有各种FTIR方法可用于识别异物或污染物。FTIR显微镜用于尺寸在几微米量级的异物,但当可以用肉眼观察到含有异物的样品时,颗粒通常大于几百微米,不需要FTIR显微镜。宏观ATR方法可能是一种合适的替代方法,并具有最少的样品制备、无损测量和易于处理等优点。高质量ATR测量的一个关键要求是样品和ATR棱镜之间的完全接触。在常规ATR附件的情况下,用户不能确保棱镜是否与外来污染物直接接触。JASCO最新的FTIR配件ATR PRO ONE VIEW提供了与ATR棱镜接触的样品区域的实时可视化。这一特性对于测量纸张、塑料和金属等不透明基材上的异物非常有效。Application Note070ATO245 2/2 Observation and Measurement of Foreign Materia l Analysis using ATR PRO ONE VIEW Introduc t ion There are various FTIR met h ods that can be used to i den t ify fore i gn material or contami n ants.FTIR m i c r oscopy is used for foreign mate r i al where the size i s i n the order of few m i c r o n s, but when a samp l e with foreign ma t er i a l can be observed by the naked eye, the particle typically is typical l y greater than several hundred microns a n d does not r equire an FTIR microscope. A macro ATR method may be a suitable alternative a n d offers advantages such as minimal sample preparation, non-destructive measu r eme n t and easy-handl i ng . A key r equi r ement f or high quality ATR measure m e n t is f u ll contact between the sample and ATR pr i sm. In t h e case of a convent i o n a l ATR accessory, the user can n ot ensure whether the prism is in direct contact with t h e foreign contami n a n t or n ot. JASCO's l atest metal. ATR PRO ONE VIEW FTIR accessory, the ATR PRO ONE VIEW prov i des real-time visualization of the sample area in contact wit h ATR prism .This feature i s highly effective for the measurement of fore i gn materials on opaque substrates such as paper, plastic and This application n ote shows an exam p le of analysi s of a f oreign material using the ATR PRO ONE VIEW. Sample Foreign material, paper, ATR Instrument FT/IR-4600 Method ATR Detector DLATGS Accumulation 50 Resolution 4cm² Prism Diamond Keyword s ATR, foreign mate r ial, F T IR, cellulose, paper analysi s , polyester, image analysis Observat i on and Measurement of Foreign Appl i c a t i on Note Mate r ial Analysis using ATR PRO ONE VIEW Figure 1 shows the picture of the sample. Figure 2 shows the observation image of the target in full contact with t he prism. Figure 1. Op t i c al i ma g e o f f oreign ma teri a l o n p a p er Figure 2. S a m p le i m ag e u s i ng A TR PRO ON E VIE W R esul t Figure 3 shows the spect r a of paper and foreign mate r ia l on paper. I n the upper spectrum, the O-H peak (a r ound 3300cml) and C-O-C peak (a r ound 1000 cml) conf i rmed that the mai n component is cel l ulose. In the l ower spect r um, C-H peak (around 2900 cml ) and C=O peak (around 1720 cm-) are not attr i buted to cellulose. In order to i dentify the foreign mater i a l , the subtraction spectrum was calcu l ated and searched t h rough a spectra l database identifying the foreign material as polyester. Figure 3. S p ect r a of p ap e r (u p p e r )and fo r eign ma t e r ia l a t tac h ed pa pe r (lo w e r )*v e r t ical a x i s is o f fs et Figure 4. D a ta b ase s e arc h r e sult of subt r act i o n of sp e c t ra JASCO USA 28600 Mary's Cour t , E a s to n , M D 21601US A T el : (800) 333-5272 F ax: (410) 822-7526A ppl ic a tio n Lib r ary: ja s c o i n c.com /appli c a t i o ns
关闭产品配置单
佳士科商贸有限公司为您提供《利用透视ATR对异物进行FTIR分析》,该方案主要用于其他中异物、透视ATR、塑料、金属、不规则检测,参考标准《暂无》,《利用透视ATR对异物进行FTIR分析》用到的仪器有JASCO傅立叶变换红外光谱仪FT/IR-6000。
