第3楼2009/02/26
压汞仪原理
压汞仪文献介绍
PoreMaster sales remain very strong, in large part on the basis of the technical features presented in the attached. This information is intended to improve the available resources/information which can be used to "win" sales cases! If there are any questions, feel free to contact me
Best Regards,
1. Effect of support on reactivity and selectivity of Ni-based oxygen carriers for chemical-looping combustion
Gayan, P. / de Diego, L.F. / Garcia-Labiano, F. / Adanez, J. / Abad, A. / Dueso, C. , Fuel, 87 (12), p.2641-2650, Sep 2008
...was taken as the average value of at least 20 measurements. Support porosity was measured by Hg intrusion in a Quantachrome PoreMaster 33. The identification of crystalline chemical species was carried out by powder X-ray diffraction (XRD) patterns acquired...
Published journal article available from ScienceDirect
similar results
2. Microstructural development in porous ±b-Si3N4 ceramics prepared with low volume RE2O3-MgO-(CaO) additions (RE=La,...
Plucknett, K.P. / Quinlan, M. / Garrido, L. / Genova, L. , Materials Science & Engineering A, 489 (1), p.337-350, Aug 2008
...porosity content. The pore size distribution of selected samples was determined using mercury intrusion porosimetry (Model Poremaster PM33-7, Quantachrome Instruments, Boynton Beach, Florida, USA). Post-sinter microstructural characterization was conducted...
similar results
3. Pressure infiltration of boron nitride preforms with molten aluminum
Sithebe, H.S.L. / McLachlan, D. / Sigalas, I. / Herrmann, M. , Ceramics International, 34 (6), p.1367-1371, Aug 2008
...identify free aluminum present and borides in the samples. The pore structures of the green samples were calculated using a PoreMaster-60 Quantachrome Instruments, Hg porosimeter (Fig. 2). The hardness was measured with a load of 10kg. 3 Results Infiltration...
similar results
4. Preparation and characterization of carbon-enriched coal fly ash
Rubio, B. / Izquierdo, M.T. / Mayoral, M.C. / Bona, M.T. / Martinez-Tarazona, R.M. , Journal of Environmental Management, 88 (4), p.1562-1570, Sep 2008
...analysis, samples were outgassed at 250^oC under vacuum up to 10-5mmHg. Analyses of mercury porosimetry were carried out in a Poremaster from Quantachrome. Morphological examination of the samples (coated with a gold layer) was carried out by means of scanning...
similar results
5. Porous bioceramic bead prepared by calcium phosphate with sodium alginate gel and PE powder
Fu, Y.C. / Ho, M.L. / Wu, S.C. / Hsieh, H.S. / Wang, C.K. , Materials Science & Engineering C, 28 (7), p.1149-1158, Aug 2008
...Msubmerged). In addition, the volume of the pore size lower than 10 mum was valuated by mercury porosimetry (Quantachrome PoreMaster 60, Germany). 3 Result and discussion 3.1 Characterization of as-synthesized powder 3.1.1 Powder morphology The view of as-lyophilized...
similar results
6. Carbon-enriched coal fly ash as a precursor of activated carbons for SO2 removal
Izquierdo, M.T. / Rubio, B. , Journal of Hazardous Materials, 155 (1), p.199-205, Jun 2008
...analysis, samples were outgassed at 250^oC under vacuum up to 10-5mmHg. Mercury porosimetry analyses were carried out in a Poremaster from Quantachrome. The morphological examination of the samples (coated with a gold layer) was done by means of SEM in a Hitachi...
similar results
7. Preparation of uniform porous hydroxyapatite biomaterials by a new method
Tang, Y. / Tang, Y. / Lv, C. / Zhou, Z. , Applied Surface Science, 254 (17), p.5359-5362, Jun 2008
...SEM observations. The pore size distribution of porous HAP materials was measured by mercury intrusion method (Quantachrome PoreMaster, USA). 3 Results and discussion HAP powders were prepared by hydrothermal technology using CaHPO4.2H2O and CaCO3as raw materials...
similar results
8. Paper-structured catalyst with porous fiber-network microstructure for autothermal hydrogen production
Koga, H. / Fukahori, S. / Kitaoka, T. / Nakamura, M. / Wariishi, H. , Chemical Engineering Journal, 139 (2), p.408-415, Jun 2008
...JSM-5600, JEOL, Ltd.). The electron accelerating voltage was set at 10kV. Mercury intrusion analysis was carried out using a Poremaster 33P (YUASA IONICS, Ltd.) to evaluate the pore diameter and porosity of the catalyst samples. The pore size distribution was...
similar results
9. Textural characterization of native and n-alky-bonded silica monoliths by mercury intrusion/extrusion, inverse size...
Thommes, M. / Skudas, R. / Unger, K.K. / Lubda, D. , Journal of Chromatography A, 1191 (1), p.57-66, May 2008
Native and n-alkyl-bonded (n-octadecyl) monolithic silica rods with mesopores in the range between 10 and 25nm and macropores in the range between 1.8 and 6.0@mm were examined by mercury intrusion/extrusion, inverse size exclusion...
similar results
10. Geometric control and tuneable pore size distribution of buckypaper and buckydiscs
Whitby, R.L.D. / Fukuda, T. / Maekawa, T. / James, S.L. / Mikhalovsky, S.V. , Carbon, 46 (6), p.949-956, May 2008
...fine structure and apparent pore sizes. All buckypaper samples and purified MWCNT powder were analysed using a Quantachrome Poremaster. As each buckypaper weighed 5-15mg, several sheets of buckypaper were used in order to conduct mercury porosimetry tests on...
similar results
