KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIQ-00115enL电话:021-54488867网址:http://www.kem-china.com-K-MKYOTO ELECTRONICSMANUFACTURING CO.,LTD. Application Memo Quantification of TMAH Industry Inorganic chemical industryInstrument Automatic potentiometric titratorMeasurement method Acid-base titration Standards 1.Overview TMAH (tetramethyl ammonium hydroxide) is measured by titration with 0.1mol/Lhydrochloric acid after the test sample is diluted with water. The endpoint is determined byLevel Stop which is previously selected and preset in the titration system. The concentrationof TMAH is calculated from the titration volume of hydrochloric acid solution. 2. Apparatus Main unit Automatic potentiometric titrator (preamplifier STD) Electrode pH glass electrode Ceramic reference electrode Temperature compensation electrode 3.Reagents Titrant 0.1mo1/L hydrochloric acid solutionSolvent Pure water 4. Example Sample Titer TMAH (g) (mL) (%) 1 2 3 3.0009 7.8519 2.3850 3.0244 7.9150 2.3855 3.0302 7.9286 2.3851 AverageSD RSD(%) 2.3852 0.0003 0.01 Titration curve- Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《显影液四甲基氢氧化铵中浓度检测方案(自动电位滴定)》,该方案主要用于其他中化学性质检测,参考标准《暂无》,《显影液四甲基氢氧化铵中浓度检测方案(自动电位滴定)》用到的仪器有AT-710M四通道旗舰型自动电位滴定仪、AT-710S豪华型自动电位滴定仪。
我要纠错
