所需要的标准全部在下面的包里,有些地方自做主张换了新版的标准
ASTM
boywy000 发表:D4485-01 Specification for Performance of Engine Evaluation of Diesel Engine Oil
E0473-00 Terminology Relating to Thermal Analysis
E0487-99 Constant Temperature Stability of Chemical Materials
E0537-98 Assessing the Thermal Stability of Chemicals by Means of DTA
E0698-99 Arrhenius Kinetic Constants for Thermally Unstable Materials
E0793-01 Heats of Fusion and Crystallization by DSC
E0794-01 Melting and Crystallization Temperatures by Thermal Analysis
E0831-00 Linear Thermal Expansion of Solid Materials by TMA
E0928-01 Mol Percent Impurity by DSC
E0967-97 Temperature Calibration of DSCs and DTAs
E0968-99 Heat Flow Calibration of DSCs
E1824-96 Glass Transition Temperature by TMA in Tension
E1867-97 Temperature Calibration of DMAs
E1953-98 Description of Thermal Analysis Apparatus
E1970-01 Statistical Treatment of Thermal Analysis Data
E2038-99 Temperature Calibration of DEAs
E2039-00 Dielectric properties by DEA
E2040-00 Mass Calibration of TGAs
F2004-00 Transformation Temperatures of Nickel-Titanium Alloys
F2005-00 Terminology for Nickel-Titanium Shape Memory Alloys
谢谢!!
