检测样品 特医食品
检测项目 营养成分
参考标准 GB 5009.5 食品安全国家标准 食品中蛋白质的测定
连续酶膜反应器生产苜蓿白蛋白水解物中抗高血压肽的表征Characterization of an antihypertensive peptide from an Alfalfa white protein hydrolysate produced by a continuous enzymatic membrane reactor法国天然物质技术实验室喷雾干燥苜蓿白蛋白浓缩物和苜蓿白蛋白浓缩物水解物使用格哈特Gerhardt公司Vapodest 3自动凯氏定氮仪测定蛋白质,转换系数6.25Protein content in the spray-dried AWPC and AWPC hydrolysate was expressed as total nitrogen determined by the Kjeldahl procedure (GerhardtVapodest 3 automatic). The 6.25 factor was used to convert nitrogen into protein as commonly seen for Alfalfa proteins. Each measure was taken three times.Vapodest 3被Vapodest 30替代,Vapodest 30再被Vapodest 30s替代,Vapodest 30s再被Vapodest 300替代
关闭还剩4页未读,是否继续阅读?
中国格哈特为您提供《喷雾干燥苜蓿白蛋白浓缩物和苜蓿白蛋白浓缩物水解物中蛋白质的测定》,该方案主要用于特医食品中营养成分检测,参考标准《GB 5009.5 食品安全国家标准 食品中蛋白质的测定》,《喷雾干燥苜蓿白蛋白浓缩物和苜蓿白蛋白浓缩物水解物中蛋白质的测定》用到的仪器有格哈特自动蛋白测定仪Vap300、格哈特快速干燥仪STL56、格哈特自动升降凯氏定氮电热消解仪KT-L 20s、格哈特强力高重现振荡器LS500/RO500、格哈特维克松废气实验室废物处理系统涤气VS、德国移液器MM、凯氏定氮催化剂5.0g K2SO4+0.5g CuSO4 x 5H2O。
