【讨论】(已应助)求英文文献(Journal of the Electrochemical Society)
文献检索-互助
  • 求Journal of the Electrochemical Society上的文章。
    1. Investigation of Corrosion and Cathodic Protection in Reinforced Concrete.
    D.A.Koleva et al 154, C261 (2007)
    2. Algorithm for Extracting Corrosion Parameters from the Response of the Steel-Concrete System to a Current Pulse .
    V.Feliu et al 151, B134 (2004)
    3. Modeling the Time-Dependent Response to External Polarization of a Corrosion Macrocell on Steel in Concrete
    S.C.Kranc et al 144, 2643 (1997)
    4. Important Early Developments and Current Understanding of the IR Mechanism of Localized Corrosion
    Howard W. Pickering 150, K1 (2003)
    5. Impedance Study of Reinforcing Steel in Simulated Pore Solution with Tannin
    J. Flis et al 143, 2458 (1996)
    6. Electrochemical Behavior, Microstructural Analysis, and 6.Morphological Observations in Reinforced Mortar Subjected to Chloride Ingress
    D.A.Koleva et al 154, E45 (2007)
    7. Investigation of Corrosion and Cathodic Protection in Reinforced Concrete
    D. A. Koleva et al 154, P52 (2007)
  • 该帖子已被版主-海之巅加10积分,加2经验;加分理由:应助!
  • jinjies
    第8楼2008/04/12
    谢谢醉卧古隆中,我还有些ECS Transactions上的文章急需(ECS Transactions, Volume 3, Issue 13 Corrosion of Infrastructure),不知你能否相助?
    我的邮箱jinjies@126.com.
    再次感谢!
