我在故我思
第1楼2008/05/12
楼主,你好!这里有一篇关于板栗中铅测定的文献,我没有权限下载,您看看如果有用可以求助下载:
Direct determination of trace lead in chestnut by graphite furnace atomic absorption spectrometry with slurry sampling
Guang Pu Xue Yu Guang Pu Fen Xi. 2005 Apr;25(4):570-2.
A method for the direct determination of trace lead in chestnut by Graphite Furnace Atomic Absorption Spectrometry (GFAAS) with slurry sampling was developed in the present paper. Ammonium ortho-phosphate was used as a matrix modifier. The effects of slurry preparation, particle size of sample, matrix modifier, ashing temperature, atomization temperature, and common coexisting components on the determination of lead were studied. Under the optimized operating conditions, the detection limit, the relative standard deviation (RSD), and the recoveries of standard addition for this method were 0.47 ng x mL(-1), 6.1% (n = 11) and 90%-106%, respectively.
连接: http://www.ncbi.nlm.nih.gov/pubmed/16097688
