1. Effect of electrode orientation on linear polarization measurements using sensor controlled guard ring Law, D.W. ,Millard, S.G.; Bungey, J.H. Source: British Corrosion Journal, v 35, n 2, 2000, p 136-140
2. Electrochemical methods for evaluating inhibitors of steel corrosion in concrete Dhouibi, L.,Triki, E.; Raharinaivo, A.; Trabanelli, G.; Zucchi, F. Source: British Corrosion Journal, v 35, n 2, 2000, p 146-149
3. Effect of intermittent cathodic protection on chloride and hydroxyl concentration profiles in reinforced concrete Hassanein, A.M. Glass, G.K.; Buenfeld, N.R. Source: British Corrosion Journal, v 34, n 4, 1999, p 254-261
4. The influence of binder type, cracking and cover on corrosion rates of steel in chloride-contaminated concrete Scott, A., Alexander, M.G. Source: Magazine of Concrete Research, v 59, n 7, September, 2007, p 495-505
5. Engineering the chemistry at the steel-concrete interface to enhance concrete durability Glass, G.K. Source: Magazine of Concrete Research, v 58, n 10, December, 2006, p 645-646
