检测样品 化药新药研发
检测项目 方法开发
钻石会员 8138 篇解决方案
The speed of analysis in HPLC has dramatically improved over the last decade due to the development of columns with sub-2 µm particles and the respective UHPLC instrumentation. (U)HPLC method development is, however, still a bottleneck in laboratory workflows and can take from weeks to months, especially if extensive column and eluent scouting is required to complete the development. This often limits the laboratory productivity and increases operational costs. A high degree of automation in column and eluent scouting is required to fully exploit the speed potential of UHPLC.
关闭还剩4页未读,是否继续阅读?
赛默飞色谱与质谱为您提供《A UHPLC method development system for efficient scouting of chromatographic elution parameters》,该方案主要用于化药新药研发中方法开发检测,参考标准《暂无》,《A UHPLC method development system for efficient scouting of chromatographic elution parameters》用到的仪器有赛默飞 Vanquish Flex UHPLC系统、Chromeleon® 变色龙7色谱数据系统。
