国外标准
核桃
第1楼2009/05/16
GB-T 10807-2006 软质泡沫聚合材料硬度的测定(压陷法)
第2楼2009/05/16
DIN 53515-1990Determination of tear strength of rubber elastomers and plastic film using Graves angle test piece with nick生橡胶和弹性体以及塑料薄膜的检验.带凹口的Graves角型试样的连续撕裂试验DIN 53515-1990生橡胶和弹性体以及塑料薄膜的检验.带凹口的Graves角型试样的连续撕裂试验
第3楼2009/05/16
日文的,福昕阅读器查看JIS K 6401-2005 Polymeric materials, cellular flexible -- Polyurethane foam for load-bearing applications -- Specification
第4楼2009/05/16
BS 5852-2006 Mothods of test for assessment of the ignitability of upholstered seating by smouldering and flaming ignition sources
ball5424
第5楼2009/05/16
非常感謝核桃大大,感激您的幫忙!謝謝
