检测样品 小麦粉
检测项目 营养成分
钻石会员
3282 篇解决方案
As more food products are imported and exported around the globe, greater quality control methods are needed. Some laboratories are looking for optimized systems that can efficiently and accurately analyze up to eight elements or more in as many as 100 samples per day. Such optimization is essential because it is inefficient to dedicate one analyst to manually running large numbers of samples every day.Cu, Mn, Fe, K, Na, Mg, and Zn are seven elements most commonly measured in food testing. Flame atomic absorption spectrophotometry continues to be an appealing technique for this analysis due to its low purchase price, simple hardware and lower operational costs.In this study, an Agilent AA 280FS flame atomic absorption spectrometer featuring Fast Sequential (FS) mode and PRecision Optimized Measurement Time (PROMT) was used to determine seven elements, Cu, Mn, Fe, K, Na, Mg, and Zn, in a wheat flour reference material.
关闭还剩1页未读,是否继续阅读?
安捷伦科技(中国)有限公司为您提供《Determination of Cu, Fe, K, Mg, Mn, Na and Zn in Food Using AAS in Fast Sequential mode》,该方案主要用于小麦粉中营养成分检测,参考标准《暂无》,《Determination of Cu, Fe, K, Mg, Mn, Na and Zn in Food Using AAS in Fast Sequential mode》用到的仪器有Agilent DUO AA 原子吸收光谱仪。
