Process Technology工艺技术 彩色蔬菜面的制作工艺及其品质分析 Processing Technology and Quality Analysis of Colorful Vegetable Noodles ◎陈育楷,高婷婷,陈蔚辉 (韩山师范学院潮菜学院,广东 潮州 521041) CHEN Yukai, GAO Tingting, CHEN Weihui (College of Chaozhou Food Hanshan Normal University,Chaozhou 521041, China) 摘 要:为探讨蔬菜面的制作工艺及其感官品质,,以红椒汁、姜黄汁、白萝卜汁、红菜头汁和苋菜汁为辅料制作蔬菜面,采用质构仪测定其质构特性,观察评价各种蔬菜面的着色力和热稳定性,筛选蔬菜汁的最佳浓度。结果显示,,各种蔬菜汁面着色力和热稳定性均随浓度的增加而增强,尤以姜黄面最为突出;各种蔬菜面配方中蔬菜汁的最佳浓度分别为姜黄汁20%(黄色面)、红椒汁20%(橙色面)、白萝卜汁60%(白色面)、红菜头汁 60%(紫色面)、水煮苋菜汁40%(粉色面)、鲜榨苋菜汁20%(灰色面)。与市售菠菜面比较,研发的蔬菜面黏结力更强,更耐咀嚼。 关键词:蔬菜汁面;制作工艺;质构特性;感官品质 Abstract: In order to explore the processing technology and sensory quality of vegetable juice noodles, red pepperjuice, turmeric juice, white radish juice, cabbage juice and amaranth juice were used as supplementary materials to makevegetable juice noodles. The texture characteristics of vegetable juice noodles were determined by texture analyzer, thedyeing power and thermal stability of vegetable juice noodles were evaluated by observation, and select the optimumconcentration of vegetable juice.The results showed that the dyeing power and thermal stability of vegetable juice noodlesincreased with the increase of concentration, especially the turmeric noodles. The optimum concentrations of vegetable juicein various vegetable noodle recipes are turmeric juice 20% (yellow noodles), red pepper juice 20% (orange noodles), whiteradish juice 60% (white noodles), red cabbage juice 60% (purple noodles), poached amaranth juice 40% (pink noodles)and fresh celery juice 20%(grey noodles). Compared with market spinach noodles, the developed vegetable noodles havestronger adhesive force and are more chewable. Keywords: vegetable juice noodles; processing technology; texture characteristics; sensory quality 中图分类号:TS213.2 蔬菜面是面条的一个分支,是利用蔬菜汁与面粉混合制作而成,它既增加了面条维生素、膳食纤维、矿物质等蔬菜的营养物质,也在一定程度上改变了面条的感官品质。蔬菜面以色彩丰富、营养健康而备受 到大众青睐。 目前,有关蔬菜面也有许多相关的研究报道,郭峰等11-2J介绍了南瓜面条、菠菜面条、胡萝卜面条和紫甘蓝面条的制作方法;周坚等③针对蔬菜面的着色 问题进行了较为详细的研究;何永进4通过调查研究认为蔬菜汁的市场潜力很大;王白鸥介绍了日本蔬菜汁市场的发展情况;张甜等6研究指出,在牛肉灌肠制作中,发酵蔬菜汁可以替代化学合成亚硝酸盐;侯丽丽等报道了芹菜黄瓜复合蔬菜汁的最佳配方;魏文静等18]探讨了减肥降压复合蔬菜汁的制备;王艳哲等指出蔬菜汁不仅能够提供身体所需营养,还具有一定的排毒功效。蔬菜汁在日常应用很广,有人选择天然蔬菜汁制作成彩色豆腐[10-12]和蔬菜面包[13]给孩子作为辅食。国外对于蔬菜面也有相关报道,超市上有紫甘蓝、胡萝卜、番茄等蔬菜面上架,许多家庭主妇也会自制蔬菜面给家人及朋友品尝[14-15],然而比较系统探讨蔬菜面的制作工艺及其感官品质,迄今未见报道。 本文以红椒、姜黄、白萝卜、红菜头和苋菜等蔬菜汁为辅料制作彩色蔬菜面,观察各种蔬菜汁的着色力和热稳定性,测定蔬菜面的质构特性,探讨彩色蔬菜面的最佳制作工艺和感官品质,为蔬菜面产业的发展提供一些理论参考。 1 材料与方法 1.1木材料与设备 本试验选用了5种蔬菜,分别为红椒( C.annuum var.grossum),又称红色灯笼椒,用于榨取橙色蔬菜汁;姜黄(Curcuma longa),用于榨取黄色蔬菜汁;白萝卜(Raphanus sativus),用于榨取白色蔬菜汁;红菜头( Beta vulgaris var.rapacea),别名红萝卜,用于榨取紫色蔬菜汁;苋菜(Amaranthus tricolor),榨取的蔬菜汁呈灰绿色,将其煮沸则呈粉紫色。所有蔬菜均购自潮州市大润发超市,挑选新鲜、完整、色泽鲜艳的蔬菜。面粉,购自潮州市大润发超市。 TMS-PRO型质构仪(美国FTC公司)、榨汁机、 厨师机、小型压面机、擀面杖和刮板。 1.2蔬菜汁的制作 1.2.1 榨制蔬菜汁 将选择好的蔬菜切成1 cm× 1 cm 小块。将蔬菜小块放入榨汁机中,加入一定比例的水,榨成汁。过滤掉榨渣,将余下蔬菜汁液体装好,即成。 1.2.2 煮制蔬菜汁 将选择好的蔬菜洗干净,将洗好的蔬菜与水按比例放入锅中,水烧开即可。过滤掉多余菜叶,将余下蔬菜汁液体装好,即成。 1.3彩色蔬菜面的工艺流程 ①将120g面粉放在厨师机中。②将制作好的蔬菜汁(55g)的1/3加入面粉中,搅动面粉进行混合。③揉面,将剩下的蔬菜汁分多次加入面粉中。④将面团揉均匀至表面光滑无面疙瘩。⑤将揉好的面团用擀面杖擀薄,成长方形,放入压面机中,调好档位,由厚到薄将长方形的面片压成2 mm 的厚度。⑥将长面片放入压面机的压面条口处,得到长面条。⑦将水煮沸,放入做好的长面条,煮3~5 min, 面条中间没有硬芯。⑧将刚煮好的面条过冷水,保证其弹性,装盘即可。 1.4蔬菜面质构分析方法 采用 TMS-PRO 质构仪进行质构分析,选用参数为1000N探头,测速60 mmmin,触发力2N,变形率50%。测定蔬菜面的弹性、硬度、黏附性、内聚性、胶黏性和咀嚼性等质构指标。为保证面条受力均匀,将待测定面条按曲别针形式进行折叠,使其保持相同的横截面和厚度。实验重复3次,实验结果以平均值±标准差表示。 1.5蔬菜汁面的感官评价方法 挑选10位感官评价员,将制作好的6种蔬菜汁面成品每种选取15 g,依次让感官评价员品尝,并根据表1所述标准,给予评分。 表1 蔬菜汁面的感官评价表 评价标准 面条名称 总分/分 颜色(评分) 气味(评分) 滋味(评分) 触感(评分) 无颗粒感, 面条分明,不黏结,深黄色有明显浓郁姜黄味道软硬度适中,比例适中,有明显弹性 (4~5分) (4~5分) 味道良好(4~5分) (4~5分) 姜黄面 面条分明,不黏结,黄色 有淡淡姜黄味道 偏软或偏硬,不涩口 无颗粒感, 20 (2~3分) (2~3分) (2~3分) 弹性小(2~3分) 面条不分明,易黏结, 没有姜黄味道 过软或过硬,涩口 有颗粒感, 浅黄色(0~1分) (0~1分) (0~1分) 弹性小或没有(0~1分) (续表1) 2 结果与分析 2. 蔬菜汁的最佳添加量分析 般人难以接受,并且姜黄略带苦味,所以,姜黄面中的姜黄汁含量要适度。由图1可以看出,20%的姜黄汁制作的姜黄面感官评分最高,最符合大众口味需求。 为了探究面粉与水配比的契合程度,取120g中筋面粉,分别与 45 g、50 g、55 g、60g4个梯度的水量进行混合搅拌。结果表明,水55g契合程度最高,面粉与水完全混合后,面团成型,软硬适中,表面光滑,因此和面的蔬菜汁(水溶液)确定为 55 g。 分别取 0%、20%、40%、60%、80%5个梯度的蔬菜汁与120g中筋面粉和面,评价制作的面条品质,确定最佳的蔬菜汁浓度,结果如下。 姜黄汁含量/(%) 2.1.1 黄色姜黄面 图1 姜黄面的感官评价图 姜黄具有极佳的上色能力和特殊的气味。,一旦姜黄汁含量过高,姜黄面成品中就会具有浓郁姜黄味道, 2.1.2 橙色红椒面 红椒具有特殊的辛辣气味,一旦红椒汁含量过高, 橙色红椒面成品中就会具有浓烈的红椒味,一般人难以接受,并且红椒偏辣,所以,红椒面中的红椒汁含量要适度。由图2可见,20%的红椒汁制作的红椒面感官评分最高,为最佳添加量。 红椒汁含量/(%) 图2 红椒面的感官评价图 2.1.3 白色萝卜面 萝卜白色,在上色程度上远远不如其他种类的蔬菜面,但萝卜含水量丰富,适宜榨汁,且萝卜具有独特的清香味,萝卜汁含量越高,萝卜面成品萝卜味越浓,越受大众喜欢,所以,萝卜面中萝卜汁含量可以适当提高。由图3可以看出,60%的萝卜汁含量加工得到的萝卜面感官评分最高,为最佳添加量。 萝卜汁含量/(%) 图3 萝卜面的感官评价图 2.1.4 紫色红菜头面 红菜头颜色紫红,含水量丰富,适宜榨汁和上色,和面后呈紫色。红菜头汁含量越高,红菜头面成品红菜头味越浓,大众越喜欢,所以,红菜头面中的红菜头汁含量可以适当提高。由图4可见,60%的红菜头汁含量加工得到的红菜头面感官评分最高,最符合大众口味需求。 姜黄汁含量/(%) 图4 红菜头面的感官评价图 2.1.5 粉色苋菜面 水煮的苋菜汁呈粉紫色,且具独特的青叶味,其在面条上的上色为粉色,十分靓丽。苋菜汁含量越高,面条苋菜味越浓。由图5可见,40%的水煮苋菜汁含量加工得到的苋菜面感官评分最高。 水煮苋菜汁含量/(%) 图5 水煮苋菜面的感官评价图 2.1.6 灰色苋菜面 鲜榨苋菜汁呈灰绿色,其在面粉上显色为灰色。鲜苋菜榨出的汁液较少,和面时苋菜汁含量越高,成品苋菜味越浓郁,一般人较为喜欢,但考虑到成本问题,鲜榨苋菜汁面中的苋菜汁含量要适宜。图6表明,20%的鲜榨苋菜汁含量是制作灰色苋菜面的最佳浓度,获得最高的感官评分。 鲜榨苋菜汁含量/(%) 图6 鲜榨苋菜面的感官评价图 2.2 各种蔬菜汁面的着色力比较 从图7可以看出,除了萝卜面,因萝卜汁颜色与面条颜色相近,难以分辨白色的着色程度,其余5种蔬菜汁面均随蔬菜汁含量的增加,着色力稳步增大,尤其是姜黄面,在添加了20%的蔬菜汁后,着色力急剧上升,之后着色力一直领先其他蔬菜汁面,最为显色。 图7 各种蔬菜汁面的着色力比较图 2.3各种蔬菜汁面的热稳定性分析 图8由实验得出,面条在进行加热的过程中,依从表2的数据可以得知,研制的蔬菜汁面与市面然根根分明,没有分散或是断裂,也没有溶解和破碎。 上售卖的菠菜面在质构特性方面存在一定的差异性,不过随着温度的升高,天然的植物色素会有部分溶解 研制的蔬菜汁面弹性相较于菠菜面略小,但差异性并在水中,致使面条颜色变淡,但随着蔬菜汁含量的增加, 不显著,而黏附性则比菠菜面大得多;两者的内聚性面条仍然有明显的着色。其中红椒面、萝卜面、红菜和胶黏性相差不大;研制的蔬菜汁面在硬度和耐嚼性头面、水煮苋菜面和鲜榨苋菜面5种面条都随着蔬菜 上比菠菜面更佳。汁含量的增加,其颜色在沸水中不断增强,而姜黄面则不轻易褪色,以20%姜黄汁制作的姜黄汁面在沸水煮熟后仍然保持面条的完整性以及颜色的固定性。 本试验以姜黄汁、红椒汁、红菜头汁、白萝卜汁和苋菜汁为辅料,研制出黄、橙、紫、白、粉、灰等6种颜色的蔬菜面;各种蔬菜面配方中蔬菜汁的最佳浓度分别为:黄色面的姜黄汁20%、橙色面的红椒汁20%、白色面的白萝卜汁60%、紫色面的红菜头汁60%、粉色面的水煮苋菜汁40%及灰色面的鲜榨苋菜汁20%;各种蔬菜汁在面条制作过程的着色力和热稳定性均随浓度的增加而增强,尤以姜黄面最为突出;与市售菠菜面比较,研发的蔬菜面在胶黏性、内聚性、弹性方面较为接近,而硬度、黏附性、咀嚼性方面,差异较大,研发的蔬菜面黏结力更强,也更耐咀嚼。 图8 各种蔬菜汁面的热稳定性比较图 2.4 各种蔬菜汁面的质构特性分析 3结论 表2各种蔬菜汁面的质构特性比较表 类型 硬度 黏附性 内聚性 弹性 胶黏性 咀嚼性 菠菜汁面 25.30±1.02a 0.30±0.06a 0.55±0.01a 1.84±0.04a 14.10±1.23a 26.06±1.01a 红椒汁面 34.57±0.32b 2.37±0.01b 0.53±0.01a 1.54±0.03a 17.07±1.01a 37.09±2.31b 姜黄汁面 33.50±0.53b 2.07±0.03b 0.53±0.02a 1.63±0.01a 17.33±0.92a 43.28±1.04c 萝卜汁面 32.40±1.51b 2.30±0.05b 0.58±0.03a 1.63±0.01a 15.98±0.53a 41.28±2.35c 红菜头汁面 34.67±1.01b 2.11±0.01b 0.53±0.01a 1.53±0.05a 15.00±1.42a 35.08±2.01b 苋菜汁面 (水煮) 32.10±0.63b 2.20±0.08b 0.58±0.01a 1.56±0.01a 14.90±1.01a 34.48±0.65b 苋菜汁面 (鲜榨) 30.93±0.12b 2.42±0.06b 0.59±0.04a 1.47±0.03a 14.70±0.94a 34.22±0.41b ( 参考文献 ) ( [1]佚名.面条变色记[J].农村百事通,2009(6): 56. ) ( [2]小莉,燕子.冯虹:让你碗里出彩虹[J].理财杂 志,2006(1):4 2 -44. ) ( [3]周坚,徐群英.蔬菜面条的研制[J].粮食与饲料 工业,1996(9):4 1 -42. ) ( [4]何永进.蔬菜汁 市 场潜力大[J].湖南农业,2003 (6): 5 . ) ( [5 ] 王白鸥.日本的蔬菜汁市场发展带给我们的启发 ) ( 与思考[J].饮料工业,2006(9):41-45. ) ( [6]张甜,关倩霞,杨华.发酵蔬菜汁替代亚硝酸盐在牛肉灌肠中的应用 [J].食品研究与开发,2016,37 (9) :2 3- 2 8. ) ( [ 7 ]侯丽丽,陈洪海,蔡敏杰 , 等.芹菜黄瓜复合蔬 菜汁的研制[J].饮料工业,2014,17 ( 1):11-14. ) ( [8]魏文静,李悦,宋翔.减肥降压复合蔬菜汁的制备及研究[J].食品研究与开发, 2 016,37(8): 86-88. ) ( (下转第157页) ) 向社会传播,但是对这些文化的进行挖掘整理创新也蕴含着一定的潜在危险,有可能让一些传统文化“走样”。因此,必须牢牢把握时代文化发展的方向,即“迈入新时代,践行新精神”,,以社会主义核心价值观为指引,才能继续彰显蓬勃的发展动力,展示传统桂菜烹调文化的旺盛生命力。 ( 参考文献 ) ( [ 1 ]娜日苏,赛娜.蒙古传统奶制品制作技艺的发展 研究[ J ].中国食品,2018(1 1 ):148-1 5 0. ) ( [2]王屹,王立高.民族文化传承人才培养的探索与实践:以广西中职民族文化传承师范特色项目建设为例[J].职业技术教育,20 1 7,38(6):62-66. ) ( (上接第145页) ) ( [9]王艳哲,董丽萍,彭辉,等.胡萝卜彩色营养功能性面条的工艺研究[J].粮油加工,2008(3):87-89. ) ( [10]王亮 , 张悠, ,王蓉.3种天然彩色豆腐的加工 工 艺[J].无锡轻工大学学报,200 2 (3):264-267. [ 11]安辛欣.彩色蔬菜汁豆腐的研制 [J].南京农业 大学学报,1995(1):10 9 -110. [12]冯紫慧,庄志发,赵超.彩色菜汁豆腐的研制生 产技术 [J].大豆科学,20 0 5(3):84 - 86. ) ( [13]唐仕华.蔬菜面包将受欢迎[J].新农业,1994 (2):6. ) ( [3]曾淑叶.电子制造业新产品导入项目管理流程研 究[J].数码世界,2016(9):97-98. ) ( [4]覃鸿鸿.基于“大师工作室”为载体的民族地区职业教育人才培养模式探索: 以艺术设计类专业为例 [J] . 北方文学,2 0 18( 1 5): 1 51-152. ) ( [ 5 ]于新建.谈高职室内设计专业学生审美素质的重 要性[J].美术大观,2013(12):1 8 2. ) ( [6]郭涛.高职测绘类专业现代学徒制课程体系的理论与实践研究 [J].北京城市学院学报,2017(3): 83-86. ) ( [7]钱静.中国历史教师教育专业研究[D].金华:浙江师范大学,2006. ) ( [14]VADIVELOO M , PRINC I PATO L, MORWITZV, et a l .Sensory y variety inn shape and colorinfluences fruit a nd v egetable intake, l i k ing,and purchase intentions i in some subsetso of adults: A randomized pilot e xperi m ent[J]. F ood Quality and Preference, 2019, 7 1:301-310. ) ( [15 ] CHOI Y J, LEE l D H, KIM M H S, et al . An exploratory study o n t he effect of daily f r uits and vegetabl e j uice o n human gut microbiota[J]. Food Science and Biotechnology, 2018 , 27(5):1377-1386. ) 一粒米,千滴汗,粒粒粮食汗珠换。 (C)China Academic Journal Electronic Publishing House. All rights reservedxlANEAISHPIN现代品/ (现代品XANDAiSHiPIre Journal Electronic Publishing House. All rights reserved. http://www.cnki.net 本文以红椒、姜黄、白萝卜、红菜头和苋菜等蔬菜汁为辅料制作彩色蔬菜面,观察各种蔬菜汁的着色力和热稳定性, 测定蔬菜面的质构特性, 探讨彩色蔬菜面的最佳制作工艺和感官品质, 为蔬菜面产业的发展提供一些理论参考。检测设备:TMS-PRO 型质构仪( 美国 FTC 公司)蔬菜面质构分析方法采用 TMS-PRO 质构仪进行质构分析, 选用参数为 1 000 N 探头, 测速 60 mm·min-1, 触发力 2 N, 变形率 50%。 测定蔬菜面的弹性、 硬度、 黏附性、 内聚性、胶黏性和咀嚼性等质构指标。 为保证面条受力均匀,将待测定面条按曲别针形式进行折叠, 使其保持相同的横截面和厚度。 实验重复 3 次, 实验结果以平均值± 标准差表示。各种蔬菜汁面的质构特性分析从表 2 的数据可以得知, 研制的蔬菜汁面与市面上售卖的菠菜面在质构特性方面存在一定的差异性,研制的蔬菜汁面弹性相较于菠菜面略小, 但差异性并不显著, 而黏附性则比菠菜面大得多; 两者的内聚性和胶黏性相差不大; 研制的蔬菜汁面在硬度和耐嚼性上比菠菜面更佳。文联来源:韩山师范学院
关闭还剩4页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《彩色蔬菜面中制作工艺及其品质分析检测方案(质构分析仪)》,该方案主要用于挂面中前处理检测,参考标准《暂无》,《彩色蔬菜面中制作工艺及其品质分析检测方案(质构分析仪)》用到的仪器有FTC-质构仪TMS-PRO。
