【已应助】该文献EI ACCESSION NUMBER, SCI SID(收录号)
  • goodlucktous
    2011/05/21
文献检索-互助
  • 文献标题:MESHING THEORY AND SIMULATION OF NONINVOLUTE BEVELOID GEARS WITH CROSSED AXES
    摘要:Based on the space engagement theory, a special type of noninvolute beveloid gears meshing with line contact between crossed axes has been studied in this paper. The engagement equation and tooth profile equation have been presented by applying the theory of gearing. Meanwhile the tooth profile errors and axial errors have been calculated by means of numerical analysis in this paper. The changes of these errors and the main factors have been studied. As a numerical example, the three-dimensional simulation of beveloid gears between crossed axes has been finished by means of the CAD system, Pro/Engineer. A new way of gear tooth modification is developed based on the space engagement theory for the first time in this paper. By improving the wheel gear grinder of large plane grinding, the paper has provided the tooth modification method of manufacturing noninvolute beveloid gears meshing with line contact between crossed axes. Finally, an example and its calculation results are presented.
    作 者: Guangbin YuYuxiang ShiWei WangGuixian Li
    母体文献: 2007 ASME International Design Engineering Technical Conferences and Computers and Information in Engineering Conference (DETC 2007)
    会议名称:
    会议时间: 2007年01月01日
    会议地点: Las Vegas, Nevada, USA
    求EI ACCESSION NUMBER, SCI SID,谢谢!
  • goodlucktous
    第1楼2011/05/21
    EI,SCI检索号,识别号也可以,分别标明即可。
  • wangshirf
    第2楼2011/05/21
    一天第二贴求助,需要悬赏!
  • 灰米奇
    第3楼2011/05/23
    EI:Accession number:2008241316862
  • 该帖子已被版主-zhumenjun1984加2积分,加2经验;加分理由:谢谢应助
  • goodlucktous
    第4楼2011/05/28
    谢谢你的帮助!
