求钯(Pd)的PDF卡片
X射线衍射仪(XRD)
  • 我在做毕业论文,急求钯的卡片。
    哪位高手可以给我传一下,我的QQ:232289320
    或者发我邮箱:fallfeeling@126.com
    谢谢了
  • 第1楼2005/05/31
    传了一下,Pd 89-4897,不过我没有直接上传的权限,你需要等待一下。
  • 第2楼2006/07/01
    PDF#46-1043: QM=Star(+); d=Diffractometer; I=Diffractometer
    Palladium, syn
    Pd    (Black)
    Radiation=CuKa1    Lambda=1.5405981    Filter=Ge
    Calibration=Internal(Si)    d-Cutoff=    I/Ic(RIR)=4.1
    Ref= Kern, A., Eysel, W., Mineralogisch-Petrograph. Inst., Univ. Heidelberg, Germany.
    ICDD Grant-in-Aid (1993)
    Cubic - Powder Diffraction, Fm-3m (225)    Z=4    mp=
    Cell=3.8902    Pearson=cF4 (Cu)
    Density(c)=12.004    Density(m)=12.02A    Mwt=106.40    Vol=58.87    F(8)=615.4(.0016,8)
    Ref= Ibid.
    Strong Line: 2.25/X 1.95/6 1.17/6 1.38/4 0.89/4 1.12/2 0.97/1 0.87/1 0.00/1 0.00/1
    NOTE: Pd (Heraeus, 99.99%).
    2$GU determination based on profile fit method.
    To replace 00-005-0681.
    d(A)     I(f)    I(v)    h    k    l     n^2    2-Theta    Theta    1/(2d)    2pi/d
    2.2458    100.0    95.0    1    1    1    3    40.118    20.059    0.2226    2.7977
    1.9451    60.0    66.0    2    0    0    4    46.658    23.329    0.2571    3.2302
    1.3754    42.0    65.0    2    2    0    8    68.119    34.059    0.3635    4.5684
    1.1730    55.0    100.0    3    1    1    11    82.098    41.049    0.4263    5.3567
    1.1230    15.0    28.0    2    2    2    12    86.617    43.308    0.4452    5.5951
    0.9725    13.0    29.0    4    0    0    16    104.751    52.376    0.5141    6.4606
    0.8925    40.0    96.0    3    3    1    19    119.329    59.665    0.5602    7.0402
    0.8699    11.0    27.0    4    2    0    20    124.627    62.313    0.5748    7.2230
    PDF#65-2867: QM=Calculated; d=Calculated; I=Calculated
    Palladium
    Pd
    Radiation=CuKa1    Lambda=1.54060    Filter=
    Calibration=    d-Cutoff=    I/Ic(RIR)=17.26
    Ref= Calculated from NIST using POWD-12++
    Cubic - (Unknown), Fm-3m (225)    Z=4    mp=
    Cell=3.8908    Pearson=cF4 (Cu)
    Density(c)=11.996    Density(m)=12.02A    Mwt=106.40    Vol=58.90    F(8)=999.9(.0001,8)
    Ref= B.Coles
    J. Inst. Met., 84 346 (1956)
    Strong Line: 2.25/X 1.95/4 1.17/2 1.38/2 0.89/1 0.87/1 1.12/1 0.97/1 0.00/1 0.00/1
    NOTE: N AL3277 6632 IB=Pd See PDF 03-05-6174.
    2.2464    100.0    100.0    1    1    1    3    40.108    20.054    0.2226    2.7971
    1.9454    44.9    51.9    2    0    0    4    46.650    23.325    0.2570    3.2298
    1.3756    22.8    37.2    2    2    0    8    68.105    34.053    0.3635    4.5676
    1.1731    23.6    45.2    3    1    1    11    82.083    41.042    0.4262    5.3560
    1.1232    6.7    13.4    2    2    2    12    86.598    43.299    0.4452    5.5941
    0.9727    3.2    7.4    4    0    0    16    104.727    52.363    0.5140    6.4595
    0.8926    10.9    27.4    3    3    1    19    119.299    59.650    0.5602    7.0391
    0.8700    10.6    27.4    4    2    0    20    124.594    62.297    0.5747    7.2220
    PDF#65-6174: QM=Calculated; d=Calculated; I=Calculated
    Palladium
    Pd
    Calibration=    d-Cutoff=    I/Ic(RIR)=16.42
    Cell=3.8874    Pearson=cF4 (Cu)
    Density(c)=12.028    Density(m)=12.02A    Mwt=106.40    Vol=58.75    F(8)=999.9(.0000,8)
    Ref= King, H. W., Manchester, F. D.
    J. Phys. F, 8 15 (1978)
    Strong Line: 2.24/X 1.94/4 1.37/2 1.17/2 0.89/1 0.87/1 1.12/1 0.97/1 0.00/1 0.00/1
    NOTE: L 44719 42357 0 TF was not given, B set to 1.000 for calc.
    The Pd rod was process-annealed for 2hr at 367C and the heated for a few minutes to 800C to remove residual stresses.
    Materials Research Corporation 20 A low temperature x ray diffraction study of Pd and some Pd-H alloys See PDF 03-065-2867 and 01-089-4897.
    2.2444    100.0    100.0    1    1    1    3    40.144    20.072    0.2228    2.7995
    1.9437    44.2    51.1    2    0    0    4    46.694    23.347    0.2572    3.2326
    1.3744    21.0    34.3    2    2    0    8    68.174    34.087    0.3638    4.5716
    1.1721    20.9    40.0    3    1    1    11    82.170    41.085    0.4266    5.3606
    1.1222    5.7    11.4    2    2    2    12    86.692    43.346    0.4456    5.5990
    0.9718    2.6    6.0    4    0    0    16    104.857    52.428    0.5145    6.4652
    0.8918    8.5    21.4    3    3    1    19    119.471    59.735    0.5606    7.0453
    0.8692    8.1    20.9    4    2    0    20    124.785    62.393    0.5752    7.2283
    上面是三张Pd的PDF卡片数据
