625Bis(2-methoxyethyl)phthalate 邻苯二甲酸二甲氧乙酯9.7536Bis(4-methyl-2-pentyl) phthalate isomer 邻苯二甲酸二甲氧乙酯异构体10.4037Bis(4-methyl-2-pentyl)phthalate 邻苯二甲酸双-4-甲基-2-戊酯10.4351.358Bis(2-ethoxyethyl)phthalate 邻苯二甲酸二乙氧乙酯10.7119Diamyl phthalate邻苯二甲酸二戊酯11.07810Di-n-hexyl phthalate 邻苯二甲酸二己酯13.04611Benzyl butyl phthalate 邻苯二甲酸丁苄酯13.24112Bis(2-n-butoxyethyl)phthalate 邻苯二甲酸二丁氧乙酯14.40013Phthalic acid dicyclohexyl ester 邻苯二甲酸二环己酯15.08814Bis(2-ethylhexyl)phthalate 邻苯二甲酸二辛酯15.1552.0715Dipentylphthalate 邻苯二甲酸二戊酯15.44516Di-n-octyl phthalate 邻苯二甲酸二辛酯17.00517Di-nonyl phthalate 邻苯二甲酸二壬酯18.863
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《邻苯中分离检测方案 》,该方案主要用于苯及其衍生物中组成分析检测,参考标准《暂无》,《邻苯中分离检测方案 》用到的仪器有纳谱分析 BP-5MS气相柱 弱极性毛细管柱。
