检测样品 生食水产品
检测项目 理化分析
参考标准 SC/T 3032 水产品中挥发性盐基氮的测定
不同电压冷等离子体处理金鲳鱼(学名:卵形鲳鲹)的微生物、品质及蛋白质结构研究 广东海洋大学食品学院Insight into the microorganisms, quality, and protein structure of golden pompano (Trachinotus ovatus) treated with cold plasma at different voltagesFood Chemistry: X 18 (2023) 100695Contents lists available at ScienceDirect J. Xu et al.Food Chemistry: X 18 (2023) 100695 Food Chemistry: X journal homepage: www.sciencedirect.com/journal/food-chemistry-x 不同电压冷等离子体处理金鲳鱼(学名:卵形鲳鲹)的微生物、品质及蛋白质结构研究 Insight into the microorganisms, quality, and protein structure of golden pompano (Trachinotus ovatus ) treated with cold plasma at different voltages Jie Xu a , Qinxiu Sun a ,b ,c , Xiuping Dong c , Jialong Gao a , Zefu Wang a , Shucheng Liu a ,b ,* a College of Food Science and Technology, Guangdong Ocean University, Guangdong Provincial Key Laboratory of Aquatic Product Processing and Safety, Guangdong Provincial Engineering Technology Research Center of Marine Food, Key Laboratory of Advanced Processing of Aquatic Products of Guangdong HigherEducation Institution, Zhanjiang 524088, China 广东海洋大学食品学院 广东省水产品加工与安全重点实验室 b Collaborative Innovation Center of Seafood Deep Processing, Dalian Polytechnic University, Dalian 116034, China 大连理工大学海鲜深加工协同创新中心 A R T I C L E I N F O Keywords:Cold plasma Golden pompano Muscle quality Protein structure Microorganism A B S T R A C T Cold plasma (CP) is a non-thermal novel technology for the processing of heat-sensitive food products, but there is concern regarding its impact on food quality. Voltage is one of the most direct factors affecting the bacte-riostatic effect of CP. Golden pompano (Trachinotus ovatus ) was treated with CP at different voltages (10, 20, and 30 kV). The total viable count decreased as the CP voltage increased, reaching a maximum reduction of 1.54 lg CFU/g on golden pompano treated at 30 kV. No effects on water-holding capacity, pH, total volatile base ni-trogen, and T 2b relaxation time were observed, indicating that all CP treatments retained the freshness and bound water of the samples. However, as the CP voltage increased, peroxide value and thiobarbituric acid-reactive substances of golden pompano gradually increased, the protein tertiary structure unfolded, and d -helices con-verted to o -sheets, indicating inevitable lipid and protein oxidation caused by excessive CP voltage. Therefore, a suitable voltage of CP should be selected to inhibits the growth of microorganisms, which avoids deterioration of sea-foods quality. 1. Introduction As a temperate fsih with rapid growth, umami taste, and high nutritional value, golden pompano (Trachinotus ovatus ) is an important marine commercial fsih widely distributed in the southern sea area of China (Xun et al., 2022). However, the high moisture content, tissue fragility, and active endogenous enzymes in gold pompano render the fsih susceptible to deterioration by the proliferation of the spoilage microorganisms (Lan et al., 2022a; Liao et al., 2018). Therefore, certain measures need to be taken to inhibit the growth of microorganisms and extend the shelf life of golden pompano. Thermal treatment is currently the most effective means of sterilization, but for some thermosensitive foods, high-temperature sterilization is not suitable (Olatunde et al.,2021). For aquatic products, high-temperature sterilization will cause protein denaturation and impact the original falvor, color, texture, and other quality characteristics. Therefore, in the food industry, non-thermal sterilization technologies have gained widespread attention (Laroque et al., 2022). Cold plasma (CP) is among the emerging non-thermal decontami-nation technologies for heat-sensitive foods due to its effciiency in activating pathogenic and spoilage microorganisms at ambient or sub-lethal temperatures and is being extensively investigated for application on raw and processed meat and seafood products (Lin, Liao, Li, Abdel-Samie, & Cui, 2020; Nasiru et al., 2021; Olatunde, Shiekh, & Benja-kul, 2021). CP can be described as an ionized gas containing reactive species (such as reactive oxygen species [ROS] and reactive nitrogen species [RNS]), energized ions, charged particles, and ultraviolet (UV) radiation (Misra & Jo, 2017). CP has the advantages of low treatment temperature, no added chemicals, environmental friendliness, and low operating cost (Olatunde et al., 2021). CP shows antimicrobial, and fungicidal effects, prolonging food shelf life and replacing food additives (Laroque, Se -o, Valencia, Laurindo, & Carciof,i 2022; Marcinkowska-Lesiak et al., 2022; Olatunde, Benjakul, & Vongkamjan, 2019a ). Although CP has good antibacterial activity, there is a possibility of * Corresponding author at: College of Food Science and Technology, Guangdong Ocean University, Guangdong Provincial Key Laboratory of Aquatic Product Processing and Safety, Guangdong Provincial Engineering Technology Research Center of Marine Food, Key Laboratory of Advanced Processing of Aquatic Products of Guangdong Higher Education Institution, Zhanjiang 524088, China. E-mail addresses: sunqinxiugo@163.com (Q. Sun), Lsc771017@163.com (S. Liu). https://doi.org/10.1016/j.fochx.2023.100695 2590-1575/© 2023 TheAuthor(s). Published by Elsevier Ltd. This is an open access article under theCCBY-NC-NDlicense (http://creativecommons.org/licenses/by- nc-nd/4.0/). deterioration of food quality, such as lipid and protein oxidation (Albertos et al., 2017; Laroque, Se o o, Valencia, Laurindo, & Carciof,i 2022; P r erez-Andr e es et al., 2020), and for this reason, it is necessary to understand and strike a balance between the benefciial effect of CP on microbial safety and quality losses. In recent years, CP has been reported for the preservation of milk and milk products, fruits and vegetables, and poultry meat (Huang et al.,2019; Laroque et al., 2022; Yu et al., 2020), as well as aquatic products, such as salmon sashimi, herring, hairtail (Albertos et al., 2019; Koddy et al., 2021; Huang et al., 2021). Aquatic products, especially fsih, are exceptional sources of high-quality fats, proteins, minerals, etc (Ola-tunde et al., 2021). However, excessive amounts of active substances produced by CP may cause lipid and protein oxidation, leading to deterioration of product quality, which limits the application of CP technology in the aquatic product industry. Protein alteration in CP is primarily triggered by reactions involving ROS and the synergistic effect of RNS (Barbhuiya et al., 2021). This causes oxidative reactions etching and cross-linking in protein. According to Nasiru et al (2022), CP treatment resulted in the modifciation of the tertiary structure of the l l y y s s o o z z y y m m e e ,, w w h h i i c c h h b b e e c c a a m m e e m m o o r r e e o o b b v v i i o o u u s s w w i i t t h h i i n n c c r r e e a a s s e e d d v v o o l l t t a a g g e e .. I I n n addition, CP-based lipid oxidation can produce secondary oxidation products (Ucar et al., 2021). Moreover, primary oxidation products in seafood caused by CP can make lipids more vulnerable to oxidation during storage. Lipid oxidation may lead to loss of nutrients and sensory properties of food and alter organoleptic properties. Furthermore, Albertos et al (2019) observed that lipid oxidation is proportional to the applied CP energy. To confront this challenge, further studies are needed to fully elucidate the effects of CP on lipid and protein oxidation in aquatic products to select an appropriate CP treatment condition for application in aquatic product preservation. Consequently, the present study aimed to comprehensively evaluate the effects of CP treatment at different voltages on the quality attributes of golden pompano, including antibacterial activity, physicochemical properties, lipid oxidation, and protein structure. A balance between Fig. 1. (A) Dielectric barrier discharge (DBD) cold plasma device; (B) DBD reactor. 1. dielectric (current experimental dielectric is quartz); 2. DBD-100 reaction unit; 3. grounding electrode; 4. high voltage electrode; 5. reaction unit gap adjustment knob; 6. reaction unit viewing win-dow; 7. timer; 8. switch; 9. timing knob; 10. discharge button; 11. stop button; 12. gas flow meters 1; 13. gas flow meters 2; 14. gas inlet 1;15. gas inlet 2; 16. gas-vent; 17. power input port;18. grounding electrode port. microbial safety and quality attributes should be revealed by exploring the relationship between the change in each parameter and the CP treatment voltage. It is considered that the fnidings of this study would be benefciial for golden pompano preservation. 2. Materials and methods 2.1. Sample processing The fresh golden pompano (average weight of 550 ± 50 g) was purchased from the Xiashan wholesale aquatic products market (Zhan-jiang, China) and then transported to the laboratory in a box with oxygenated water within 30 min. The fsih were killed by ice bath treatment. Then, they were cleaned with pure water and wiped dry with clean absorbent paper. The dorsa-lateral muscles of the fsih were sepa-rated from the bone and skin and cut into 40 × 30 × 10 mm3 pieces. 2.2. Cold plasma treatment The CP system (Fig. 1) consisted of a DBD-100 reaction unit, a CTP2000S high-voltage power supply (output voltage: 0–60 kV; Suman, Nanjing, China), a TDGC2-1 voltage regulator (220 V, 50 Hz; Zhengtai, Yueqing, China), and a TBS 1000C oscilloscope (Tektronix, Beaverton, OR, USA). The CP discharge was carried out in a DBD-100 reaction unit consisting of quartz plates with a diameter of 100 mm and a spacing of 20 mm. The TBS 1000C oscilloscope was used to monitor the energy in the DBD-100 reaction unit. The fsih pieces were randomly divided into four groups: the negative control group (0 kV) without CP treatment and the three treatment groups (10, 20, and 30 kV) treated with CP at different voltages for 45 s. The reaction gas was clean air, and the treatment temperature was 25 ±3 °C. 2.3. Microbiological analysis As the microbial content of fresh fsih is very low, according to the previous experimental results in our lab, the fsih was placed at 20 °C for 24 h before CP treatment to achieve a certain microbial content. The total viable count (TVC) was determined according to the method of Huang et al. (2019) with minor modifciations. The minced fsih (10 g) was placed in a sterilized blender bag with sterile physiological saline (90 mL, 0.85% NaCl, w/v). Then, the samples were mixed with a stomacher (Truelab, BM-400HP, Shanghai, China) for 1 min. The sam-ples (1 mL) were poured onto plate count agar after a series of dilutions in physiological saline. After the agar had solidifeid, it was incubated at 37 °C for 48 h, and the TVC was counted and reported as lg CFU/g. 2.4. Quality properties and biochemical analysis 2.4.1. Juice loss Juice loss was determined according to the method of Du et al.(2022). The weight of each fsih pieces was recorded before CP treatment (m 0). After the CP treatment, the moisture on the surface of the sample was dried with fliter paper, and then the sample was accurately weighed (m 1), and the juice loss was calculated by the following equation: 2.4.2. Water-holding capacity Water-holding capacity (WHC) was determined according to the method of Yang et al. (2022) with minor modifciations. Approximately 5 g of fsih sample (m 2) was wrapped in blotting paper and centrifuged at 5,000 r/min, 4 °C for 10 min in a freezing centrifuge (Sigma, 3-30KS, Osterode am Harz, Germany). After removing the blotting paper, the weight of the fsih pieces was recorded (m 3), and the WHC was calculated by the following equation: 2.4.3. Color C C h h a a n n g g e e s s i i n n t t h h e e c c o o l l o o r r p p a a r r a a m m e e t t e e r r s s ,, i i n n c c l l u u d d i i n n g g L L ** ((l l i i g g h h t t n n e e s s s s )),, a a **(redness or greenness), and b * (yellowness or blueness), of the fsih were evaluated as described by Yang et al. (2022) using a colorimeter (Konica Minolta, CR-20, Tokyo, Japan). The white reference tile (L *: 95.0, a *:- 0.1, b *: 4.1) was used to calibrate the instrument. 2.4.4. Hardness The hardness was measured according to the method of Yang et al.(2022) with minor modifciations. The fsih was cut into a 10 × 10 ×10mm3 cube. The hardness of the sample was determined using a texture analyzer (Stable Micro Systems, TA.XTplusC, Surrey, UK) under the following test conditions: P/0.5 probe; trigger force, 5 g; pre-test, test, and post-test speed, 1 mm/s. 2.4.5. pH The pH value was determined according to the method of Qian et al.(2021) with minor modifciations. The minced fsih (3 g) was added to deionized water (30 mL) and homogenized with a homogenizer (IKA, T25, Staufen, Germany) at 10,000 r/min for 1 min. After standing for 30min, the pH value was measured with a PB-10 pH meter (Sartorius, Gottingen, Germany). 2.4.6. Total volatile base nitrogen Total volatile base nitrogen (TVB-N) was determined according to the method of Lan et al. (2022a) with some modifciations. About 5 g of minced fsih was added to deionized water (37.5 mL) and mixed with a vortex mixer (Scilogex, SCI-VS, CT, USA) for 30 s. After standing for 30min, the mixture was added to the distillation tube with MgO (0.5 g). A Vapodest Kjeldahl nitrogen analyzer (Gerhardt, Konigswinter, Ger-many) was used to determine the TVB-N under the following measure-ment settings: distillation time of 120 s, titration endpoint of pH 4.65. Hydrochloric acid (HCl) solution for volumetric analysis (0.1 M; Anpel Laboratory Technologies, Shanghai, China) was used to titrate. The TVB-N was calculated by the following equation: where V 1 is the volume of HCl solution for volumetric analysis in the mixture (mL); V 2 is the volume of HCl solution for volumetric analysis in blank specimens (mL); c is the concentration of HCl solution for volu-metric analysis (mol/L), and m is the mass of the fsih (g). 2.5. Lipid oxidation 2.5.1. Peroxide value Peroxide value (POV) was determined according to the method of Wang et al. (2018) with minor modifciations. Twenty milliliters of cold chloroform:methanol (1:1, v/v) solution was added to about 5 g of minced fsih. Then, the mixture was homogenized at 12,000 r/min for 1min, followed by the addition of 6.16 mL of NaCl solution (0.5%, w/v), and then the mixture was centrifuged at 4,500 r/min, 4 °C for 8 min. Afterward, 3 mL of the bottom chloroform layer was aspirated by sy-ringe and then mixed with 5 mL of cold chloroform:methanol solution (1:1, v/v), 100 p L of ammonium thiocyanate solution (3.94 M), and 100u L of FeCl2 solution (18 mM), vortexed for 10 s. After standing for 20min in the dark, the absorbance of the mixture was determined at 500nm using a UV –visible spectrophotometer (Shimadzu, UV-2550, Kyoto, Japan). Finally, the POV value was calculated from the Fe3d standard curve. 2.5.2. Thiobarbituric acid-reactive substances TBARS was determined according to the method of Wang et al.(2018) with minor modifciations. Twenty milliliters of trichloroacetic acid (20%, w/v) were added to 5 g of minced fsih and homogenized at 12,000 r/min for 1 min. Then, the mixture was centrifuged for 15 min (8,000 r/min, 4 C C), and the supernatant was retained. Next, 4 mL of the supernatant was mixed with an equal amount of 2-thiobarbituric acid (20 mM) and heated in boiling water for 20 min. The mixed solution was cooled to room temperature with water. The absorbance of the solution was measured at 532 nm with a Varioskan Flash microplate reader (Thermo Fisher Scientifci, Waltham, MA, USA). The TBARS value was calculated from the malondialdehyde (MDA) standard curve and expressed as milligrams of MDA per kilogram of meat. 2.6. Low-feild nuclear magnetic resonance Low-feild nuclear magnetic resonance (LF-NMR) was performed ac-cording to the method of Yang et al. (2022) with some modifciations. The fsih was cut into a 30 × 30 × 10 mm3 pieces (about 10 g). The relaxation time (T 2) and peak area of the samples were measured by the Carr –Purcell –Meiboom –Gill (CPMG) sequence with an NMR analyzer (Niumag Corp., NMI 20-060H-I, Suzhou, China) at 32 C C under the following measurement settings: stable frequency, 21 MHz; waiting time, 3,000 ms; echo count, 3,000; number of repeated scans, 8. The T 2relaxation time of the samples was obtained by inversion of the data using the Niumag NMR analysis software (Niumag Corp.) with the simultaneous iterative reconstruction technique. 2.7. Protein oxidation and structural changes 2.7.1. Extraction of myofbirillar protein Myofbirillar proteins (MP) was extracted according to the method of Lan et al. (2022b) with minor modifciations. Two grams of minced fsih was mixed with 20 mL of Tris-buffer A (0.05 M KCl, 20 mM Tris-HCl, pH 7.00) and homogenized at 12,000 r/min for 1 min, The resultant ho-mogenate was centrifuged at 10,000 r/min, 4 °C for 15 min, and the supernatant was discarded (This operation was repeated twice.). Then,20 mL of Tris-buffer B (0.6 M KCl, 20 mM Tris-HCl, pH 7.00) was added to the precipitate and homogenized at 12,000 r/min for 1 min. After standing for 1 h, the mixture was centrifuged for 15 min (10,000 r/min,4 °C). The supernatant was the MP solution. The MP content was determined by the Biuret Protein Quantitative Kit (PT0004; Leagene Biotechnology, Beijing, China). 2.7.2. Total sulfhydryl content The total sulfhydryl content of the samples was determined by a c c o o l l o o r r i i m m e e t t r r i i c c m m e e t t h h o o d d w w i i t t h h t t h h e e T T o o t t a a l l S S u u l l f f h h y y d d r r y y l l C C o o n n t t e e n n t t A A s s s s a a y y K K i i t t (BC1375; Solarbio, Beijing, China), and the protein content was deter-mined by the Biuret Protein Quantitative Kit (PT0004; Leagene Biotechnology). The absorbance value measured at 412 nm was substituted into the formula given in the instructions in the assay kit to calculate the total sulfhydryl content (mol/105 g protein). 2.7.3. Intrinsic fulorescence spectra Intrinsic fulorescence was measured according to the method of Cheng et al. (2021b) with minor modifciations. The protein concentra-tion of MP was adjusted to 0.1 mg/mL. The fulorescence of the solution was measured using a fulorescence spectrophotometer (Shimadzu, RF-5301PC, Kyoto, Japan) under the following measurement settings:excitation wavelength, 280 nm; emission wavelength, 295–450 nm; scan speed, super; slit width, 5 nm. 2.7.4. Circular dichroism spectroscopy Circular dichroism (CD) spectroscopy was performed according to the method of Sun et al. (2019a) with minor modifciations. The protein concentration of MP was adjusted to 0.4 mg/mL. The CD spectroscopy of the solution was determined using a CD spectropolarimeter (Applied Photophysics, Chirascan V100, Surrey, UK) under the following mea-surement settings: wavelength range, 190–260 nm; scanning speed, 1nm/s; quartz CD cuvette, 0.5 mm in thickness. The secondary structure contents were analyzed by the CD spectra deconvolution software (Institut für Biotechnologie, Saale, Germany). 2.8. Sensory evaluation Sensory evaluation was determined according to the method of Olatunde et al. (2019a) with some modifciations. Thirteen trained panelists (6 women and 7 men, aged 21 to 30 years) were asked to evaluate the appearance, texture, odor, and overall likeness of the fsih. A 99--p p o o i i n n t t h h e e d d o o n n i i c c s s c c a a l l e e w w a a s s u u s s e e d d f f o o r r s s e e n n s s o o r r y y e e v v a a l l u u a a t t i i o o n n ((99:: l l o o v v e e extremely, 8: like very much, 7: like moderately, 6: like slightly, 5:neutral, 4: dislike slightly, 3: dislike moderately, 2: dislike very much, 1:dislike extremely). A mean score (5) was used as the acceptable threshold. 2.9. Statistical analysis The data were analyzed by one-way analysis of variance (ANOVA) using JMP Pro 16 software (SAS Institute, Cary, NC, USA). Tukey ’s honestly signifciant difference (HSD) multiple comparisons test was used to assess the signifciant differences between all samples, with P <0.05 indicating a signifciant difference. All data were expressed as mean ± standard deviation. Three batches of fsih samples were prepared for this study, and triplicate measurements were performed (Except that the hardness of the sample was measured fvie times). 3. Results and discussion 3.1. Microbiological analysis Fig. 2. (A) TVC; (B) Juice loss and water-holding capacity; (C) pH and TVB-N; and (D) POV and TBARS of golden pompano treated with cold plasma at different voltages. Different letters (a-d) indicate signifciant difference (P < 0.05) of means between the groups. TVC, total viable count; TVB-N, total volatile base nitrogen; POV, peroxide value, TBARS, thiobarbituric acid-reactive substances; MDA, malondialdehyde. 3.2. Juice loss and water holding capacity analysis Juice loss refelcts the water retention capacity of meat, which affects the extent of water exudation from the sample (Du et al., 2022). Fig. 1B shows the juice loss of golden pompano before and after the CP treat-ments. The juice loss of the sample increased with the CP voltage (P <0.05), although the maximum juice loss was only 0.52%. Juice loss would lead to a decline in the nutritional value of fsih, thereby deteri-orating the quality and reducing the commercial value. It was speculated to be caused by a certain degree of oxidation of MP as the treatment voltage increases, resulting in a more pronounced loss of free water on the surface (Du et al., 2022). In the current study, the 45 s-CP treatment time was short enough to avoid substantial juice loss from fsih. One of the most important factors affecting the economic value and quality of meat is the WHC, which is closely related to the color and texture of raw meat (Barbera, 2019; Yang et al., 2022). As shown in Fig. 2B, there was no signifciant difference in the WHC among all the groups (P >0.05). The WHC depends largely on the water content of the aquatic product itself (Szmanko et al., 2021). The 45 s-CP treatment caused signifciant juice loss (≤0.6%, Fig. 2B), but it had little effect on the WHC of the samples containing a large amount of water. Koddy et al.(2021) asserted that the reactive species generated by CP might have the ability to induce aggregation reactions. They found that the WHC of hairtail treated at 50 kV for 60 s increased compared to the untreated group. The impact of the treatment depends on a range of factors, such as the CP equipment, treatment voltage, and raw materials. 3.3. Color analysis Color is the frist quality attribute those consumers use to assess meat quality, which is more intuitive than any other sensory attribute (Huang et al., 2019). The color changes in golden pompano induced by CP at different voltages are shown in Table 1. There was no signifciant dif-ference in the L *-value between the control group and the 10 kV CP group (P 0.05), perhaps due to the small processing voltage. However, the L *-value increased signifciantly when the treatment voltage excee-ded 20 kV (P < 0.05). An increase in the L *-value suggests that CP treatment caused the migration of water from inside the fsih to the surface (Yang et al., 2022), perhaps due to a certain degree of oxidation of MP as the treatment voltage is increased (Du et al., 2022). In addition to the change in the L *-value, there was a dramatic decrease in the a *-value with the increase of the voltage (P <0.05). This change may result from the oxidation of pigments and lipids caused by the reactive species produced by CP, especially ozone (O3), and met-myoglobin formation could be promoted when myoglobin reacts with reactive species (Olatunde et al., 2019b ). Cho et al. (2014) showed that O3 treatment decreased the a *-value of beef. In addition, the decrease in the a *-value of fsih might be associated with the degradation of the heme porphyrin rings induced by plasma treatment (Cheng et al.,2021a ). There was no signifciant difference in the b *-value between the control group and the 10 kV CP group (P > 0.05) but the b *-value increased signifciantly when the treatment voltage exceeded 20 kV (P <0.05). Huang et al. (2021) also found that the b *-value of salmon sashimi increased after CP jet treatment. It may be because of lipid and pigment Table 1Color, hardness, and sensory evaluation of golden pompano treated by cold plasma at different voltages. Processing voltage (kV) L* a* b* Hardness (g) Appearance Texture Odor Overall likeness 0 45.96 ± 1.07c - 1.22 ± 0.15a 0.86 ± 0.18b 1517.1 ± 79.33b 8.42 ± 0.53a 8.35 ± 0.47a 8.58 ± 0.49a 8.38 ± 0.46a 10 46.76 ± 0.96bc - 1.66 ± 0.23b 1.08 ± 0.22b 1493.56 ± 39.49b 7.94 ± 0.54ab 7.77 ± 1.25a 8.10 ± 0.66a 7.79 ± 0.88a 20 48.26 ± 1.02b - 2.10 ± 0.16c 1.94 ± 0.38a 1290.73 ± 95.60c 7.70 ± 0.82b 7.92 ± 0.7a 6.95 ± 1.09b 7.81 ± 0.7a 30 50.96 ± 0.99a - 2.64 ± 0.11d 2.28 ± 0.72a 1704.81 ± 69.32a 6.27 ± 0.73c 6.38 ± 0.89b 5.98 ± 1.34c 6.42 ± 0.88b Different letters (a-d) indicate signifciant difference (P < 0.05) of means between the groups. oxidation induced by CP, or the lipid oxidation products might be involved in browning processes by reacting with proteins and related compounds (Huang et al., 2021). In summary, the changes in the color parameters were mainly due to the oxidation of proteins, pigments, and lipids caused by the reactive species produced by CP (Nasiru et al.,2021). 3.4. Hardness analysis The hardness is a sensory characteristic of food (Yang et al., 2022). It can be seen from Table 1 that with the increase of processing voltage, the hardness of golden pompano frist decreased and then increased. There was no signifciant difference in hardness between samples treated with 10 kV CP and fresh samples (P >0.05). After low-voltage treatment (10kV), the lipid and protein products of oxidation caused by the reactive species produced by CP were not enough to change the hardness of the fsih. However, the hardness decreased signifciantly when the voltage was 20 kV (P <0.05). This decrease in the fsih hardness might be related to the bombardment of fsih by charged particles generated by CP, which damaged muscle fbiers and destroyed the protein spatial structure (Bao & Ertbjerg, 2019). At the same time, the decrease in fsih hardness also refelcted an improvement in the tenderness. Nevertheless, the hardness of fsih treated with 30 kV CP was signifciantly higher than that of the fresh samples (P < 0.05), which can be explained by the severe dehy-dration of the surface of the fsih muscle, protein oxidation leading to crosslinking, and a dense protein network (Koddy et al., 2021). 3.5. pH and total volatile base nitrogen analysis The pH value is an important indicator of meat quality. Changes in the pH value of golden pompano treated with CP at different voltages are shown in Fig. 2C. The pH values of all the samples ranged from 7.01 to 7.04 (P >0.05). Generally, the pH value of fresh fsih varies from 5.80 to 7.20, which is related to the species, growth environment, and fsihing methods (Huang et al., 2021). Based on their observations that the pH value of sashimi treated with CP for 3 min did not change signifciantly, Huang et al. (2021) suggested that the CP jet treatment could retain the pH value of sashimi at normal levels. Moreover, Olatunde et al. (2019a) found that the pH value of Asian sea bass slices did not change with the extension of plasma treatment time. Changes in the pH value may be related to the accumulation of basic compounds from the decomposition or degradation of nucleotides and proteins mediated by autolysis and microbial proliferation (Olatunde et al., 2019a ). From the results of the present study, short-term CP treatment does not affect the pH value of golden pompano. TVB-N is an important indicator for assessing fsih freshness. It is a general term for the basic volatile compounds produced due to the degradation of protein and non-protein nitrogen compounds (Sun et al.,2019b ). As shown in Fig. 2C, the TVB-N values of golden pompano before and after CP treatments ranged from 15.76 to 16.36 mg/100 g (P > 0.05). An increase in the TVB-N value is mainly due to the role of microorganisms. Olatunde et al. (2019a) also found that there was no signifciant difference in the TVB-N value of fsih after CP treatment without storage (P > 0.05). 3.6. Peroxide value and thiobarbituric acid-reactive substances analysis Lipid oxidation can result in the generation of hydroperoxides in the initial stage, and POV values were measured to refelct the amount of hydroperoxides formed during lipid oxidation (Fang et al., 2022). As shown in Fig. 2D, the POV value of golden pompano treated with CP gradually increased with the processing voltage (P <0.05). These results mirrored the observations of Albertos et al. (2017) that the POV value of mackerel increased after CP treatment. In general, the increase in the POV value indicated that CP treatment caused lipid oxidation reactions. The mechanism of CP action has been confrimed, and the ROS and RNS produced by CP are the most important components (Misra & Jo, 2017). Although the bactericidal effciiency of ROS and RNS cannot be under-rated, these reactive chemical species also have adverse effects on lipids. The TBARS value represents the content of secondary lipid oxidation products mainly derived from the degradation of polyunsaturated fatty acids (Sun et al., 2019b ). As shown in Fig. 2D, the TBARS value of golden pompano increased signifciantly after CP treatment (except for the 10kV) (P < 0.05), which indicated that the lipid oxidation increased with the increase of the treatment voltage. The change trend of the TBARS value (except for the 10 kV) almost mirrored that of the POV. Olatunde et al. (2019b) proposed that the increase in the TBARS value of Asian sea bass with the extension of CP treatment time was due to the increasing production of O3. It is well known that an increase in the treatment voltage will also lead to an increase in O3 formation (Albertos et al.,2019). Intriguingly, the TBARS value of golden pompano treated with CP at 10 kV was lower than that of the fresh sample. It seems plausible that the protein binding effciiency of MDA and the active substances and charged particles produced by CP promote this process, resulting in a decrease in the TBARS value (Wang et al., 2021). Nevertheless, with further increments in the treatment voltage, the yield of MDA caused by lipid oxidation exceeded the amount needed to bind to the protein, and the TBARS value increased. In general, the threshold level for acidif-i cation of the TBARS is 2.0–2.5 mg/kg (Wang et al., 2018). However, in the present study, the TBARS values of all the golden pompano samples were well below this threshold level. From these results, the amount of hydroperoxides and MDA increased with the CP treatment voltage, which proved that the degree of fat oxidation increased with the CP voltage. Although the CP treat-ment did not affect the acceptability of golden pompano, the lipid o o x x i i d d a a t t i i o o n n c c a a u u s s e e d d b b y y t t h h e e C C P P t t r r e e a a t t m m e e n n t t o o f f g g o o l l d d e e n n p p o o m m p p a a n n o o w w o o u u l l d d adversely affect the shelf life. Further experiments are needed to determine if the prior treatment of seafood with some antioxidant technology will circumvent this limitation. 3.7. Low-feild nuclear magnetic resonance F-NMR analysis The water mobility and distribution in golden pompano were eval-uated by measuring the proton spin –spin relaxation time (T 2) using an LF-NMR spectrometer (Yang et al., 2022). The water distribution of all the samples is shown in Fig. 3A –D. Four water peaks were observed on the LF-NMR curves (Fig. 3A): T 2b1 (0–1 ms) and T 2b2 (1–10 ms) both represent bound water, T 21 (10–100 ms) represents immobilized water, and T 22 (100–10,000 ms) represents free water. The changes in the T 2b1, T 2b2, T 21, and T 22 relaxation times are shown in Fig. 3C and 3D. The peak area refelcts the amount of water in the samples. The contribution of the Fig. 3. Water properties of golden pompano treated with cold plasma at different voltages. (A) T 2 relaxation times, (B) different types of water content, (C) T 2b1 and T 2b2 relaxation times, (D) T 21 and T 22 relaxation times. Different letters (a-b) indicate signifciant difference (P < 0.05) of means between the groups. peak area of each component to the total peak area is shown in Fig. 3B. As shown in Fig. 3C, there were no signifciant changes in T 2b1 and T 2b2 among the different treatment groups, and correspondingly, there were also no signifciant differences in P 2b1 and P 2b2 (Fig. 3B) between each treatment group (P > 0.05). The bound water is tightly bound to proteins or other biological macromolecules and is not easy to migrate to other regions. Albertos et al. (2017) also noticed that strongly bound water (T 2b) was not infulenced by CP treatment. A signifciant increase in the T 21 relaxation time (Fig. 3D) was observed for the CP-treated golden pompano samples compared with the fresh sample (P 0.05), causing a decline in the binding capacity of the muscle tissue with water, and water mobility increased. Simultaneously, the T 22 relaxation time increased as the treatment voltage increased (Fig. 3D), which was consistent with Albertos et al. (2017) that T 22 after CP treatment at 80kV was signifciantly higher than that obtained after CP treatment at 70kV (P < 0.05). The increase in the T 21 and T 22 relaxation times may be related to the oxidation of proteins caused by CP, resulting in a certain degree of conversion of immobilized water to free water (Liu et al.,2022) and subsequent loss of water. This corresponded with the result of juice loss. As shown in Fig. 3A and 3B, P 21 was not affected (P >0.05) by the intensity of the treatment voltage, indicating that the proportion of immobilized water to total water remained constant, which was verifeid by the change in the WHC (Fig. 2B). In addition, P 22 decreased signifciantly (P <0.05) with further increments of the treatment voltage (≥20 kV) compared with the fresh fsih, signifying that the free water decreased. This may be due to the evaporation of free water at the increased treatment voltage, resulting in juice loss. 3.8. Total sulfhydryl content analysis Protein oxidation leads to a variety of changes, including carbonyl- a a t t i i o o n n ,, r r e e d d u u c c t t i i o o n n o o f f s s u u l l f f h h y y d d r r y y l l g g r r o o u u p p s s ,, a a n n d d c c r r o o s s s s l l i i n n k k i i n n g g f f o o r r m m a a t t i i o o n n (Nawaz et al., 2022). The sulfhydryl content of all samples was evalu-ated to identify the extent of oxidation of the fsih with CP treatment. As revealed in Fig. 4A, the sulfhydryl content of golden pompano tended to decrease with the increase in the processing voltage, but the magnitude of the decrease was signifciant only from 20 to 30 kV (P < 0.05). The sulfhydryl content decreased from 8.13 mol/105g protein (control sample) to 5.57 mol/105g protein after being treated with 30 kV. This may be because of the particular susceptibility of the sulfhydryl groups in fsih protein to oxidation induced by ROS (Huang et al., 2019). The reactive species produced by CP lead to either strong oxidation of side chains of sulfur-containing proteins or aggregation of disulfdie bonds through sulfhydryl crosslinking in sulfur amino acids (Koddy et al.,2021). The decrease in sulfhydryl content indicates the loss of most sulfhydryl functional groups and usually indicates protein oxidation. Consistent with the present results, Koddy et al. (2021) reported that the sulfhydryl content of hairtail was notably affected by CP treatment. 3.9. Intrinsic fulorescence analysis The fulorescence spectroscopy of tryptophan (Trp), which shows high sensitivity to its microenvironment, is conventionally used to observe the changes in protein tertiary structures (Lan et al., 2022b ). As shown in Fig. 4B, there was a difference in the fulorescence intensity between the control sample of golden pompano and the CP-treated samples, and the fulorescence intensity increased with the increase of Fig. 4. (A) Total sulfhydryl content; (B) Intrinsic fluorescence; (C) Circular dichroism spectra; and (D) Secondary structure content of golden pompano treated with cold plasma at different voltages. Different letters (a-c) indicate signifciant difference (P < 0.05) of means between the groups. the treatment voltage. This could be attributed to the etching and oxidation induced by CP that exposed the Trp residues to the outer surface, increasing the degree of MP unfolding (Yu et al., 2020), which becomes more pronounced with increasing treatment voltage. Another study showed that the destruction of the protein hydrophobic regions would lead to the exposure of aromatic groups, thus increasing the fulorescence intensity (Lan et al., 2022b ). Similarly, Yu et al. (2020) found that CP treatment could increase the fulorescence intensity of peanut isolate protein, and Nasiru et al. (2022) observed a similar phenomenon in lysozyme. The changes in the sulfhydryl content and fulorescence intensity refelcted a certain degree of destruction of the structure of MP in the fsih. The destruction of the protein structure is not conducive to subsequent storage, so certain measures need to be taken to inhibit protein oxidation caused by CP. 3.10. Circular dichroism spectroscopy analysis CD spectroscopy analysis examines the conformational changes connected to the polypeptide backbone structure of proteins, including a -helix, B -turn, p -sheet, and random coil (Nasiru et al., 2022; Sun et al.,2019a ). The CD spectra of golden pompano samples before and after CP treatment at different voltages are shown in Fig. 4C. The peak position of each treatment group was the same. However, compared with the fresh sample, the negative peaks of the other treatment groups shifted up-ward, and the positive peaks decreased as the voltage increased, indi-cating that the secondary structure of the protein was transformed by the CP treatment (Nasiru et al., 2022). However, it should be noted that these changes were very small (Fig. 4D). With the increase of the CP t t r r e e a a t t m m e e n n t t v v o o l l t t a a g g e e ,, t t h h e e a --h h e e l l i i x x c c o o n n t t e e n n t t o o f f t t h h e e s s a a m m p p l l e e s s g g r r a a d d u u a a l l l l y y decreased, and the p -sheet content gradually increased, but there was no signifciant change in the content of random coil and p -turns, which indicated that the conformation of protein was partially transformed from stable to relatively disordered alongside the denaturation and unfolding of the protein (Han et al., 2019). This may be because of the high reactivity of methionine, phenylalanine, and tyrosine in the fsih protein, which can be rapidly oxidized when exposed to reactive species (ROS and RNS) produced by CP (Qian et al., 2021). However, the sec-ondary structure content changes were slight, with signifciant differ-ences only between the 30 kV group and the control group (P < 0.05). The CD results suggested that CP treatment can change the MP sec-ondary structure and that an appropriate treatment voltage (≤20 kV) has no signifciant effect on the protein secondary structure. 3.12. Correlation analysis and principal component analysis The quality of golden pompano after CP treatment was determined by its microbial content and physical and chemical properties. Thus, to predict the effect of CP on the quality of golden pompano, the complex relationships between various variables must be resolved. In the present study, correlation analysis (Fig. 5A) and principal component analysis (PCA) (Fig. 5B) were conducted to clarify the relationships among the TVC, juice loss, WHC, hardness, color, pH, TVB-N, water properties (T 2b1, T 2b2, T 21, T 22, P 2b1, P 2b2, P 21, and P 22), lipid oxidation (POV, TBARS) and protein structure (total sulfhydryl content, o -helix, B -turn, B -sheet, and random coil) of the CP treatment at different voltages. It can be approximately considered that the TVC, a *-value, total sulfhydryl content, P 22, a -helix, p -turn, and P 2b2 were negatively correlated with T 2b1, T 2b2, T 21, T 22, P 2b1, P 21, pH, TVB-N, juice loss, WHC, hardness, Fig. 5. (A) Correlation analysis; and (B) Principal component analysis. POV, TBARS, L *-value, b *-value, B -sheet, and random coil. In addition, the TVC had a signifciantly negative correlation with TBARS, L *-value, and b *-value (P <0.05) and a signifciantly positive correlation with the a *-value (P < 0.05). Therefore, as a more convenient experiment, only the TVC, TBARS, and color need to be studied to allow a rapid investi-gation of the optimal conditions of the CP treatment. At the same time, cluster analysis of the different treatment groups divided the groups into three categories. The frist group included the control group and the 10 kV group; the second group was 20 kV, which signifciantly reduced the TVC. The third group was 30 kV, which further reduced the TVC. With the increase of the treatment voltage, the com-ponents of reactive species and charged particles also increased, which reduced the microbial content, but aggravated the deterioration of the lipid. The PCA of each indicator of the sample is shown in Fig. 5B, and the contribution rates of the frist two principal components (PC1 and PC2) were 65.5% and 22.3%, respectively, with a cumulative contribution rate of 87.8% (>85%), which can well refelct the information of the original data. The PCA also showed similar results to the cluster analysis, with the control (0 kV) and 10 kV groups in the second quadrant, 20 kV in the fourth quadrant, and 30 kV in the frist quadrant. Moreover, TVC was also located in the second quadrant, indicating that the CP anti-bacterial effect was not signifciant under low-voltage conditions. Meanwhile, POV and TBARS were in the frist quadrant, indicating that high-voltage CP treatment improved the antimicrobial effects but pro-moted lipid oxidation. However, the 20 kV group was far from TVC, b *-value, a *-value, POV, and TBARS on the coordinate axis, indicating that this group had a good inhibition effect and maintained good quality. Therefore, CP treatment at 20 kV may be used for the sterilization and preservation of golden pompano. 3.12. Sensory evaluation analysis the higher voltage, which caused strong off-falvor of fsih. In addition, it also resulted in severe water loss from the surface of the fsih and the fsih b b e e c c a a m m e e t t o o u u g g h h e e r r ,, w w h h i i c c h h w w a a s s c c o o n n s s i i s s t t e e n n t t w w i i t t h h t t h h e e h h a a r r d d n n e e s s s s r r e e s s u u l l t t s s (Table 1). Overall, the acceptability of the golden pompano was not affected at the appropriate CP treatment voltage. 4. Conclusion CP inhibited the growth of microorganisms, thus reducing the TVC, and the inhibits effect increased with the increase of the CP voltage. However, excessive voltage (30 kV) inevitably leads to problems, such as fat oxidation, protein oxidation, and juice loss, while at an appropriate voltage, CP treatment had inapparent or small effects on the funda-mental properties of golden pompano, such as texture, color, water distribution, lipid oxidation, and protein structure. This indicates that the quality of golden pompano can be maintained after CP treatment at an appropriate voltage. In this context, CP could be considered as a potential alternative method for the preservation of seafood products in the future. Moreover, if the oxidation problem caused by high-voltage CP can be solved, it will broaden the application prospect of CP. Funding This work was supported by the Scientifci and Technological Inno-vation Strategy of Guangdong Province [grant number 2022A05036]; Guangdong Basic and Applied Basic Research Foundation [grant num-ber 2023A1515011513]; Zhanjiang Ocean Youth Talents Innovation Project [grant number 2021E05015]; General transfer payment fund project of fsihery development support policy in Guangdong Province in 2022 [grant number 2022-440000-45060100-9680]; and Guangdong I I n n n n o o v v a a t t i i o o n n T T e e a a m m o o f f S S e e a a f f o o o o d d G G r r e e e e n n P P r r o o c c e e s s s s i i n n g g T T e e c c h h n n o o l l o o g g y y [[g g r r a a n n t t number 2019KCXTD011]. CRediT authorship contribution statement Jie Xu: Data curation, Writing – original draft, Visualization. Qinxiu Sun: Conceptualization, Methodology, Writing –review & editing. Xiuping Dong: Supervision. Jialong Gao: Investigation, Validation. Zefu Wang: Investigation, Validation. Shucheng Liu: Conceptualiza-tion, Methodology, Writing – review & editing. Declaration of Competing Interest The authors declare that they have no known competing fniancial interests or personal relationships that could have appeared to infulence the work reported in this paper. Data availability Data will be made available on request. Acknowledgements The authors wish to express their gratitude to Wenqing Xu (Under-graduate student; Guangdong Ocean University, Zhanjiang, China) for her great efforts in the whole research project. In addition, the author also thanks Huiyuan Situ, Jinzhen Li, Zhendong Tang, and Yu Yang (Postgraduate student; Guangdong Ocean University, Zhanjiang, China) for assistance in the raw material processing, instrument operation, and charting of this research. References Albertos, I., Martín-Diana, A. B., Cullen, P. J., Tiwari, B. K., Ojha, S. K., Bourke, P., …Rico, D. (2017). Effects of dielectric barrier discharge (DBD) generated plasma on microbial reduction and quality parameters of fresh mackerel (Scomber scombrus ) flilets. Innovative Food Science and Emerging Technologies, 44, 117–122. https://doi. org/10.1016/j.ifset.2017.07.006 Albertos, I., Martin-Diana, A. B., Cullen, P. J., Tiwari, B. K., Ojha, K. S., Bourke, P., &Rico, D. (2019). Shelf-life extension of herring (Clupea harengus ) using in-package atmospheric plasma technology. Innovative Food Science and Emerging Technologies,53, 85–91. https://doi.org/10.1016/j.ifset.2017.09.010 Bao, Y. L., & Ertbjerg, P. (2019). Effects of protein oxidation on the texture and water-holding of meat: A review. Critical Reviews in Food Science and Nutrition, 59(22),3564–3578. https://doi.org/10.1080/10408398.2018.1498444 Barbera, S. (2019). WHCtrend, an up-to-date method to measure water holding capacity in meat. Meat Science, 152, 134–140. https://doi.org/10.1016/j. meatsci.2019.02.022 Barbhuiya, R. I., Singha, P., & Singh, S. K. (2021). A comprehensive review on impact of non-thermal processing on the structural changes of food components. Food Research International, 149, Article 110647. https://doi.org/10.1016/j.foodres.2021.110647 Cheng, J. H., Chen, Y. Q., & Sun, D. W. (2021). Effects of plasma activated solution on the colour and structure of metmyoglobin and oxymyoglobin. Food Chemistry, 353, Article 129433. https://doi.org/10.1016/j.foodchem.2021.129433 Cheng, L. N., Zhu, Z. W., & Sun, D. W. (2021). Impacts of high pressure assisted freezing on the denaturation of polyphenol oxidase. Food Chemistry, 335, Article 127485. https://doi.org/10.1016/j.foodchem.2020.127485 Cho, Y., Muhlisin, Choi, J. H., Hahn, T. W., & Lee, S. K. (2014). Effect of gaseous ozone exposure on the bacteria counts and oxidative properties of ground hanwoo beef at refrigeration temperature. Korean Journal for Food Science of Animal Resources , 34(4),525-532. doi: 10.5851/kosfa.2014.34.4.525. Du, M. T., Huang, L., Gao, M. L., Li, K., Xiang, Q. S., & Bai, Y. H. (2022). Effect of dielectric barrier discharge low temperature plasma treatment on mutton quality. Food Science, 43(21), 87–92. https://doi.org/10.7506/spkx1002-6630-20210628- 316 Fang, C. D., Chen, H. S., Yan, H. B., Shui, S. S., Benjakul, S., & Zhang, B. (2022). Investigation of the changes in the lipid proflies in hairtail (Trichiurus haumel a) muscle during frozen storage using chemical and LC/MS-based lipidomics analysis. Food Chemistry, 390, Article 133140. https://doi.org/10.1016/j. foodchem.2022.133140 Han, L., Patil, S., Keener, K. M., Cullen, P. J., & Bourke, P. (2014). Bacterial inactivation by high-voltage atmospheric cold plasma: Infulence of process parameters and effects on cell leakage and DNA. Journal of Applied Microbiology, 116(4), 784–794. https://doi.org/10.1111/jam.12426 Han, Y. X., Cheng, J. H., & Sun, D. W. (2019). Changes in activity, structure and morphology of horseradish peroxidase induced by cold plasma. Food Chemistry, 301, Article 125240. https://doi.org/10.1016/j.foodchem.2019.125240 Huang, M. M., Wang, J. M., Zhuang, H., Yan, W. J., Zhao, J. Y., & Zhang, J. H. (2019). Effect of in-package high voltage dielectric barrier discharge on microbiological, color and oxidation properties of pork in modifeid atmosphere packaging during storage. Meat Science, 149, 107–113. https://doi.org/10.1016/j. meatsci.2018.11.016 Huang, Y. M., Chang, W. C., & Hsu, C. L. (2021). Inactivation of norovirus by atmospheric pressure plasma jet on salmon sashimi. Food Research International, 141, Article 110108. https://doi.org/10.1016/j.foodres.2021.110108 Koddy, J. K., Miao, W. H., Hatab, S., Tang, L. L., Xu, H. Q., Nyaisaba, B. M., … Deng, S. G.(2021). Understanding the role of atmospheric cold plasma (ACP) in maintaining the quality of hairtail (Trichiurus Lepturu s). Food Chemistry, 343, Article 128418. https:// doi.org/10.1016/j.foodchem.2020.128418 Lan, W. Q., Sun, Y. Q., Liu, S. C., Guan, Y., Zhu, S. Y., & Xie, J. (2022). Effects of ultrasound-assisted chitosan grafted caffeic acid coating on the quality and microbial composition of pompano during ice storage. Ultrasonics Sonochemistry, 86, Article 106032. https://doi.org/10.1016/j.ultsonch.2022.106032 Lan, W. Q., Zhang, B. J., Zhang, X., & Xie, J. (2022). Effects of slightly acidic electrolyzed water combined with compound preservative on the protein characteristics of Pacifci white shrimp (Litopenaeus vannamei ) during refrigerated storage. Journal of Guangdong Ocean University, 42(1), 98–105. https://kns.cnki.net/kcms/detail/44.1635.N.20211224.1820.002.html . Laroque, D. A., Se o o, S. T., Valencia, G. A., Laurindo, J. B., & Carciof,i B. A. M. (2022). Cold plasma in food processing: Design, mechanisms, and application. Journal of Food Engineering, 312. https://doi.org/10.1016/j.jfoodeng.2021.110748 Liao, X. Y., Su, Y., Liu, D. L., Chen, S. G., Hu, Y. Q., Ye, X. Q., … Ding, T. (2018). Application of atmospheric cold plasma-activated water (PAW) ice for preservation of shrimps (Metapenaeus ensis ). Food Control, 94, 307–314. https://doi.org/10.1016/j.foodcont.2018.07.026 Lin, L., Liao, X., Li, C. Z., Abdel-Samie, M. A., & Cui, H. Y. (2020). Inhibitory effect of cold nitrogen plasma on Salmonella Typhimurium bioflim and its application on poultry egg preservation. LWT-Food Science and Technology, 126, Article 109340. https://doi.org/10.1016/j.lwt.2020.109340 Liu, J., Liu, D. H., Zheng, A. R., & Ma, Q. (2022). Haem-mediated protein oxidation affects water-holding capacity of beef during refrigerated storage. Food Chemistry: X,14, Article 100304. https://doi.org/10.1016/j.fochx.2022.100304 Marcinkowska-Lesiak, M., Wojtasik-Kalinowska, I., Onopiuk, A., Stelmasiak, A., Wierzbicka, A., & Poltorak, A. (2022). Application of atmospheric pressure cold plasma activated plant protein preparations solutions as an alternative curing method for pork sausages. Meat Science, 187, Article 108751. https://doi.org/10.1016/j.meatsci.2022.108751 Misra, N. N., & Jo, C. (2017). Applications of cold plasma technology for microbiological safety in meat industry. Trends in Food Science and Technology, 64, 74–86. https://doi.org/10.1016/j.tifs.2017.04.005 Nasiru, M. M., Boateng, E. F., Wang, Z. B., Yan, W. J., Zhuang, H., & Zhang, J. H. (2022). Ultrasound-assisted high-voltage cold atmospheric plasma treatment on the inactivation and structure of lysozyme: Effect of treatment voltage. Food and Bioprocess Technology, 15, 1866–1880. https://doi.org/10.1007/s11947-022-02842- z Nasiru, M. M., Frimpong, E. B., Muhammad, U., Qian, J., Mustapha, A. T., Yan, W. J., …Zhang, J. H. (2021). Dielectric barrier discharge cold atmospheric plasma: Infulence of processing parameters on microbial inactivation in meat and meat products. Comprehensive Reviews in Food Science and Food Safety, 20(3), 2626–2659. https://doi.org/10.1111/1541-4337.12740 Nawaz, A., Irshad, S., Ali Khan, I., Khalifa, I., Walayat, N., Muhammad Aadil, R., …Lorenzo, J. M. (2022). Protein oxidation in muscle-based products: Effects on physicochemical properties, quality concerns, and challenges to food industry. Food Research International, 157, Article 111322. https://doi.org/10.1016/j. foodres.2022.111322 Olatunde, O. O., Benjakul, S., & Vongkamjan, K. (2019a). Dielectric barrier discharge high voltage cold atmospheric plasma: An innovative nonthermal technology for extending the shelf-life of Asian sea bass slices. Journal of Food Science, 84(7),1871–1880. https://doi.org/10.1111/1750-3841.14669 Olatunde, O. O., Benjakul, S., & Vongkamjan, K. (2019b). High voltage cold atmospheric plasma: Antibacterial properties and its effect on quality of Asian sea bass slices. Innovative Food Science and Emerging Technologies, 52, 305–312. https://doi.org/10.1016/j.ifset.2019.01.011 Olatunde, O. O., Shiekh, K. A., & Benjakul, S. (2021). Pros and cons of cold plasma technology as an alternative non-thermal processing technology in seafood industry. Trends in Food Science and Technology, 111, 617–627. https://doi.org/10.1016/j. tifs.2021.03.026 P e erez-Andr e es, J. M., de Alba, M., Harrison, S. M., Brunton, N. P., Cullen, P. J., &Tiwari, B. K. (2020). Effects of cold atmospheric plasma on mackerel lipid and protein oxidation during storage. LWT-Food Science and Technology, 118, Article 108697. https://doi.org/10.1016/j.lwt.2019.108697 Qian, J., Wang, C., Zhuang, H., Nasiru, M. M., Zhang, J. H., & Yan, W. J. (2021). Evaluation of meat-quality and myofbirillar protein of chicken drumsticks treated with plasma-activated lactic acid as a novel sanitizer. LWT-Food Science and Technology, 138, Article 110642. https://doi.org/10.1016/j.lwt.2020.110642 Sun, Q. X., Chen, Q., Xia, X. F., Kong, B. H., & Diao, X. P. (2019). Effects of ultrasound-assisted freezing at different power levels on the structure and thermal stability of common carp (Cyprinus carpio ) proteins. Ultrasonics Sonochemistry, 54, 311–320. https://doi.org/10.1016/j.ultsonch.2019.01.026 Sun, Q. X., Sun, F. D., Xia, X. F., Xu, H. H., & Kong, B. H. (2019). The comparison of ultrasound-assisted immersion freezing, air freezing and immersion freezing on the muscle quality and physicochemical properties of common carp (Cyprinus carpio ) during freezing storage. Ultrasonics Sonochemistry, 51, 281–291. https://doi.org/10.1016/j.ultsonch.2018.10.006 Szmanko, T., Lesiow, T., & Gorecka, J. (2021). The water-holding capacity of meat: A reference analytical method. Food Chemistry, 357, Article 129727. https://doi.org/10.1016/j.foodchem.2021.129727 Ucar, Y., Ceylan, Z., Durmus, M., Tomar, O., & Cetinkaya, T. (2021). Application of cold plasma technology in the food industry and its combination with other emerging technologies. Trends in Food Science and Technology, 114, 355–371. https://doi.org/10.1016/j.tifs.2021.06.004 Wang, Z. M., He, Z. F., Gan, X., & Li, H. J. (2018). Interrelationship among ferrous myoglobin, lipid and protein oxidations in rabbit meat during refrigerated and superchilled storage. Meat Science, 146, 131–139. https://doi.org/10.1016/j. meatsci.2018.08.006 Wang, Z. F., He, Z. F., Zhang, D., Chen, X. S., & Li, H. J. (2021). The effect of linalool, limonene and sabinene on the thermal stability and structure of rabbit meat myofbirillar protein under malondialdehyde-induced oxidative stress. LWT-Food Science and Technology, 148, Article 111707. https://doi.org/10.1016/j. lwt.2021.111707 Xun, P. W., Zhou, C. P., Huang, X. L., Huang, Z., Yu, W., Yang, Y. K., Li, T. Huang, J. B. Wu, Y., & Lin, H. T. (2022). Effects of dietary potassium diformate on growth performance, flilet quality, plasma indices, intestinal morphology and liver health of juvenile golden pompano (Trachinotus ovatus ). Aquaculture Reports , 24, 101110. doi:10.1016/j.aqrep.2022.101110. Yang, Z. M., Liu, S. C., Sun, Q. X., Zheng, O. Y., Wei, S., Xia, Q. Y., … Xu, J. (2022). Insight into muscle quality of golden pompano (Trachinotus ovatus ) frozen with liquid nitrogen at different temperatures. Food Chemistry, 374, Article 131737. https://doi.org/10.1016/j.foodchem.2021.131737 Yu, J. J., Ji, H., Chen, Y., Zhang, Y. F., Zheng, X. C., Li, S. H., & Chen, Y. (2020). Analysis of the glycosylation products of peanut protein and lactose by cold plasma treatment: Solubility and structural characteristics. International Journal of Biological Macromolecules, 158, 1194–1203. https://doi.org/10.1016/j.ijbiomac.2020.04.255
关闭还剩9页未读,是否继续阅读?
中国格哈特为您提供《金鲳鱼(学名:卵形鲳鲹)中挥发性盐基氮(TVBN)的检测》,该方案主要用于生食水产品中理化分析检测,参考标准《SC/T 3032 水产品中挥发性盐基氮的测定》,《金鲳鱼(学名:卵形鲳鲹)中挥发性盐基氮(TVBN)的检测》用到的仪器有格哈特全自动凯氏定氮仪VAPODEST 450、格哈特快速干燥仪STL56、格哈特带自动进样器凯氏定氮仪VAP500C、格哈特强力高重现振荡器LS500/RO500、特大消化管、德国移液器MM、1200ml大体积样品蒸馏管。
