摘录部分: Section 7 - Handling and Storage Storage: Keep away from heat, sparks, and flame. Keep away from sources of ignition. Store in a tightly closed container. Keep from contact with oxidizing materials. Store in a cool, dry, well-ventilated area away from incompatible substances. Flammables-area. Store protected from moisture.
Section 10 - Stability and Reactivity Chemical Stability: Stable under normal temperatures and pressures. Conditions to Avoid: Ignition sources, excess heat, exposure to moist air or water.
Section 12 - Ecological Information Environmental: (前略) Acetonitrile is unreactive towards photochemically-generated free radicals and direct photolysis in the gaseous phase.
