硝酸含量的测定 应用资料称取一定量的试样,用氢氧化钠标准滴定溶液滴定,根据氢氧化钠标准滴定溶液的消耗量计算硝酸的含量。KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIQ-97044enL Application MemoQuantification of Nitric Acid Industry Inorganic chemical industryInstrument Automatic potentiometric titratorMeasurement method Acid-base titrationStandards GB/T 337.2 1.Overview Nitric acid is measured by titration of a diluted sample with 1mol/L sodium hydroxide up tothe endpoint, which is the maximum inflexion on the titration curve. The concentration of nitric acid is calculated from the titration volume of sodium hydroxide. 2. Apparatus Main unit Automatic potentiometric titrator (preamplifier STD) Electrode pH glass electrode Ceramic reference electrode Temperature compensation electrode 3.Reagents Titrant 1 mo1/L sodium hydroxide Solvent Pure water 4. Example Sample Titer Nitric acid (g) (mL) (%) 1 0.5388 5.8240 68.10 2 0.5304 5.7286 68.04 3 0.5331 5.7506 67.96 Average 68.03 SD 0.07 RSD(%) 0.1 Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《硝酸含量的测定 应用资料》,该方案主要用于集成电路中硝酸检测,参考标准《暂无》,《硝酸含量的测定 应用资料》用到的仪器有AT-710S豪华型自动电位滴定仪、京都电子KEM 自动电位滴定仪控制操作软件 AT-Win。
