塑料中水分含量的测定 应用资料使用卡尔费休法水分测量是世界上普遍采用最可靠的水分测定方法。在许多官方标准中,如: ISO、ASTM、DIN、BS、JIS和GB的试验方法中采用了该程序。塑料样品很难溶于卡尔费休试剂中,因此通常采用加热炉蒸发样品中水分的间接方法。首先在加热炉中加热测试样品,并通过载气将蒸发的水分转移到溶剂中,根据标准测试方法通过库仑电量法或容量滴定法进行水分滴定。本次测量的测试样品如下: 尼龙6、聚碳酸酯、聚乙烯、ABS树脂。KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.KVX-01531-enLK-MKYOTO ELECTRONICSMANUFACTURING CO.,LTD. Application MemoMoisture of Plastics IndustryInstrumentMeasurement method Plastic. Rubber Karl Fischer Moisture Titrator Standards : JIS K0113, ASTM E203, ASTM D6869, ISO 760, ISO 15512 1.Overview Moisture titration using Karl Fischer reagent is popularly practiced water determinationworldwide as the most reliable method. The procedure is adopted in many official standards astest method specified in ISO, ASTM, DIN, BS and JIS. Plastic samples are hard to dissolve inKarl Fischer solvent, and therefore, the indirect method using an oven to evaporate moisturein sample is generally practiced. The test sample is first heated in the oven, and the evaporatedmoisture is transferred to solvent by carrier gas where moisture titration is performedaccording to JIS K 0113-2005 Standard Test Method by Potentiometric, Amperometrtic,Coulometric and Karl Fischer Titration For indirect method, the extracting solvent ME fromRiedel de Haen is used. Test samples measured this time are as follows: Nylon 6, Polycarbonate, Polyethylene, ABS resin 2. Apparatus Main unit Karl Fischer moisture titration volumetric system Electrode Twin platinum electrode for KF titration Option: Water evaporator 3. Reagents Reagent Hydranal Composit 2 (Riedel de Haen) Solvent: Extracting medium ME (for gas)(Hayashi Chemicals) 4. Example -Measurement results-. Sample name扣 Sample(g)。 Solvent。 Oven(℃)。 Water content mg· % Nylon 6。 0.214 ME。 150。 4.47。 2.09。 Polycarbonate。 2.498。 ME。 150。 3.23。 0.13。 Polyethylene。 2.944。 ME· 130。 0.16。 0.005。 A B S resin 1.009。 ME。 180。 2.05。 0.20。 Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《塑料中水分含量的测定 应用资料》,该方案主要用于聚乙烯(PE)中含量分析检测,参考标准《暂无》,《塑料中水分含量的测定 应用资料》用到的仪器有橡胶塑料水分测定仪、ADP-611卡氏水分测定仪-自动卡氏样品加热处理器(卡氏炉)、MKC-710卡氏水分测定仪[库仑电量法]、MKV-710S豪华型容量法卡尔费休水分仪。
我要纠错
