薄膜清洗液中盐酸含量的测定 应用资料将样品加入纯水后,用1mol/L氢氧化钠滴定溶液滴定至终点,测量盐酸含量。终点是滴定曲线上的最大拐点。盐酸浓度是根据氢氧化钠的滴定体积计算得出的。KGMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.TII-93002enL Application Memo Hydrochloric Acid in Film Cleaning Liquid Industry Plastic,Rubber Instrument Automatic potentiomet r ic titrator Measurement methodAcid-base titration StandardsGB/T 320 1.Overview Hydrochloric acid is measured by titration with 1mol/L sodium hydroxide up to the endpoint after the sample is added with pure water. The endpoint i s t he maximum inflexion on t he titration curve. Hydrochloric acid concentration is calculated from the t i tration volume of sodium hydroxide. 2. Apparatus Main unit Automatic potentiometric t itrator (preampli f ier STD) Electrode pH glass electrode Ceramic reference electrode Temperature compensation electrode 3. Reagents Titrant l mo1/L sodium hydroxide Solvent Pure water 4. Example -Titration curve一 Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《薄膜清洗液中盐酸含量的测定 应用资料》,该方案主要用于其他中含量分析检测,参考标准《暂无》,《薄膜清洗液中盐酸含量的测定 应用资料》用到的仪器有AT-710S豪华型自动电位滴定仪、AT-710M四通道旗舰型自动电位滴定仪、京都电子KEM 自动电位滴定仪控制操作软件 AT-Win。
