醉卧古隆中
第1楼2007/11/18
Application of partial least-squares regression to the resolution of highly correlated spectra. Simultaneous spectrofluorimetric determination of Al3+, Ga3+ and In3+
Talanta, Volume 43, Issue 9, Pages 1489-1496 (September 1996)
M. Blanco, J. Coello, F. González, H. Iturriaga, S. Maspoch and A.R. PuigdomènechTalanta43-1489
peter02402
第3楼2007/11/18
Analytica Chimica Acta, Volume 72, Issue 2, October 1974, Pages 295-305Analytica Chimica Acta, Volume 72, Issue 2, October 1974, Pages 295-305
peter02402
第4楼2007/11/18
Analytica Chimica Acta, Volume 114, 15 February 1980, Pages 325-328Analytica Chimica Acta, Volume 114, 15 February 1980, Pages 325-328
peter02402
第5楼2007/11/18
Analytica Chimica Acta, Volume 121, 1 December 1980, Pages 301-308.pdfAnalytica Chimica Acta, Volume 121, 1 December 1980, Pages 301-308.pdf
peter02402
第6楼2007/11/18
Analytica Chimica Acta, Volume 129, 1 August 1981, Pages 195-203.pdfAnalytica Chimica Acta, Volume 129, 1 August 1981, Pages 195-203.pdf
peter02402
第7楼2007/11/18
Analytica Chimica Acta, Volume 193, 1987, Pages 119-125Analytica Chimica Acta, Volume 193, 1987, Pages 119-125
海之巅
第8楼2007/11/18
这次应该补齐了吧
2、The fluorescence properties of metal complexes of aromatic schiff base and their use in fluorimetryThe fluorescence properties of metal complexes of aromatic schiff base and their use in fluorimetry
7、Simultaneous determination of gallium and aluminium in biological samples by conventional luminescence and derivative synchronous fluorescence spectrometrySimultaneous determination of gallium and aluminium in biological samples by conventional luminescence and derivative synchronous fluorescence spectrometry
