硬质合金中钴含量的测定 应用资料样品溶解在硝酸和氢氟酸中后,加入纯水、柠檬酸铵和氨水。冷却后,用1/30mol/L铁氰化钾滴定至终点,即滴定曲线上的最大拐点,测量样品溶液中的钴。钴的浓度是根据铁氰化钾的滴定体积来计算的。其原理是通过使用铁氰化钾在强氨溶液中将钴(II)氧化为钴(III)进行定量分析。KGMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIN-97001enL Application Memo Cobalt in Cemented Carbide Industry Iron and steel Instrument Automatic potentiometric t itrator Measurement method Redox t i tration Standards CIS 032B (Former Japan Cemented Carbide Tool Manufacturer's Association’s standards), GB/T 5124.3 1.Overview After the sample is dissolved in the nitric acid and hydrofluoride acid, add pure water,ammonium citrate, and ammonia water to i t. After cooling, cobalt in the sample solution i s measured by t itration with 1/30mol/L potassium ferricyanide up to the endpoint , which is the maximum inflexion on the titration curve. Cobalt concentration is calculated from t he titration volume of potassium ferricyanide. The principle is quant i fication by oxidizing cobalt (I I ) to cobalt (ⅢI ) i n strong ammonia solution using potassium f erricyanide. 2. Apparatus Main unit Automatic potentiometric titrator (preamplifier STD) Electrode Platinum electrode Ceramic reference electrode 3. Reagents Titrant 1/30mol/L potassium ferricyanide (potassium hexacyanoferrate (II ))solution Solvent Pure water, Nitric acid (1+1), Hydrofluoride acid,Ammonia water, Ammonium citrate 4. Example —Measurement results一 — Sample Titer Cobalt (g) (mL) (%) 1 0.2370 9.6125 8.054 2 0.2265 9.1946 8.061 3 0.2410 9.7968 8.072 Average 8.062 SD 0.009 RSD(%) 0.1 —Titration curve厂 Please feel free to contact us for any further i nformation.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《硬质合金中钴含量的测定 应用资料》,该方案主要用于合金中含量分析检测,参考标准《暂无》,《硬质合金中钴含量的测定 应用资料》用到的仪器有AT-710S豪华型自动电位滴定仪、AT-710M四通道旗舰型自动电位滴定仪、京都电子KEM 自动电位滴定仪控制操作软件 AT-Win。
我要纠错
