检测样品 其他饮料
检测项目 理化分析
二氧化碳气容量分析仪测量含苏打水威士忌中的二氧化碳和空气含量 应用资料在威士忌的装瓶过程中,二氧化碳气容量和空气含量的测量对于产品的质量控制至关重要。本应用使用二氧化碳气容量分析仪测量市售含苏打水威士忌中的二氧化碳和空气含量。京都電子工業株式会社KYOTO ELECTRONICSAPET-0150erMANUFACTURING CO.,LTD. APET-0150en Application Note Measurement of Gas volume and Air content in whiskywith soda by Gas Volume Analyzer IndustryFood & beverageInstrumentGas Volume and Air Content AnalyzerMeasurement method:Gas volume measurement methodStandardsGB/T 10792 1.Scope On the bottling process of whisky with soda manufacturing, measurement of gas volume and aircontent are essential for quality control of products. This application note introduces the measurementexample of gas volume and air content in commercially-available whisky and with soda by using theGas Volume and Air Content Analyzer. 2. Precautions 1) This measurement requests uses of 6mol/L sodium hydroxide aqueous solution. Contact with eyesmay cause blindness. Be sure to wear protective goggles during handling. 2) The measurement instruments and the measurement samples should be temperature-stabilized at20°C. 3) Either instrument air system or an air compressor is necessary for piercing and rotation of samplebottle/can. (Pressure: 0.490 to 0.686 MPa (5 to 7 kgf/cm²)). 3. After measurement 1) Samples should be disposed properly after measurement is completed. 2) The measurement instruments should be rinsed properly after the end of the day. 4. Apparatus Gas Volume and Air Content Analyzer 5. Reagents ●6 mol/L sodium hydroxide solution Pure water 京都电子工业株式会社-可睦电子(上海)商贸有限公司上海市徐汇区宜山路333号1201室电话:021-54488867 电邮: kemu-kem@163.com网址: http://www.kem-china.com 6. Procedure 1)Select“gas volume / gas pressure+ air content measurement (GV/P+AIR)”on themeasurement mode, and enter the following parameters into the measurement conditions. Note that below measurement parameters is an example and optimizing these parameters might be necessarydepending on sample’s property. ·Mode :GV/P+AIR ·GV/P Cal. : Soft ·Method Sniff. Level :0.015MPa E-Sni. Level :0.015MPa Trial Count :6 Press Level :0.010MPa Rot 4-1 :0 Sec Wait 4 :0 Sec Rot 4-2 :120 Sec Rot 4-3 :25 Sec 2) Set the sample bottle/can on the sample stage and press the Start button.For details, refer to the operation manual. 7.Example Table 1 shows the measurement results of whisky with and soda. Table 1. Measurement result list of whisky with and soda Sample No. Gas Volume (v/v) Air Volume (mL) Gas Press (MPa) Press (MPa) Temp.(C) whiskywith andsoda 1 2.98 2.04 0.243 0.199 15.4 2 2.96 1.87 0.241 0.200 15.7 3 2.91 1.77 0.234 0.191 15.3 Ave. 2.95 1.89 0.239 0.197 15.5 SD 0.04 0.14 0.005 0.005 0.2 RSD(%) 1.22 7.21 1.98 2.51 1.29 whiskywith andsoda withfruit juice 1 2.96 1.49 0.241 0.196 15.3 2 2.96 1.24 0.241 0.198 15.5 3 3.00 1.29 0.244 0.204 15.8 Ave. 2.97 1.34 0.242 0.199 15.5 SD 0.02 0.13 0.002 0.004 0.3 RSD (%) 0.78 9.87 0.72 2.09 1.94 Measurement items Gas Volume : Carbon dioxide volume (mL) of 1mL sample volume Air Volume : Gas volume except carbon dioxide in sample bottle/can (mL) Gas Press : Converted pressure in sample bottle/can at 20 ℃ (MPa) Press : Measured pressure (MPa) Temp. : Measured sample temperature (C) 8.Summary Measurement of gas volume and air content in commercially-available whisky with soda wasperformed with good repeatability by using the Gas Volume and Air Content Analyzer. 京都电子工业株式会社-可睦电子(上海)商贸有限公司电话:021-54488867 电邮: kemu-kem@163.com 都電子工業株式会社KYOTO ELECTRONICSMANUFACTURING CO.,LTD
关闭还剩1页未读,是否继续阅读?
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《苏打水威士忌中二氧化碳气容量检测方案(饮用酒检测仪)》,该方案主要用于其他饮料中理化分析检测,参考标准《暂无》,《苏打水威士忌中二氧化碳气容量检测方案(饮用酒检测仪)》用到的仪器有GVA-710全自动饮料二氧化碳气容量测定仪。
