beyondcao
第1楼2009/11/02
这是篇日文文献,下面是英文的摘要
p1114
The Effect of Additives in Room Temperature Molten Salt-based
Lithium Battery Electrolytes
Minato EGASHIRA,* Toshiyasu KIYABU, Izumi WATANABE, Shigeto OKADA,
and Jun-ichi YAMAKI
Institute for Materials Chemistry and Engineering, Kyushu University (6-1 Kasuga-Koen, Kasuga, Fukuoka 816-8580, Japan)
Received May 30, 2003 ; Accepted August 28, 2003
Several organic solvent electrolytes used in lithium batteries were added to the electrolyte based on 1-ethyl-3-methyl imidazolium tetrafluoroborate (EMIBF4) in order to improve the deposition/dissolution behavior of lithium metal. The selected solvents for this purpose were ethylene carbonate (EC), dimethyl carbonate (DMC), and vinylene carbonate (VC). All of the selected electrolytes were effective in improving the reversible lithium deposition/dissolution on a steinless-steel electrode when added in 10 w/o. Among the selected solvents, VC provided the best behavior due to its good film-forming ability on the lithium surface in EMIBF4.
beyondcao
第3楼2009/11/03
不好意思,搞错了,因为是日本电气化学会志上的,以为是日本的呢
有英文版
正好最近也引用上面的文章pdfdisp2.pdf
