eee9999eee
第1楼2009/06/21
(3)段落扩展
段落扩展(Paragraph Development)是根据主题句的思想来阐明问题的某一方面。好的段落应该是主题单一、内容完整、连贯,长度适中。
段落扩展的方法很多,但由于研究生英语入学考试的写作实际上只是微型作文,这里介绍几种最常用的扩展方法,以供参考。
1)描述法(Description):描述法是段落扩展中最常用的一种方法。描述一个过程或程序时,常用一般现在时的被动语态,这是“一般描述”;报导某一特定的程度或过程时,其涉及到的只是过去某一特定的情况,所以经常使用一般过去时的被动语态。如果描述不涉及到某特定的过程或程序,则经常用一般现在时的主动语态。此外,在描述过程或报导事件时,顺序很重要。
2)举例法(Exemplification):用具体事例来阐述主题句的中心思想。
3)比较与对比法(Comparison and Contrast):比较与对比是阐述段落主旨的常用方法;通过比较指出事物的异同,通过对比找出事物的差异。
下面列出须熟记的10个表示比较的常用句型:
句型a.A is different form. B in that…
句型b.With regard to…, A is bigger than B
句型c.A and B are different in every way(respect)
句型d.One of the differences between A and B is that :
句型e.A and B have a little(something, much etc.) in common
句型f.A is quite (completely, entirely, totally) different from B
句型g.A is not quite as/so big (expensive, interesting etc.) as B
句型h.On (the) one hand, A is (has, does) :;on the other (hand), A is (has, does):
句型i.A is exactly(precisely, just, practically, more or less, almost, nearly, approximately, about) the same as B
句型j.A is much(a great deal, a lot, considerably, somewhat, a bit, al
ittle, slightly, hardly, scarcely, only just) smaller (bigger, cheaper) than B[ZK)]
4)因果法(Cause and effect):通过分析事物发生的起因,来说明由此而产生的种种结果。
下面列出须牢记的8个表示因果的句型例句:
句型a.Bad weather is due to
caused by an increase in air pollution.
句型b.If
When there is an increase in air pollution, (then) the weather gets bad.
句型c.An increase in air pollution often
causes
leads to
results in
produces worse weather.
句型d.As
Since
Because
Now that the air pollution has increased, the weather gets worse.
句型e.The cause ofreason for worse weather was an increase in air pollution.
句型f.The/One resulteffectconsequenceof an increase in air pollution is worse weather.
句型g.The air pollution has increased.
So,Now,Thus,Hence,Therefore,As a result,Accordingly,Consequently,Because of this, For this reason, the weather is worse.
句型h.The weather gets worse, as
since
because
through
owing to
there is
because of
as a result of
on account of an increase in air pollution.
除上述四种扩展段落的方法外,还有许多其他的方法,如综合法、归纳法、分析法和演绎法等。
