UNC-49是一种氧化还原敏感的GABAA受体,非自主调节线粒体未折叠蛋白反应细胞UNC-49 is a redox-sensitive GABAA receptor that regulates the mitochondrial unfolded protein response cell nonautonomouslyTreatment with RSP extracts and NAC RSP was extracted as previously described (37, 57–59) with minor modifications. Instead of the previously used automatic Soxhlet Soxtherm SE 416 (Gerhardt; Königswinter), a conventional Soxhlet extraction apparatus was used in this study. The RSP was initially extracted with petroleum ether, and the defatted RSP was dried overnight at room temperature. The second extraction of the defatted RSP was undertaken with an ethanol/water mixture (95:5), followed by one cycle of evaporation using the rotary evaporator Rotavapor . The final extract was frozen (24 hours) and free-dried (Edwards Freeze Dryer Modulyo) for 48 hours to yield the RSP extract (6.4% yield by weight).
关闭还剩12页未读,是否继续阅读?
中国格哈特为您提供《菜籽渣提取物的提取》,该方案主要用于其他中前处理检测,参考标准《暂无》,《菜籽渣提取物的提取》用到的仪器有格哈特全自动快速索氏提取SOXTHERM、格哈特传统经典索氏提取/萃取仪EV6 AII16、格哈特快速干燥仪STL56、格哈特强力高重现振荡器LS500/RO500、玻璃滤筒、滤纸筒、德国移液器MM。
我要纠错
