1.Andrade, C., Maribona, I. R., Feliu, S., Gonzales, J. A., and Feliu, S. Jr, The Effect of Macro-Cells Between Active and Passive Areas of Steel Reinforcements, Corrosion Science, 33(2):237–249 (1992)
2.Feliu, S., Gonzalez, J. A., Andrade, C., and Feliu, V., On-Site Determination of the Polarization Resistance in a Reinforced Concrete Beam, Corrosion Engineering, 44:761–765 (1988)
3.Andrade, C., and Gonzales, J. A., Quantitative Measurements of Corrosion Rate of Reinforcing Steels Embedded in Concrete Using Polarization Resistance Measurements, Werkstoffe und Korrosion, 29:515-519 (1978)
111 not ok yet. http://www.sciencedirect.com/science?_ob=MImg&_imagekey=B6TWS-48HY4NW-48-2&_cdi=5570&_user=616134&_orig=search&_coverDate=02%2F29%2F1992&_sk=999669997&view=c&wchp=dGLbVzz-zSkzV&md5=f5c3ea01c39b706c841b7e455e15a35a&ie=/sdarticle.pdf
