阳线
第2楼2008/05/23
所有这些标准论坛都有了。
GB/T 17657-1999 人造板及饰面人造板理化性能试验方法
http://www.instrument.com.cn/bbs/download.asp?ID=31379
GB 18580-2001 室内装饰装修材料 人造板及其制品中甲醛释放限量
http://www.instrument.com.cn/bbs/download.asp?ID=27214
CNS 11818-2007 单板层积材
http://www.instrument.com.cn/bbs/download.asp?ID=86031
ASTM D 5582-00 Standard Test Method for Determining Formaldehyde Levels from Wood Products Using a Desiccator
http://www.instrument.com.cn/bbs/download.asp?ID=85136
BS EN 120:1992 Wood-based panels—Determination of formaldehyde content— Extraction method called the perforator method
http://www.instrument.com.cn/bbs/download.asp?ID=73233
BS EN 717-1:2004 Wood-based panels— Determination of formaldehyde release—Part 1: Formaldehyde emission by the chamber method
http://www.instrument.com.cn/bbs/download.asp?ID=80594
BS EN 717-2:1995 Wood-based panels— Determination of formaldehyde release— Part 2: Formaldehyde release by the gas analysis method
http://www.instrument.com.cn/bbs/download.asp?ID=86029
BS EN 717-3:1996 Wood-based panels— Determination of formaldehyde release—Part 3: Formaldehyde release by the flask method
http://www.instrument.com.cn/bbs/download.asp?ID=84081
BS EN 13986:2004 Wood-based panels for use in construction— Characteristics, evaluation of conformity and marking
http://www.instrument.com.cn/bbs/download.asp?ID=80595
GB 18580-2001与EN 120:1992穿孔法测定人造板甲醛释放量的比较与分析http://www.instrument.com.cn/bbs/download.asp?ID=86032
兰鹰
第4楼2008/05/23
都有了啊,我以前都没有查到。
有些还是资料室到别的地方买的呢。真是献丑了。
那我就把我整理的各国木制品甲醛释放量的限量、规格和方法汇总发一个吧。各国木制品甲醛释放量
