夏天
第2楼2008/11/29
GB-T 20746-2006 牛、猪的肝脏和肌肉中卡巴氧、喹乙醇及代谢物残留量的测定 液相色谱-串联质谱法.pdf
这个标准就是哦!以下编号一直延续到GB/T 20772-2006 (动物肌肉中380种农药及相关化学品残留量的测定 液相色谱-串联质谱法) 可能都是!
30 GB/T 20741-2006 畜禽肉中地塞米松残留量的测定 液相色谱-串联质谱法 Method for the determination of dexamethasone residues in livestock and poultry muscles - LC-MS-MS method 现行 2007-03-01实施
31 GB/T 20742-2006 牛甲状腺和牛肉中硫脲嘧啶、甲基硫脲嘧啶、正丙基硫脲嘧啶、它巴唑、巯基苯并咪唑残留量的测定 液相色谱-串联质谱法 Method for the determination of 2-thiouracil, methyl thiouracil, propyl thiouracil, tapazole and 2-mercaptobenzimidazole residues in bovine thyroid and muscles - LC-MS-MS method 现行 2007-03-01实施
32 GB/T 20743-2006 猪肉、猪肝和猪肾中杆菌肽残留量的测定 液相色谱-串联质谱法 Method for the determination of bacitracin residues in porcine liver, kidney and muscle tissues - LC-MS-MS method 现行 2007-03-01实施
33 GB/T 20744-2006 蜂蜜中甲硝唑、洛硝哒唑、二甲硝咪唑残留量的测定 液相色谱-串联质谱法 Method for the determination of metronidazole, ronidazole and dimetridazole residues in honey - LC-MS-MS method 现行 2007-03-01实施
34 GB/T 20745-2006 畜禽肉中癸氧喹酯残留量的测定 液相色谱-荧光检测法 Method for the determination of decoquinate residues in livestork and poultry muscles - LC-Fluorescence detection method 现行 2007-03-01实施
35 GB/T 20746-2006 牛、猪的肝脏和肌肉中卡巴氧和喹乙醇及代谢物残留量的测定 液相色谱-串联质谱法 Method for the determination of the residues of carbadox,olaquindox and related metabolites in bovine and porcine liver and muscle tissues - LC-MS-MS method 现行 2007-03-01实施
36 GB/T 20747-2006 牛和猪肌肉中安乃近代谢物残留量的测定 液相色谱-紫外检测法和液相色谱-串联质谱法 Method for the determination of metabolite residues of dipyrone in bovine and porcine muscle tissues - LC-UV and LC-MS-MS method 现行 2007-03-01实施
37 GB/T 20748-2006 牛肝和牛肉中阿维菌素类药物残留量的测定 液相色谱-串联质谱法 Method for the determination of avermectins residues in bovine liver and muscles - LC-MS-MS method 现行 2007-03-01实施
38 GB/T 20749-2006 牛尿中β-雌二醇残留量的测定 气相色谱-负化学电离质谱法 Method for determination of β-estradiol residues in bovine urine gas chromatography-negative-ion chemical ionization mass spectrometry method 现行 2007-03-01实施
39 GB/T 20750-2006 牛肌肉中氟胺烟酸残留量的测定 液相色谱-紫外检测法 Determination of flunixin meglumine residue in bovine muscle tissue - LC-UV method 现行 2007-03-01实施
40 GB/T 20751-2006 鳗鱼及制品中十五种喹诺酮类药物残留量的测定 液相色谱-串联质谱法 Method for the determination of 15 quinolone residues in eels and eel products - LC-MS-MS method
夏天
第3楼2008/11/29
GB-T 20746-2006 牛、猪的肝脏和肌肉中卡巴氧、喹乙醇及代谢物残留量的测定 液相色谱-串联质谱法.pdfGB-T 20746-2006 牛、猪的肝脏和肌肉中卡巴氧、喹乙醇及代谢物残留量的测定 [url=https://insevent.instrument.com.cn/t/5p]液相色谱-串联质谱法.pdf[/url]
另外:以上的标准都是食品类的,在食品标准网上可以免费下载!
